Dell Monitor keeps blowing fuses - Computers & Internet
    Sergeant:
  • 349 Answers
Well a fuse is a safety feature of all electrical devices ,the only suggestion i can give is to try a different power cable, if it is a detachable one,if that don't work,
you need to take it to an electrical repairer,as it has an obvious fault ,
it is not wise to play around with monitors ((CRT)Cathode Ray Tube) type, as they can retain 10,000 volts in some parts, too dangerous to suggest you enter the case.
if it is an old CRT monitor, it will not be worth the cost of repair.as a second hand one will only cost about AU$20.
good luck
Terry
Posted on Apr 04, 2008
Keep blowing number 32 fuse in a 2005 Lincoln navigator what causes it to keep blowing
fusee blow because of excess current caused by a short either in the wires after the fuse or in the equipment that the fuses controls.
Dec 21, 2014 | 2005 Chevrolet Equinox
Bm5a blows fuse when turned on
Blowing a fuse means that it has a dead short. The fuse does its job by protecting the other components while the circuit fails. Something is definitely burned out inside.
Mar 24, 2014 | Dynaudio BM5A Active Monitor
My DELL MMS 5650 Subwoofer fuse keeps on blowing out. Any suggestions?
well you might want to see what the output on your computers sound card is if it is to high that would explain it or if you have the base set to high that would also make the fuse blow on it
Jun 05, 2011 | Dell 5650 Computer Speakers
I keep blowing my 20 amp fuse, replaced mag tube and diode
Check the HV capacitor. It may be short circuited.
Also check the door switches. One of the switches (the monitor switch) is connected directly across the power and is there to blow the fuse in the event that the timing of the door switches are incorrect.
The monitor switches on Panasonic micros will also short.
Jan 04, 2011 | Microwave Ovens
I have a viewsonic vp211b monitor and when I try to hook it up to my dell it doesn't do anything at all. no pictures on the screen nothing. The power supply is fine as I am getting a green light on the...
I have repaired several of these Viewsonic VP211b monitors. In every case, the problem was a blown fuse on the inverter board. There are two fuses, F1 and F2. Either one can fail. The fuses are located on either side of the CN1 connector. These fuses are 1.5 mm long, 1.0 mm wide and 0.5 mm high (Case Style 1206). They have the letters FN printed on them. The N is for 2 Amps and the F is for Very Fast Blow.
The fuses were made by LittleFuse. The replacements were purchased from Newark Electronics. Part number 64R8010. This part number is the Fast blow 2.0 Amp (not the Very Fast blow), but they work fine.
Troubleshooting hint:
The screen is illuminated with fluorescent back lights. Those back lights are powered by the inverter. If everything is working except the back lights, you should be able to see a faint image by shining a bright flashlight into the screen.
Aug 06, 2010 | ViewSonic VP211b 21.3" LCD Monitor
My Dell monitor keeps turning off .
Look for shorted out transistors and blown fuse, bad caps, poor solder joints,
http://s807.photobucket.com/albums/yy352/budm/Dell%20E193FP/
Aug 04, 2010 | Dell E193FP 19" LCD Monitor
I have a J HP60G 002 GE Microwave (older)keeps
If it blows the line fuse instantly when you push start.... it is either a shorted HV capacitor or shorted monitor switch.... most likely.
Sep 13, 2009 | Microwave Ovens
Monitor fuse keeps blowing
There is definately a shorted component that causes the fuse to blow. Nomaly the ceremic capacitors are the cause of the problem. Check to see if there is visiual dark or burnt ceremic caps with label sameting like this "SCK 083" near the fuse area and change it. Hope it helps,cheers.
Jan 21, 2009 | Computers & Internet
Blowing fuses
noavatar_s.png this was me homerweezy i had not register when i wrote this but i hope i helped you out
if there is no power what you do is re soder the power inlet , if it powers but no light you can bridge the fuse in the inverter its a yellow or orange fuse it should say F1 bridge it and it should work
Jan 25, 2007 | Dell E151FPp 15" TFT LCD Flat Panel...
Computers & Internet Logo
273 people viewed this question
David Payne
David Payne
