Question about Whirlpool GEW9250 Electric Dryer
Sensor stays on preventing the dryer to start
Getting power and can set the settings, but thge riught hand panel indicated it is sensing all the time- any ideas
  • zipperhead44 Apr 10, 2008
    I cleaned the sensor and now it is reading "wet" but still will not start.
  • 101 Answers
Replace the sensor.
Posted on Apr 22, 2008
My Kenmore elite dryer mod 110 62932100 won't stay running.
Some dryers have a moisture sensing strip in the drum area of the dryer. If this sensor gets coated with an insulator, like silicon from the backing on carpets, it does not sense moisture. When this happens, the dryer times out and shuts down. This prevents the dryer from running even after the clothes are dry.
Dec 19, 2015 | Kenmore Dryers
My dryer ran through the dryer cycle turned off. Hours later I noticed the "control locked" light is on and the dryer will not even light up to set program.
Hello. I really need the make/model number to help you accurately. However, depending on the model dryer you have, look on the control panel for a button or buttons that have a "key" symbol or the word "lock" underneath. Normally, you would hold the button down for 3-5 seconds until the lock light goes out. This is the indication that the control panel is unlocked and normal operation can be initiated. The manufacturers put a panel-lock feature on the units to prevent "busy little hands" or others from changing settings, for unattended safety, etc. Dishwashers, ovens, ranges, and other appliances also have locks for the control panel. If your dryer initiated a control lock by itself, this would indicate a shorted button on the control panel--soft touch buttons and glass touch-control panels are notorious for doing this. If I have the model number, I can usually provide the part number and/or procedure for getting into diagnostic mode to see any stored error codes(if any) which would help pinpoint a problem. I hope I helped you!
Oct 03, 2015 | Dryers
Gas dryer does not dry in "timed Dry" setting
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
My kenmore 600 dryer auto moisture sensing not working. Is this is easy fix? If so where is the sensor?
That sensor will be somewhere along the exit duct work, Open up the back of the machine to find it, first clean out the duct work and the sensor might just be plugged with lint.
Dec 21, 2014 | Kenmore 600 6962 Dryer
Dryer won't start cycle, stays on sensing
It sounds like the pullies (drum guides ) need attention the motor is having trouble rotating cause of pressure of not being balanced ,
May 13, 2014 | Maytag MED6400TQ Electric Dryer
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Why does my dryer end its cycle early?
depending on what type of model. there is a moisture sensor inside the dryer. when you use any cycle other than time dry. if it is a small load ( 2 -3 shirts) it may not touch that cycle. making the machine think that things inside are dry and cut the time short. you can try time dryer and see if that helps. to check if moisture sensor on you dryer is working some models will have a test mode to make sure its sensing. try pressing more time button, then less time button back and fourth. all lights should come on. then you can open door. and when put your hand across the moisture sensor usually near the lint trap. you should hear a beep. to indicate that its reading moisture, meaning good..
Sep 19, 2017 | LG DLG5988 Gas Dryer
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
My 400 series Kenmore dryer's timer is not working
if the timer will not advance through the cycles and the dryer is getting hot try the timed setting not the sensed setting and if the problem continues on the sensed side only it is not the timer it is the sensor , the sensor is what senses the temperature inside the dryer that is what advances the timer on the sensed side it could be that the timer could be good and the sensor be bad try that
Apr 03, 2010 | Kenmore 400 6943 Dryer
Need the manual to understand operation, problems with drying
84052/94052 is the stock number and 417.94052500 is the actual model number
How long did you let it run on sensor? Some models may need to sense for a while before they decide to start heating.
The knob can be turned either way
Manual: http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502104.pdf
Sep 02, 2009 | Kenmore Dryers
Whirlpool GEW9250 Electric Dryer Logo
144 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
