Question about Kitchen Ranges
I have a frigidaire glass top range. It has an expandable burner on the left front. All of a sudden the expandable part lights up and heats but not the center part. Can these this be repaired ?
  • 52 Answers
Yes, it is likely either the switch that controls the burner, or the burner itself. These are usually pretty pricey. If you want the part numbers, post your model/serial numbers and I'll try and get them for you.
Posted on Apr 04, 2008
SOURCE:
The front left range element on our frigidaire electric range es300 does not appear to be heating at all. The unit's "Element On" light turns on, but the element itself does not come on. Eve
Good afternoon friend, thanks for your inquiry!
Based off the information you have provided me regarding your Frigidaire range element not working I am able to identify some possibilities with your range. It could be an issue with your burner switch or burner element. It would be best to have a professional come out and properly diagnosis your appliance to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Oct 05, 2014 | Frigidaire FEF368GM Free-Standing 30-Inch...
Replacing burner on slide in FES365ECA frigidaire stove
Good Afternoon Friend,
I understand you are trying to get assistance on how to access the burners on your glass-top Frigidaire range, model# FES365ECA. I suggest contacting the manufacturer. They might have some type of diagram that will assist you in replacing the burner. My other suggestion would be to contact your local authorized technician for further assistance. The technicians have been trained to replace parts on your range. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire Kitchen Ranges
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
Frigidaire model FEC30S6ABF front burner wont turn off
Hi - From what you have described the range could possibly be experiencing a faulty element/sensor or the communication to the element from the control board is now compromised. If you are referring to the left front element, the part number is 318178110/MSRP: $65.86. Right front element, part number 316224201/MSRP: $89.60. I would suggest contacting a professional to move forward accurately and properly diagnose the range.
Oct 18, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Dual element left front
call a repair service locally possibly he got the wrong element
Jan 20, 2018 | Kitchen Ranges
Stove top want heat up
the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My front left burner on elec.range model FEFL67GCA does not work.
If it's just quit all of a sudden then I assume it's burned out.You will have to remove the glass top to get to it. The new burner has two wire connectors that plug in. CAUTION: Make sure you disconnect electrcal power to the stove before working on this!
Apr 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Kitchen Ranges Logo
76 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
