Question about Broan-NuTone QT100L Fan
Fan Light The Nu-Tone QT 100L light goes out periodically, usually after it has been on for 5-10 minutes. Suspect it heats up and then shuts off. Any repair suggestions? If I replace it which new model fits the existing housing?
    New Friend:
  • 39 Answers
My unit has 100 watts and it shows no problems. I don't remember any heat sensors in the unit. I am assumig that it does not trip the house circui breaker. It could be a loose light bulb or a socket that needs adjustment. Replace the light bulb and make sure the bulb is tight.
Posted on Dec 31, 2009
Try reducing the wattage of the light bulb.
Posted on Nov 08, 2008
SOURCE:
Lights intermittingly go out?
I would suspect the main headlight switch for having burnt contracts as well as a heat damaged connector to the main light switch. Because you gave no make, model, or year that is about all I can offer.
Jan 07, 2017 | Cars & Trucks
Our bathroom Nu Tone Model QT-100l fan is sounding loud and Rough. Can I purchase the motor part for this? If so will the motor be attached to the metal housing and I should be able to simply replace the...
The replacement motor is available from several sources online. The best way is to purchase the new motor assembly. All you need to do is remove the blower housing from the ceiling, there are three screws that hold the motor assembly in place. The whole job takes about five minutes. Here are a few sites with the motor.
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0 http://www.cshincorporated.com/product_info.php/manufacturers_id/33/products_id/11272
Aug 22, 2011 | Broan-NuTone QT100L Fan
Nu Tone Bath Exhaust Fan - QT-110N-B - motor vibrating
You can buy just the motor assembly. You would remove the grill. Usually there is a plug to disconnect the motor. Remove screw(s) and the motor and fan assembly will come out leaving the rough in housing in the ceiling. I did not locate your model number as you listed it however the QT line has numerous model numbers. Here is a link to the nutone page. You should be able to purchase a "trim kit" which would include the fan,motor,and grill. You can either buy it on-line, or you might try an electrical supply company.
http://www.nutone.com/product-detail.asp?ProductID=11043
Jul 05, 2010 | Home
Two function control switch. Broan nu-tone
Oh Boy! ...Oh Boy! Lol...:) Put the Earth/Ground, (usually green and yellow) wire in the on screw side.
Then, get the Fan's black wire, and connect with the Light's white wire,...then put it in the any one of the Screws, (usually a hole where you put a wire through and screw down to hold. Golden ~ like in color).
Then, get the other Fan's white wire, and connect with the Light's black wire, then put in the other Screw hole. :)
And Whala :)
Mar 28, 2010 | Broan-NuTone FAN CONTROL SWITCH
Nu tone model QT-100N-B. looking for a replacement. Were can I buy 2 of them in sacramento, ca?
There is no replacement fan for that model that will fit in the existing housing. You can buy the replacement motor assembly.
You can buy these online and have them shipped to you:
or
http://www.centralvacuumstores.com/search/search.php?keywords=qt110&x=47&y=15&asug=
or
http://www.partstore.com/Part/Broan-Nutone%20Group/Broan/0696B000.aspx?s=froogle
Jan 07, 2010 | Broan-NuTone QT100L Fan
Exahaust fan not working
The best thing to do is buy the replacement motor. It is usually a pretty simple thing to change out and it sure beats having to take down the whole thing. Here is an article on finding the right motor. http://nutoneproducts.blogspot.com/2009/05/nutone-bath-fan-motor-replacement.html
Jul 12, 2009 | Broan-NuTone N-667RN Combination Light Fan...
Where can i get a replacement motor for a qt100l BATH FAN?
Go to the link below and you can order replacement parts for the QT 100L
http://parts.broan-nutone.com/nutone/Shop?DSP=30115&PCR=1:21000&IID=QT100L
Nov 08, 2008 | Broan-NuTone QT100L Fan
My microwave heats but shuts off due to the fan not coming on
A little late for a reply; you probably have replaced it by now.
I suspect it shuts down because the fan is no longer turning on and there is probably a thermal shutoff switch near or on the magnetron to prevent the chance of fire.
Jan 08, 2008 | GE JVM1190 Microwave Oven
QT 100L replacement
Don't worry, you can purchase just the fan from amazon (not entire motor). here: NuTone 0696B000 Motor Assembly for QT100 and QT110 Series Fans. I hope this was helpful. cheers
Oct 12, 2007 | Broan-NuTone QT100L Fan
Broan-NuTone QT100L Fan Logo
269 people viewed this question
Top Broan-NuTone Dryers Experts
Steve Allison
Steve Allison
wavesfix
Level 1 Expert
rcarmean
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
