Heating & Cooling Logo
A
Anonymous Posted on May 19, 2010
How many tons is the condensing unit serial # 10AJB36A01
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on May 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
2148
Points
21
3 tons. 12,000 btu per ton divide 36 into 12 = 3 tons
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
2helpful
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
1helpful
2answers
Need Minimum Circuit Ampacity and the Maximum Fuse Breaker for the Condenser - Thak you
Serial numbers don't tell much.
Model. numbers describe the unit best an 18 in the model is for 1 1/2 ton,24=2 ton, 30 =21/2 ton 36=3ton etc
2 ton unit
6719f81e-d5d1-47c4-b80f-e11712a6cac5.pngNo oversizing the condenser will not work well, however oversizing the evaporator coil by 1/2 a ton actually increases the units efficiency and is recommended to do by most utilities on units they finance.
1helpful
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
1helpful
What size is my weatherking unit model 10ajb36a01
It is a 3 ton, 10 seer unit. Size is basically good for 1200 sq. ft. Hope this helps!
Whats the tonnage on model 10AJB36A01
This is a 3 ton unit. I got that from the 36 in the model this means 36,000 BTU'S. If this helps please rate me and do a testimonial.
1helpful
I HAVE A HEIL 5000 A/C CONDENSING UNIT.\r\nCAN YOU TELL ME WHAT SIZE IT IS (TON)? MODEL # CA5560 VKD2 STYLE # 60MCE-000095ZR SERIAL # L9811 50209MANF # NCA5560 VKD2 I APPRECIATE YOUR HELP. THANK YOU VERY...
It looks like you have a 60,000 BTU unit or a 5 ton unit...12,000 BTU/ton is how you figure that...
The 60 in the model number indicates the nominal btu's of the unit... the exact output could be a bit more or less depending on the air handler...
heatman101
Need help selling a Carrier 4-ton 10SEER unit!
Yes you can sell this unit. You would have better luck posting on ebay or craigslist.
Top Heating & Cooling Experts
Paul Carew
john h
