Question about Crown CE2000 2-Channel Amplifier
Crown Amp Possibly Blown??
I simply turned on a Crown CE2000 and it let a little bang and output some smoke. The fault lights remain lit all the time. I checked both speakon leads for shorts, it wasn't the cause. Are components easy to get for such an amp? What would be most likely to have gone? (transformer, voltage amp...) is it worth fixing?
Thanks in advance
Mech Eng & botch job DJ
  • NoelMc Apr 08, 2008
    Thanks Graeme,
    I had a look at the circuit, it appears the relay on one of the channels blew up, i.e. there's a nice big hole in the side of it and there's a few burnt components around it. I'm presuming this might have been caused either by a faulty relay or short in the speaker wire? I'm going to replace the damaged components, put it back together and put it out into the middle of the lawn, switch on the extension lead and hope it doesn't blow up!
  • 1,512 Answers
Hi, probably worth fixing, Crown gear is generally reliable, but this one has failed for some reason. Puffs of smoke are not generally good... If it has blown an output array, expect a costly repair.
Posted on Apr 04, 2008
  • Graeme Ross
    Graeme Ross Apr 08, 2008
    Aahhh.... not sure what sort of relay could end up with a hole in it, is probably the output stages you are looking at. Do they mount to a heatsink??
    If it has an array of outputs, then expect there to be more than one part blown. All output transistors and driver transistors need to be checked. By design, the amp uses direct coupling, and a cascade effect of failed components is often found. Don't just replace the parts that are physically fire it up again without soft starting the amp will result in the parts you just replaced and possibly more blowing again. Softstarting is where you use a variac to lower the voltage/power available to the output stage to prevent it from blowing if there is still a faulty part that was NOT replaced. Transistors may often appear to be ok, but have catastrophically short circuit junctions or leakage between junctions. The best bet when you have failed output components for a reliable repair is to replace the entire array and drivers also. All parts in the output stage have been under huge stress with the sort of failure you have had, and can sometimes be stress damaged, to then blow in the future, putting you back to square one. If you have any further questions about it, ask away. I have repaired this type of unit for a living. It is hard however to relay my experience with fault finding high power equipment to you from here. If the amp does not mean much to you, then I wouldnt even bother with it. If it does, then take it to a repair guy that does this type of unit and get a quote. Could work out better for you in the long run:)
Red fault light on amp high pitch squeal through speakers
Clearly a main power amp failure. Look to the device(s) located on the big heat sink and replace them.
Dec 14, 2013 | Crown CE2000 2-Channel Amplifier
Red and green lights falshing on and off....
Please add some more information, such as this amp show some smoke before? was it working then all of the sudden stops? The 2 red lights generally speaking means that there's a power amp stage failure, which could be from moderate to severe, please put some more information and i will be glad to help you.
Nov 07, 2013 | Crown CE2000 Amplifier
I want the Amp diagram.
You can download the complete service manual including the schematic diagram also.
Here is the link.
Unfortunately there are many possibilities of faults and so I can not give you any solution. You should have given description about the problem.
When you get to the site using the link it is possible that you have to wait a little bit to be able to download.
After waiting you should see a button as "Get Manual" and simply click on it and save the file.
Apr 18, 2012 | Crown CE2000 2-Channel Amplifier
Fault light on my crown ce 2000 is on both channels
It sounds like your output transistors are bad or power supply problems. You will need to have it serviced unless you know about electronics and how to repair them. Do not attempt this yourself unless you know what you are doing. It could be fatal.
Nov 02, 2011 | Crown CE2000 2-Channel Amplifier
Fault lights keep blinking
I have one upstairs in my repair que. There are some small glass fuses ( 20 mm long) on the power supply board.
Check those
Apr 20, 2010 | Crown CE2000 2-Channel Amplifier
I request a schematic diagram of crown power amp CE2000 2-Channel
The surface mount ic= MC33079D , 14 pin quad low noise op amp is likely at fault, IF the amp is NOT showing a fault light. A LM324D surface mount will
also work in a pinch. It's located on the input pcb attached to the input jacks.
Jan 19, 2010 | Crown CE2000 2-Channel Amplifier
I have Crown ce2000,it turns off after a short period then on then off ect.
IF all the outputs are connected right and it still does that..Take it to a tech..You have bad output transistors
Jun 27, 2009 | Crown CE2000 2-Channel Amplifier
Fuse for crown ce2000 amp???
The problem is not a fuse. The red light indicates that the unit is in "protect" mode. This means that a problem was detected in the final amplification stage and the unit is prevented from turrning on completely to prevent damaging either the speakers or the amp further. These are not the easiest to repair without prior experience and I would not suggest you attemt the repair. Please seek an authorized Crown repair center for assistance.
May 07, 2009 | Crown CE2000 2-Channel Amplifier
Is it clipping for real or overheating ? It may just be a fault with the indicator light circuitry itself. Make sure the input levels of the amp are matched with the output levels of whatever device is running into the amp, they will either be +4 dbm or -10 dbu, if you have a choice you want them to be set at +4 dbm. Crowns are professional amplifiers and withstand years of hard touring on the road, it would definitely be worth it to take it to a good repair shop if you can't remedy the problem yourself.
Jul 26, 2008 | Crown CE2000 2-Channel Amplifier
clipping as indicated by its light? if so then you have overdriven your output. i dont know about Crown their protection but normally such indication you have problem with either your load speakers maybe shorted but still audible or maybe your input stage overdriven also.
Mar 17, 2008 | Crown CE2000 2-Channel Amplifier
Crown CE2000 2-Channel Amplifier Logo
869 people viewed this question
Top Crown Audio Players & Recorders Experts
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
