Question about Cyberhome CH-DVD 300 DVD Player
Bad disc, lens cleaner doesn't work
I tried to use a lens cleaner, but that came up "bad disc" as well.
  • 149 Answers
Even tho it came up as a bad disk the brushes would have cleaned your lens as it tried to play the disc. If theres no improvement after using the cleaner you may need to take the unit to an engineer. Is it reporting every disk as bad or just a few??
Posted on Apr 04, 2008
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
Hts3555 will not read disc
Hi
Is it all discs or just one?
Try several discs and see what happens.
If its all discs,try cleaning the lens using DVD lens cleaners.If this doesn't solve the problem,have the lens replaced or if the machine's still on warrant,have its owning company do it for you.
Hope it helps.
Feb 20, 2012 | Televison & Video
SL/DV280 DVD/CD PLAYER PROBLEMS TRACKING IS OUT BUT SOUND IS FINE. When I play CDs its fine but DVDs are skipping making it impossible to watch a film, is there anything I can do to resolve this probl
First check the disc doesn't have dirt, finger prints or is very badly scratched. If it happens on all discs you will need a lens cleaner disc. If that doesn't work then it could be damage to the lens or a fault on the unit.
Dec 10, 2011 | Audio Players & Recorders
Ps3 slim error code 8001002b what could this code be.
The code means "dirty or damaged disc". The PS3 has encountered some kind of problem reading the disc.
Possibly the laser could be having problems, possibly the disc.
Try another game disc. If it works, the game disc you are trying to start is somehow damaged.
If it doesn't, the laser most likely has a problem.
If the laser is the problem you can try and clean it with a DVD laser lens cleaner like this one :
http://www.walmart.com/ip/Innovera-CD-DVD-Laser-Lens-Cleaner/14915544
Regards
Sep 28, 2011 | Sony Playstation 3 (PS3) Console
I have a Goodmans DAB600 Micro System and its not reaind the disc
how long have you been using this player and when did this begin?
Remove the disc and try another.
If the player still doesn't read disc, then it means the laser is weak.
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Good luck.
Aug 13, 2011 | Goodmans Televison & Video
When I try to use my dvd player I put a disc in it says loading them it comes up and says bad disc, it will also do this if there is no disc inserted into it, can you help me? I don't know the model #...
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Once this us done, your player will play all DVD discs again.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Koss KS4110 DVD Player
DVD player purchased 8/4/10 will not read disc. Model SD7300. Have used the cleaner disc.
Regards.
Apr 14, 2011 | Toshiba Televison & Video
Not reading DVD discs
has it been reading DVD discs before? Also, does it read other discs apart from DVD's?
It is possible that your DVD drive's lens (laser) is weak. You can try to use a lens cleaner or cutton board to clean the lens.
Take care.
Mar 07, 2010 | Acer Aspire One PC Notebook
Every disc is a "Bad Disc".
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 12, 2009 | Recoton Advent Advent DVD-8200 DVD Player
Won't play any DVDs
I mostly first always recommend a dvd lens cleaner to clean the lens incase there is something on the lens.
Is the player underwarranty? the lens may have a issue other than dirt and might need to be replaced.
What happened last time it worked fine? try unpluging the dvd player for 5 minutes and try again.
Jan 04, 2009 | Toshiba SD-6980 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
112 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
