Question about Panasonic KX-TG5632 Phone
KX-TG4500B I have a KX-TG4500B. It is a 4 line system. I have only been using the first two lines. All of a sudden line 2 says it is busy even when all of the hand sets are off. When I try to change the input wire to utilize lines 3&4, the message light will not turn on and only the default message can be heard instead of my recorded message and music on hold. I have unplugged, but not "unbatteried" so that I don't lose all my saved #'s. HELP!!!
    Novelist:
  • 201 Answers
The only way to loose your saved numbers is to delete them or initialize the system. Removing the power, battery and hitting the reset button will not delete your settings messages or phonebook.
Go ahead and remove the battery, power and try the reset feature it just may solve your issue with this unit.
Posted on Apr 20, 2009
SOURCE:
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Every extention on the console is showing with the red led light, as if the lines are busy. Therefore I cannot transfer calls, when in actual fact, the lines are not busy
    ouch, sounds bad...
    possibilities~
    1) everyone has DND turned on if so have them disable their call forwarding entirely (intercom*7100)
    2) your buttons are all suddenly programmed wrong, reprogram them to the correct extensions
    (press "PROG" then the button you want to program, press " 1 " then the extension number, then enter)
    3) major error with the system, have a serviceman come out and take a look
    Jan 04, 2011 | Panasonic KX-T7630 Corded Phone
    I have attached this cordless to KX-TA824 supporting 2 incoming lines. How can I select which line (CO 1 or CO 2) to call from?
    If you start with intercom dial tone, press 81 or 82. If you dial 9 you'll get line 2 before line 1 in normal programming, and if you dial a line that's busy with 8x access codes, you'll get a busy, even if the other line is free.
    Of course, you could also RTFM and program the system to function with your TA-824 http://public.carl.airpost.net/Pana/TA-824/UG_TA_0823%5B1%5D.pdf
    Starting on page 15 or so of the pdf, after you set up the keys, you'd press the > and 1 or 2 to get to lines 1 or 2 :-)
    Carl
    Oct 08, 2010 | Panasonic KX-TD7896 Cordless Phone
    KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
    From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
    3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
    4. Press AUTO DIAL / STORE to save your changes.
    5. Press PROGRAM to exit program mode and you are done.
    Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
    On the Panasonic KX-TDA 50 we are using, there is no dial tone all of a sudden on line 1. It has been working fine thus far. No setup or wiring has been touched by anyone. How do i fix this problem?
    Simple enough. On the cabinet, there are at least 8 modular jacks. One is marked LCOT 1-4 and the other is marked DHLC 1-4. Swap the moduler plugs for LCOT 1 and 2. If the No Dial Tone moves to line 2, it's a telco issue (most likely). If it stays on line 1, it's a system issue.
    I'm betting on the former.
    Carl
    Sep 11, 2009 | Panasonic KX-TDA50 Phone
    Hi, i purchased Panasonic KX TG4500B base unit and one hand set, 3 lines connected to the base unit, i will use only the base unit, but when there is a missed call, i can't see that which line is missed...
    In the window, you should see the Name, Number of Caller, and at the bottom, it should say which line number, ie. line 1, line 2, or line 3, it will not say which number the call is on. If you need the user manual, you can find it here: http://service.us.panasonic.com/OPERMANPDF/KXTG4500B.PDF
    Aug 26, 2009 | Panasonic Lands Phones
    Setting up voicemail for base unit and handsets
    Download a pdf instruction manual from panasonic.com od pdf on internet ....
    Jun 11, 2017 | Panasonic KX-TG4500B Phone
    My phone wont jump to the next line
    that is up to your telephone service provider. call them and info them off the problem. tell them that you want a busy forward only to line 2. that way after 4 rings it will jump to line 2.
    Feb 19, 2009 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-TG5632 Phone Logo
    196 people viewed this question
    Top Panasonic Lands Phones Experts
    Ekse
    martin hogg
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
