Question about Frigidaire FDE336RE Dryer
Frigidaire dryer timer wires
I purchased a replacement timer #131062300F, some of the wires that connect to the timer are not clearly marked, so I am having trouble connecting the wires. Do you have any type of diagram that would help
  • 770 Answers
I need your model number to look up the wires
Posted on Apr 05, 2008
Old whirlpool thin/twin Dryer timer old timer M404-G New timer M460-G how to hook up
The problem as stated is that the new M460-G timer does not have the same pins as the old one (because there seem to be a variety of sub-models under the M460-G name). However, I have successfully (at least to provide the timed heat function) used a different M460-G on my Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, I had to figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also by inspection of a wiring diagram at appliance pros dot com
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
c / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)48146720-bbc3-47da-833c-6d50a0cf5df0.jpg
Sep 06, 2015 | Whirlpool Dryers
My Frigidaire dryer does not work. It seems like it does not register that the timer is being turned back. It is the Gallery Series, Model GCET1031FS2.
Thank you for your inquiry, Ashley!
From what you have described your Frigidaire dryer is not working and it seems that the timer is not registering. This sounds like you may need to replace your timer or you could have a faulty wiring harness. In order to accurately diagnose your dryer I would recommend having a professional technician out. They will be able to properly disassemble your dryer and test each electrical component. This will help you avoid any unnecessary part purchases. Best of luck! -Matt
May 28, 2015 | Frigidaire Dryers
Need to replace my dryer timer M460-G
The problem is that the new M460-G timer does not have the same terminal letters as the old one (because there seem to be a variety of sub-models under the M460-G name providing varying options such as an "air dry" function). However, I've at least been able to provide the basic timed heat function using a different M460-G on my old Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also inspect wiring diagram (mine was at appliance pros dot com).
A / Gas / Org
C / Motor / Wh
BK / Motor / Wh
R / Gas / Org
OR / ? / Pink (figured it was safe)6b1460b2-ed5e-4c5d-b06b-c654e59e7487.jpg
Nov 19, 2013 | Whirlpool Dryers
The dryer buzzer keeps going off even when dryer is off
When the dryer stops can you advance the timer a little to turn off buzzer? Or when you open the door does the buzzer stop? I was trying to find a schematic for that model but I have had no luck. Power should come from the timer to the buzzer. If you know how to read a schematic. Unplug the unit and remove the back to the control panel. Check to make sure that all the wires to the timer are on the right connections. You may need an appliance repair service from your area to come out and diagnose it for you.
Apr 02, 2013 | Frigidaire Westinghouse Electrolux...
Timer dial will not rotate automatically.
The timer (part number 8566184) is motor driven and can actually be heard buzzes or hums when it works. The symptom clearly indicates a stuck timer motor. Remove the control panel rear cover then check to make sure the timer motor wires are connected and that the connections are snug fit. Reseat the connections several times to clean off dirt and corrosion build up in the terminals and connectors. Replace the timer should there be no issue found with the connections and the timer still does not work.
Unscrew the faulty timer from the console bracket then secure the new timer in place. Disconnect the wires from the faulty timer terminals one at a time then connect it to the corresponding terminals of the new timer. This is to prevent messing up the wires upon connecting it to the new timer. Reinstall the console rear cover then its done.
May 27, 2010 | Whirlpool WED5800S Electric Dryer
Frigidaire Dryer Timer Replacement question
Take the broken parts to your hardware store, they have all the parts to make you a substitute.
Good Luck
Quentin
Jul 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer has power but won't start
hiThe dryer timer, located in back of the control panel, controls several things: the drying time of the clothes in the drum, the flow of electricity to the heating element, and the flow of power to the timer motor and the drum motor in the dryer cabinet.
Timers are driven by synchronous motors. Although the contact part of the timer can be cleaned and adjusted on some dryers, this is a job for a professional repair person. Timer motor repairs should also be handled by a professional, but you can replace a faulty timer yourself. Here's how to test and replace a dryer timer:
Step 1: To access the timer, remove the front of the control panel. On some dryers, the timer can be removed without removing the panel. In either case, pull the timer knob off the shaft and slip off the pointer. The pointer is usually keyed to the shaft by two flat surfaces to keep the pointer from slipping when it's turned.
Step 2: Test the timer with a VOM set to the RX1 scale. Turn the timer to the NORMAL DRY setting and disconnect one of the timer power leads. Some timers may have several wires connected to them: The power leads are usually larger than the other wires, and this size difference can be spotted under close examination. Clip one probe of the meter to each timer terminal. If the meter reads zero, the timer is working. If the needle jumps to a high reading, the timer is faulty and should be replaced. Replace the timer with a new one of the same size and type.
Step 3: To replace the timer, have a helper hold the new timer close to the old one, especially if there are several wires to be changed. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram detailing the proper connections. After all the wires are connected, check the connections again for accuracy.
Sep 13, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
340 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
