Question about Lexmark X2470 All-In-One InkJet Printer
Printer My printer will not load the paper to print how can I fix this problem
  • myragdollcat Apr 03, 2008
    Thank you I will give that a try.
  • Anonymous Apr 08, 2008
    The paper will only feed so far and then it jams on the right hand side.
    Guru:
  • 1,463 Answers
Have you checked that the printer has no paper bits jammed inside of the printer thats stopping it from loading paper.
or you uninstall it and reinstall see if that helps.
riz.
Posted on Apr 03, 2008
SOURCE:
Single paper sheet not printed, multiple yes
Try few steps as given below...
1. poor quality printer may reduce printer quality & causes paper jams and other printer problems. If you encounter problem , switch to a higher grade of printer.
2. Do not load curled and paper folder.
I hope, it helps.
Feel free to get instant printer help at http://www.vtechsquad.com/printer-support/ to fix any printer issues.
Jan 21, 2013 | Epson Stylus Photo R800 InkJet Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
I have a Dell 3000cn printer it is saying load paper but the paper is loaded but wont print
check whether the cartage is fix well or the paper is far from the area from where the printer starts printing.
Jan 27, 2011 | Dell 3000cn Laser Printer
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Regards,
polysandy
Apr 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Epson Stylus CX6000 Won't Load Paper.
hmmm am afriad if u had a warrant for it just take it back to them and get a new one...plastic staffs are hard to fix.
Nov 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
HP Photosmart C7280 All in One Printer. I am trying to print on new check paper, but it just keeps running it through and then prints on the regular white paper. Any quick fixes?
Check the preferences setting in your Printer Dialogue box (the pop-up that comes up when you attempt to print... the paper settings may be set to standard, which you can modify...
A quick-fix is also to simply print to plain paper, place the newly-printed form in the scanner, and press "copy" on the printer itself (the physical button, not from Windows), with the check paper loaded (place in just one sheet, as not to waste ink)
Hope this helps!
-- RT
Sep 03, 2009 | HP Photosmart C7280 Laser Printer
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Lexmark X2470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
