Question about Braun Syncro 7526 Electric Shaver
Braun SynchroPro 7526
The slider with 1-2-3 does not got all the way back. Any the shaver stays on. I had to run the battery down. any idea how I can get it all the way back. the removed the small black piece where the plug goes in. i took off both sides - any idea what the next step would be. Desperate.
Larry from New York
Pry out the blue button. In the oval hole where the button was you will see a thin metallic part (semi-circular shapes on each side); pull it out through the hole and the switch will be functional.
Posted on Aug 12, 2008
  • HobbyHound Dec 26, 2010
    December 25, 2010 - My dad's Braun 5726 razor would not turn off. I waited for battery to quit. Then I found solution above. This solution really does work. The reason this model razor will not turn off is because some internal plastic part failed and the inner metal shim gets jammed. The above fix works great, saved me expensive repair or buying a new one razor for my dad. This was an easy fix if you have small screw driver to prey the button and shim out. If I had known about this fix sooner I would have tried this procedure while unit was running. The parts removed have nothing to do electrically. The shim removed appears to be only mechanical. Whoever posted this fix.. THANKS Much..!!! :)) Finding the fix was a nice Christmas present.. My dad could use his razor the next day without having to wait on professional repair or downtime. Just a side note. Using this repair the blue button remains removed, but the on / off sliding works smooth without it. Many thanks again.
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 screws
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
Braun 7526 requires new battery
You will find the correct battery type at shaveroutlet.com at the link below. You will need two. Scroll down the page for video instructions
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Sep 02, 2011 | Braun Syncro 7526 Electric Shaver
Braun 7526 needs new rechargable battery
You will find batteries for model 7526 at shaveroutlet.com. See link below
Scroll down the page for disassembly video instructions.
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Feb 21, 2011 | Braun Syncro 7526 Electric Shaver
Need new batteries for 7526 braun
You will find compatible batteries at shaveroutlet.com. See link below.
I suggest that you read the installation tip on the page
Nov 24, 2010 | Braun Syncro 7526 Electric Shaver
Braun saver 7526 does not lock. it stays on. how to fix? Do you have numer for repair service if i can not fix it myself
if the arm on the stand is not locking down, this can be replaced. you will find this part at shaveroutlet.com
Dec 30, 2009 | Braun Syncro 7526 Electric Shaver
How to replace battery on braun 7526 electric shaver
3) Using a small torq driver remove the 4 scews
4) Open shaver
6) Install new circuit board and reassemble
Nov 20, 2008 | Braun Syncro 7526 Electric Shaver
Open the shaver:
4) Open shaver
Oct 25, 2008 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
174 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
