Question about Honeywell HT-800 Table Fan
The fan has hair and dust trapped inside so it can't turn correctly... it takes awhile to start up and has trouble turning. Is there any way to take it apart to clean it?
Just had the exact same problem. there's 6 screws to remove along the back side of the fan grill, 4 of them are philip and 2 of them torx. don't know why they didn't just make them all the same! once the screws are out, you can take off the faceplate. you can then clean most of the fan, however it will be difficult to clean the area near the motor.
Posted on Apr 28, 2008
My computer keeps freezing up, have to turn off and then on and works for awhile.
sounds like you need to take the side off and get the hoover round the inside...dust will build up round the fans causing it to overheat....i normally paintbrush all insides then hoover..
Jan 04, 2016 | Compaq Computers & Internet
Why does wii u turn off while playing games
It is more then likely overheating. Check that the fan isn't blocked by hair and/or dust. Blow compressed air into the fan to clear anything that could be causing it not to function correctly. Also, make sure you can hear the fan operating while the unit is on to make sure it has not failed.
You should never leave a gaming console on the floor due to buildup of dust/hair and cause it to overheat. This also applies to leaving it in a confined space as it will not have enough air available to expel the heat it creates while running.
Apr 23, 2014 | Nintendo Wii Console
Sony kds-rx60xbr1 red light blinking turn it on and off and tv goes on
The lamp for this model number is XL-5100
Before ordering the lamp, I would inspect the inside of the TV, be certain that the three fans are clean and free from dust. Often if a fan does not start the first time it may start on a restart. Due to the nature of televisions operating, dust seems drawn to these TV's. Cleaning the fans might correct your issue.
Oct 12, 2017 | Sony KDS-R60XBR1 60" Projection HDTV
COMPAQ SG3000 The PC is making a very loud whirring sound. I have googled this and it appears that it may be the hard drive or the fan. I have taken the back off the pc and it is full with dust!!!! Also.....
First of all use a vacuum and a soft brush to take away all the dust from the inside. Take care not to remove any connections. After this use a blowgun (if available) to clean the dust from difficult places. The power supply and the CPU blower tend to have more dust that you can imagine. Alternative you can use air under pressure but you have to wait some minutes after the cleaning for the humidity to calm, otherwise you may destroy the pc. Start up the pc and check for results.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jun 10, 2011 | Computers & Internet
Roomba appears to be working fine, goes over the whole house with no trouble, but then house is still dirty and no dirt is in his dirt bin.
if there is dust in the filter and none in dirt bin check to see if brushes are turning, you can do this by running the roomba with bin out, if not turning clean thoroughly, remove yellow tips on ends to check for trapped hair, replace brushes and turn them manually in one direction a few times and then run roomba again, you may need to do this a couple of times
Sep 08, 2010 | iRobot Roomba 560 Robotic Vacuum
Laptop shuts down
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give your computer a "blow-job", to remove the dust, because the dust is acting as a layer of insulation, trapping heat inside your computer.
Reload the battery.
Connect the AC power.
Start your laptop, and check that the fans inside the notebook computer are pushing air out of the exhaust-vents. If not, the fan(s) have failed, and you need a professional computer technician to disassemble your computer, and fix the fans.
Jul 16, 2010 | Acer Aspire 5535-5050 Notebook
Roomba does not fill upper tray.
brushes are not turning, you can see this if you remove dust bin and start the roomba, remove brushes clean thoroughly removing yellow end pieces as well to remove trapped hair, re inbstall brushes and turn manually about 20 turns and re try cleaning, try this a couple of times
Jul 06, 2010 | iRobot Roomba 530 Robotic Vacuum
Hair in filter cleaned the filter out ran it again and more hair and dust
Sounds like hair is trapped in the machine.
Start with checking all the inspection valves, take off the sole plate and check to see if the brush bar compartment is not blocked.
Sep 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
A/c turns on for 10 minutes
If it was start up capacitors, it wouldn't start initially every time. Do me/you, a favor, and remove your filter inside (return air) , and if it's a ducted system, remove entire plastic cover inside. Take a flashlight & look way up where filter covers in hole & take a good look at cooling fins on evaporator (front of AC). Look for restrictions such as dust etc. That dust will turn just like mud on there due to condensation mixing with dust, and block off flow which could cause unit to freeze up & compressor to kick out. If your real ambitious, and find lots of dust there, taking cover off roof unit would be next, and check same there at back end (condenser) coils & cooling fins.Get back to me after inspection from inside. Could still be electrical but lets check that it has proper maintenance & best chance to work properly by doing this first.
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Fan
I would advise taking the fan cover off and the blade off of the motor and cleaning it. (Make sure its unplugged when you do this.) Maybe hair and dust has gathered around the motor and the blade. This would make the motor have to work harder, especially if stuff is wound around the motor. Good Luck.
Apr 16, 2008 | Dryers
Honeywell HT-800 Table Fan Logo
619 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ray gallant
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
