Question about RCA F32450 32" TV
Need your help!
Hey I have read what you have said about the tv not comming on. My Tv will also not turn on. We had a storm one day and the electric went out. When it came back on our tv did not, however I thought since it was plugged into the cable box and if the tv blew then it would have also blown the cable box. But I went today and got the fuse you have mentioned and it still will not come on. Is there any more suggestions you have? The Tv is a 2000 and I have never had a problem with it. But its a RCA F36685 if you know anything I could do I would really appriciate it.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Replace tv. unplug tv
not worth it
potential fire hazard.
Posted on Aug 14, 2008
SOURCE:
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
My TV will not power on but I here when it is plugged in that it has power it will click like it is wanting to power up but nothing happens. I had an electrical storm prior to my problem
The tv power supply board it is dead,u said had an electrical storm in ur area before this problems happen.Yes.Than the tv have a power surge by of the electrical storm already,the storm had a charge sent of an electrical magnatic statics to ur tv and now kills all those sensitive ICS on ur tv power suppply board already.The tv power supply board already dead that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jul 08, 2011 | Mitsubishi LT-52149 52 in. LCD HDTV
The morning after a storm(the tv was off during the storm), i turned on the tv. it worked for about 20 minutes, and all of a sudden it turned black. At first there was sound just no pic. After 1 day, there...
You need to get it fixed under warranty ASAP, if you open it up (which you need to) it will void waranty. This is not a good sign, since if it failed within a year, then more likely to be bad unit.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 23, 2011 | Samsung LN32A330 32 in. LCD TV
Sony trinitron 36" flat screen tv
Unfortunately, TV sets are not equipped with adequate internal protection against electrical storm damage, and it doesn't matter that the TV was turned off if it was left plugged in to an active electrical receptacle and/or directly connected to an antenna or an Internet data line. The fact that you can still receive anything at all indicates that the TV set can probably be repaired at a service shop, but for future protection of the set you should purchase a good surge protection device such as the one found at the below link.
Amazon com APC 11 Outlet Surge Protector 3020 Joules with Phone Network...
Jan 20, 2018 | Televison & Video
TV will not turn on since electrical storm
yes, a fuse need to check. open back cover and trace for possible burn fuse or ckt. if burn ckt found your unit need to bring nearest service center for possible replacement.
Jun 02, 2010 | Televison & Video
Samsung 52" tv
you could possibly have damaged the deflection power supply that part is not to expensive if you can find a reputable shop they should be able fix you up pretty cheap as opposed to a new. if the set had a good picture get it fixed its a good set
Jun 11, 2008 | Samsung HC-P5241W 52" Rear Projection...
Hitachi 50vs69a
have power supply normally the voltage regulator gose bad normally start str f668b
Apr 21, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Tv will not turn on after lightning storm
Defective HV transformer. (Likely lost it during the storm)...accordianman
Nov 28, 2007 | Orion TVDVD092 9 in. TV/DVD Combo
RCA F32450 32" TV Logo
42 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
