Question about Prima C2012 TV
Prima cr-20sb72 tv
Need to find the values for R524,R525 on board SPW 782550042 ????who builds those circuit boards
  • Gene Wells May 11, 2010
    Do you have the color code of the resistors?
    Geno
    Scholar:
  • 160 Answers
Start with products to specs or contact support.
http://www.primaamerica.com/support.asp
Posted on Dec 01, 2008
RESISTAN VALUE OF R522,R524 ON THE INVERTER BOARD BA71F0F01041.
Hi Juan,
the resistor values you want are:
R52
RES METALIZED FILM T 1/4W F 3.92k?
R524
CARBON RES. 1/4W J 10k?
The complete Service Manual is available as a .pdf Here:
Sylvania LC420SS8 LCD TV Service Manual
Its free to view, but you'll have to agree to a free 14 day trial membership to download it. Hope this helps you,
Jan 22, 2016 | Sylvania LC420SS8 LCD TV
Prima tv lcd ht3461 just clip for a while then turn off completely
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 19, 2014 | Prima Televison & Video
Need to get the circuit diagram for board e106527 srf-c 94v found on TV Digistar Model CR_20SS01D
quick way with location number for the part (a cap?) will be marked on the board---call the maker or Google the model number with the location number.
Oct 15, 2012 | Prima Televison & Video
Tv is discolored
remove the rear cover to access the main board, then you can do first with re soldering cold soldered component parts at video section which get loose contact to the pcb ( printed circuit board ).just let me know if it works good luck.
Jul 25, 2012 | Prima C2012 TV
I have a 42" Prima
Hi Howard,
It sounds to me the Power Supply Board is bad. You will need to get the numbers off the original board by taking the back off the set ( After unplugging the set of course) and the you can contact a board company ( Encompass Parts Distribution ) or any other company that you might find on the internet with your google search engine and order the board. Good luck with this problem.
Ed " Original Radio Man"
Nov 20, 2010 | Televison & Video
Prima sreen goes red on me is my tube gone
no ur tv must be had loose contact in video board section...or..driver transitor or driver ic may be failed in the vedio board section..if the tube is gone then there will be several horizontal retrace line will be found with red color, and they will not shake.. have a good day..
Feb 25, 2010 | Prima CV2011 TV
Prima plasma kept turning off by itself, then made popping noises in the back of tv and then no power at all!
This sounds like a problem with the power supply. Usually capacitors on the power supply board tend to dome, bulge or dry up. The damaged ones can be seen on the power supply circuit board when the back is removed. The dry ones have to be removed and tested. The caps can be replaced at a repair shop for around $200, but if the power supply board has to be replaced it can cost a little more. It all depends on the shops repair fees.
Sep 17, 2009 | Prima C2012 TV
5 flashing light code,unplug CR board,now 8 flashing light code
If you put the "CR" board back on, the error code will once again be 5 blinks. Your problem is likely the TV's IK blanking circuit. The Kine driver ICs on the CRT sockets boards CR, CB, and CG need replacement along with a few components in the 200 volt supply to the circuit.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Internal problem
but you did not give the model number nor did you give the chassis number
Jan 22, 2009 | Televison & Video
LC-23Y25 Problem with turning on power?
so i had the same problem. red light came on, but no blue light or anything on the screen. it turns out that there were some capaciters blown on the circuit power board. unless you have a good understanding of circuit boards, its not a quick fix. but for someone who knows their electronics, its not too hard, and its not expensive to fix, unless you bring it into a store. but the supplies needed arent expensive. good luck
Nov 09, 2008 | Prima C2012 TV
Prima C2012 TV Logo
168 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
