Question about Hunter 27185 Remote Control
Hunter remote Model 27185. Light bulb blew out today, replaced with new bulb (twice) and now the light will not operate with remote. The fan portion works fine. Turns off and on fine with main wall switch.Any ideas?
  • 5 more comments
  • Anonymous Apr 08, 2008
    same
  • Anonymous Apr 12, 2008
    light want come on after changing. what the trick?
  • jups_1 Aug 23, 2008
    I replaced light bulbs on fan. Now the light will not turn off by remote. It will turn off by wall switch. The fan does operate with the remote though. The remote came with fan so there are no chains. Ideas?
  • rwk0127 Oct 26, 2008
    I had to replace 2 of the 4 lighbulbs. After replacing the bulbs, the remote failed to work for the lights. The remote works fine for the fan. I can shut the entire unit down at the light switch. Any help would be greatly appreciated.
  • davepross Dec 03, 2008
    The remote will not turn the light on or off - I pull the chain and the light will go on then if I hit the remote the light will dim, hit it again and it is bright, if I hold the remote button down the light will dim then go bright again.
  • Anonymous Mar 22, 2014
    NEED BLADE IRON. HUNTER FAN DOESN'T HAVE ANY MORE
  • Anonymous Mar 30, 2014
    remote lights but no longer turns on fan or light
There is no fused protection in the receiver -- I just had the same problem.  When replacing a bulb, somehow the bulb arced in the socket on the fan and blew out the unit.  Time to replace the unit.  I may put an inline fuse this time for protection.
Posted on Mar 14, 2009
  • 3 Answers
Make sure the light is switched ON at the fan...pull the chain a couple times and see if it make a difference.
Posted on Jul 31, 2008
Light comes on by it's self after turning it off with the remote
Posted on Jun 13, 2011
I have a Hunter Ceiling Fan Model No. 27185. I can control the fan with the remote but can not control the lights with the remote. is there some instructions on how to operate the system?
27185 is the model # of the remote. Check to make sure your light wires are connected at the light fixture & receiver. Also, make sure your dip settings are set on the same frequency. Lastly, push the light button & pull the chain on the light.
Oct 06, 2013 | Hunter Dryers
Hunter fan 27185 has lost speed
Remote controlled ceiling fans can suffer a lapse of memory when there is a power outage. You eliminated the possibility of a dead battery in the remote by installing a new battery, but just to be sure remove the new battery and press all the buttons on the remote to eliminate the possibility of a stuck button then reinstall the battery. Next disconnect power to the fan at the breaker box, not a wall switch or by tugging on a chain. Turn the fan power on again. Using only the remote, check operation.
Apr 20, 2013 | Hunter Dryers
I have a hunter ceiling fan and the light blew, when it blew then the remote quit working for the light, it still turns the fan on & off but after I replaced the bulb it still will not operate the...
Hello nita... I believe the fact that the remote stopped working is due to a weak battery in the remote. Change that battery and you should be back up and running. Joe
Thanks for choosing Fixya!
Jan 14, 2011 | Hunter 20537 / 20538 The Vista Iron...
I have a Hunter fan with remote and the light flickers without coming on completely - and you can hear a clicking noise coming from the fan. The fan works and the bulbs and batteries were changed
The pins inside the remote could have been switched or the wiring inside the fan could have come loose. Check the wiring at the fan first. The vibrations of the fan could have worked the light conrol wire loose.
Oct 10, 2010 | Hunter 27185 Remote Control
Hello, I have to install a Hunter universal remote receiver, Model 27185 toa Hampton Bay ceiling fan w. light, Model 468-282 today. The receiver has 5 wires, red to light, black to fan, a live black to...
Red from receiver to blue light feed. Black from receiver to black feed to fan. White common from receiver to ground.(bare copper)
Black from receiver (hot) live in, to black from household wiring switch. Common in from receiver to neutral (white ) from house (switch.)
Sep 26, 2010 | Hunter Ceiling Fan Remote Receiver...
I have a ceiling light that does not have a switch anywhere. Can a hunter 27185 remote control be used to control the ceiling light fixture only. There is no fan in this scenario. How should it be wired?...
Connect the lamp output wire of the receiver to the hot wire of the fixture, and the incoming hot wire to the hot input of the receiver. Be sure to insulate the fan output wire(s) so nothing nasty happens if someone presses the fan on button.
Check the remote control manual to see if you can use compact fluorescent bulbs. You probably cannot if this is a dimming lamp control; most CF bulbs flicker wildly if used with dimmers, and will not last long.
You can also buy remote lamp-only switches.
Sep 22, 2010 | Hunter 27185 Remote Control
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Remote model 27185
make sure that you wire BOTH the black and black & white striped wires together to the supply, or the light won't work.
May 21, 2008 | Hunter 27185 Remote Control
Televison & Video Logo
1,158 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
