Question about Compaq iPAQ H3765 Pocket PC
Compaq ipaq i have a compaq ipaq 3765 and bought the sleeve with the expansion pack for it, i am plugging in my wireless g card to the back and cant get it to connect to my network wirelessly, how do i connect
Hi i am wolson so i have a problem with my pocket pc so i need connect it to the internet but i can't can you explain what i suppose to do please
Posted on May 29, 2009
I can not figure out how to connect my device to the internet Wi-Fi, I want to go on internet explorer and it won't connect
To send and receive e-mail with Inbox and view Web sites with Pocket Internet Explorer, set up a remote connection using a modem card or an Ethernet/LAN card.
To connect to the Internet with a modem card, you need a phone line, a dial-up Internet Service Provider, and an optional Single-slot or Dual-slot PC Card Expansion Pack or CompactFlash (CF) Card Expansion Pack.
*Insert your modem card
*From the Start menu, tap Settings
*Tap the Connections tab->Connections Icon-->Internet Settings-->Modify-->New
*Enter a name for the connection, select the modem type, and select the correct baud rate for that modem.
I have shared the basic steps..which I refereed using the reference guide for the model that you have specified from this website.This you can easily get my typing "reference guide for Compaq iPAQ H3850 Pocket PC" in Google...and the first link lets you download the PDF..Follow the steps carefully and connect to the internet.To check for the internet speed you can use Scanmyspeed.com which gives you accurate speed results.
Oct 28, 2013 | Compaq iPAQ H3850 Pocket PC
How to get on line with an ipaq 2490
You need an expansion card. SD 56k modem cards is recommended.
You can also use the built in WiFi to connect to a wireless router nearby
Feb 12, 2010 | Compaq iPAQ H3630 Pocket PC
Where do I find the model number?
Look on the capsule-shaped sticker on the back. Near the bottom, left, you'll see under the part number ('P/N') the word 'MODEL' and then a number ('3765') under that.
Oct 24, 2009 | Compaq iPAQ H3765 Pocket PC
IPAQ 3765 Won't Turn On
you may have to buy a new battery for the unit. Simple as that
Jan 05, 2008 | Compaq iPAQ H3850 Pocket PC
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Memory upgarde ipaq 3630
Hi there
1) Where can you purchase the memory? - you can buy them at many stores such as Walmart if you come from USA or Game if you come from South Africa.
2) How much can you put in? - Depending on the model of your Pocket Pc you can put up to 1gigabite but they usually come with only 64mb.
3) How to install it - You must first buy an HP expansion pack which you place on your Pocket Pc and you place the extra memory card in the expansion pack.
4) Where can you download software for it? - The memory card comes with the software installed already
Kind regards
Dustin Ellse
Nov 29, 2007 | Compaq iPAQ H3630 Pocket PC
EXPANSION PACK WIRELESS PC CARD
You need to install the drivers for it.
Xracer
Oct 31, 2007 | Compaq iPAQ H3955 Pocket PC
How do I find the MAC address on IPAQ 3765
I have the same problem and I'm yet to find a solution :(
Oct 26, 2006 | HP iPAQ H3765 Pocket PC
IPAQ 3700 series
Most iPaqs use a small AC Adapter This model will still need an AC Adapter, because it does not draw any current from USB to charge.
Oct 11, 2006 | Compaq iPAQ H3630 Pocket PC
Compaq iPAQ H3765 Pocket PC Logo
232 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
