Question about Car Audio & Video
Phillips car radio
Hiya experts
enterered the code for the radio, which it would'nt accept, now it just displays the word codewith no option to enter. any ideas please
kind regards
jason
  • 323 Answers
Have you tried disconnecting the battery?
Posted on Apr 03, 2008
Entering radio code into p38
When the fourth digit of the code is correctly entered the radio unlocks automatically. There is no "enter" step. If the code remains on the screen then you are entering the wrong code.
Feb 27, 2014 | Land Rover Range Rover Cars & Trucks
1997 BMW 318 convertible radio problems
Remove battery cable for 2 minutes.Then try again...Good Luck!!!!!
Aug 05, 2008 | 2006 BMW 3 Series
Tip
How to Enter a Renault Radio Code
This tip deals with instructions on how to enter the security code in your Renault car radio and assumes that you already have the correct code for your radio. It also describes what to do if your radio will not accept a code after too many incorrect entries and appears to be locked.<br /><br />
If you happen need a code for your Renault Radio I can also recommend this site which is cheap, fast and accurate and will email or text the code directly to you.
1) You must have 0000 showing on the display before the radio will accept the code.<br /> <br />If CODE or ERROR is on the display you must leave the radio switched on with the key turned to the first point in the ignition that activates the radio until the display changes to 0000.<br /> <br />This can take over an hour depending on how many wrong code entries have been made. It is very important to leave the key in the ignition turned to the accessories on position and the power must not be interrupted or the wait period will be reset and start all over again.<br /> <br />2) When you get 0000 on the display, use the steering stalk and <b><u>not</u></b> the radio to enter the code. Turn the thumbwheel on the stalk until the number changes on the display. Accept each number by pressing the satellite button on the bottom of the stalk before moving on to the next one.<br /> <br />3) When all four numbers are entered on the display you must press and hold the button on bottom of the stalk until you hear a confirmation beep. This may take up to 10 seconds.<br /><br />4) Enjoy your sounds!<br /> <br />Hope this tip helps. Please do leave a vote for it and thanks for using FixYa.<br />
on Nov 17, 2010 | Car Audio & Video
Radio code
  • The 4-digit code for your radio is listed on the two radio security cards supplied with the vehicle.
  • Enter the code by using the pre-set buttons numbered 1 to 6 and a "beep sound" occurs.
  • If the code is not properly entered, then begin the code entry again, starting with the first digit. If the code is not properly entered in three successive attempts the radio will not accept any entry until the radio has been left on for one hour (the radio display will show the word 'WAIT'). After one hour in the 'on' position the radio will accept three additional entries.
Note: Should you lose your radio security cards, contact your Jaguar Dealer, who for security reasons will require proof of vehicle ownership.
I hope this info helps!
~subyguru~
Mar 31, 2012 | 2000 Jaguar S-Type
Cant get the word code off my radio in car so i can put the code in
This happens when you have made several incorrect code entries and the radio will make you wait for a longer period each time a wrong entry is made before you can enter another code.
The resolution is as follows;
2) When you get 0000 on the display, use the steering stalk and not the radio to enter the code. Turn the thumbwheel until the number changes on the display. Accept each one by pressing the satellite button on the bottom of the stalk.
Please leave a vote for the solution if it helps. Thanks.
Sep 04, 2010 | Sony Ninco 50368 Renault Clio Super1600...
I have the unlock code for my phillips cr600 car radio and cd changer but dont know how to enter the code can any one help please
CCR 600 Code Entry
Press and hold the [ AS ] key and switch on.
'SAFE' will display followed by '10 - - - - '
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ AS ] key to accept
Jul 10, 2010 | Philips Car Audio & Video
How do I enter the radio code for 1993 volvo 850
To enter the codeAfter installation or when the set has been disconnected from power, the set displays "codE" when it is switched on.
Enter the 4-digit code using the preset buttons. If the correct code is entered, "on" is displayed and the
set is ready to use.
If you enter an incorrect code you must enter the correct code again from the beginning.
Incorrect code
If an incorrect code has been entered "rPt" is displayed. Enter the correct code.
After three unsuccessful coding attempts the set will lock and remain locked for two hours.
"OFF" is displayed.
After two hours have elapsed, re-enter the correct code.
NOTE: During the two hours waiting period, the set must be connected and turned on.
May 11, 2009 | 1996 Volvo 850
Radio displays EEEE, wont accept code
Did you enter the code in the proper sequence? I reprogrammed mine and it took quite awhile to reset. The manual will tell you how long it takes. It works fine now. Hope this helps.
May 10, 2009 | 1992 Volvo 740
Resetting Radio with WAIT on an 01' Ml 320
hi,,you can not enter your code while wait is on,try to put your ignition on one position,wait maybe 3 to 6 hours to disappear the wait on display,then try to enter the code with guidance of manual,ty
Apr 03, 2009 | 2007 Mercedes-Benz ML320 CDI
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
