Question about Polaroid CAA-03040S Camcorder
Screen shuts off
I just got this new camera and after we plugged it into the tv the flip screen no longer works. when i turn it on the screen briefly comes on then flickers and shuts off.. does anybody know why it's doing this??
  • Allisonrhone Apr 14, 2008
    i'm having the same issue! someone help...
It's supposed to shut off to conserve battery life. The camera will display on the tv screen instead. Make sure your tv is on the right channel for external source (ex/ video front).
Posted on May 10, 2008
SOURCE:
When I press the power button on my ultra hd 2nd generation camcorder, the screen lights up with the flip logo and verbage that says hold the record button for setup. It also makes the correct sound for...
Will the camcorder let you go ahead and complete "SETUP"?? if so, go ahead and redo the setup maybe some glich and maybe doing setup again may get the camera going again? hope so!! I have one also and knock on wood, no problems so far. it may be worth a try:
when camcorder turns on: when Flip Video Logo comes up press and hold RECORD button, to enter setup mode use the + and - to adjust current setting and the left and right arrows to select other settings
good luck!
Apr 25, 2011 | Pure Digital Flip Video Ultra Camcorder
Flip Ultra - freezes at initial Flip screen - will not shut off
I found a fix that worked for mine.
It was doing the same thing, freezing at the "Flip" screen and would not turn off. I did the remove the batteries deal. It worked once but issue reoccured 2 months later and the battery fix didn't fix it.
What did fix it was...
With the camera off, hold down the Right Arrow button and the trash can button at the same time and turn the camera on.
A few seconds later, I was at the start recording screen!!
Good Luck!
Jul 21, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
How do you fix a frozen flip video ultra?
I fixed mine! When I turned it on it only had the flip logo on the screen & it would only shut off if I took the batteries out. I tried everything - holding the on switch for 30 sec, holding the record button & the on switch for 30 sec, deleting every bit of data from the camera, reinstalling the software onto the camera, leaving the batteries out for a month... I took it apart & found a burnt spot on the motherboard. I scraped it with a pocket knife, put it back together & now it works like new!
Jun 23, 2009 | Pure Digital Flip Video Ultra Camcorder
Camera Turns off when Display is rotated then closed
ur strip line is broken dont use ur screen with more rotation
Jun 18, 2009 | Canon PowerShot SX10 IS Digital Camera
Flip video won't charge
If you look on the bottom of the camera there is a button that slides from a locked to an unlocked position. Slide it to unlocked and then slide down the back of the camera (the side with the lens) there is a removeable rechargeable battery pack. Remove it for a moment and then put it back in. Try plugging back into the USB port. This should work.
Jan 09, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Camera Video Screen is white
buy a new one take the screen out of the new one and then swap screens take it back to walmart tell them it doesnt work and get your money back.
i would just say swap cameras but im sure theres serial numbers in these
Oct 07, 2008 | Pure Digital Flip Video Ultra Camcorder
Vtech kidizoom camera
We had the same issue. After turning on, nothing on the view screen and the buttons didn't work. The camera could turn on, the turn on screen and sound happened and we cold turn off (show off screen and sound)...even after changing batteries. It was like that for a week.
I found it had to do with TV connector slot. Thinking back, my daughter had been playing with the TV connector right before it stopped working. I took a small hair pin and put it in the TV connector slot, lightly wiggled it and the camera sprung back to life. I'm guessing the camera hardware was acting like it was still plugged in...hence turning off the view screen.
Anyways, hope that helps someone.
Jul 25, 2008 | Vtech Kidizoom Digital Camera
57xbr2....tv turns on briefly...solid color screen for a second...then blank?
I had the same problem about a 8 months ago. I searched online and found that there is a problem with one of the color guns. They need to be replaced. I don't remember where I found the information, but there is a number or something to call for this problem. I think that my authorized sony repair man knew of the problem, there are other models that have the same problem. Anyway, sony replaced all three guns in my tv FREE of charge, and my tv was no longer under warranty. They did all repairs and fixed my tv.
Aug 25, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Polaroid CAA-03040S Camcorder Logo
66 people viewed this question
Top Polaroid Video Cameras Experts
Eric Sutherland
Tony Parsons
Tony Parsons
masud
masud
Are you a Polaroid Video Camera Expert? Answer questions, earn points and help others
