Question about Toshiba 43H70 43" Rear Projection Television
Toshiba 43H70 - making it HD
When we purchased the TV, we were told we would eventually need to purchase a part to make it high def. Do you know what part that is and the cost of it?
Thanks
You need a high definiton cable box from cable company with your subcription to digital cable signal.
Posted on Apr 13, 2008
  • Toshiba Master
  • 8,617 Answers
You cant make it high Def. The converter only allows and analog tv to recieve digital signals, But it wont make it a HDTV
Posted on Apr 09, 2008
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
Can't get HD on my TV. Tried with every cable type but cannot get High Def
2 things have to happen. first, your tv has to be set for the correct resolution, second, You need to be recieving high def from your cable/sat provider.Your tv does not make programming high def, it allows high def.
Mar 10, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
How do I fix a fuzzy screen
A fuzzy television screen is generally not the fault of the game console itself, but of your television.
The Xbox 360 is an HD game console, and from personal experience, trying to render an hd image in 480i Standard Definition will cause it to look somewhat fuzzy regardless of the television.
Just to make sure it is not the Xbox, I would, if possible, suggest you try the 360 on another television, preferrably with the HD cables (remember that there's a switch on the cable itself that you will need to switch from SD to HD).
Unfortunately, if you do not have access to a high def television, you can always fiddle with the contrast and sharpness on your standard def TV to reduce the fuzzyness, but the screen will always be somewhat fuzzy.
I realize this is probably not the answer you wanted, but to solve this problem for my own Xbox, I ended up purchasing an inexpensive HD Television.
Nov 01, 2010 | Microsoft Xbox 360 Console
Gentlemen; We purchased a 32 inch hygh def TV app 3 years ago. We had an issue with a burned out 32 inch model and had a certified repair tech come up to our home and had the main board replaced in I...
Please note that we are not affiliated with any company. We are a bunch of independent consultants with hands on experience at fixing stuff. However if you can get me the make and model of the tv along with country of residence I can get you the contact info of the customer service department so that you can get it replaced.
Oct 31, 2010 | Televison & Video
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
CLEAR PICTURE ON MY 42
Dear LADY DAWN,
In order to get true high definition quality, you would want a high definition source. There really is not much else you can add to make your picture clearer, provided you have it hooked up with the best type of cables possible.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jul 21, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Can i upgrade to hd on this tv
I am not finding anything on the net about being able to upgrade it but the HD in the model # stands for high def but the tv is old enough that it may not go up as high as 1080 most likely just 480i or p which can be achieved with an s-video or might be 720 with the R/B/G connector or a DVI connector, you can look for converting cables on ebay
Jan 26, 2008 | Akai PT4298HD Rear Projection Television
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
62 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
