Home | GE | WBVH6240F Front Load Washer | Washer
GE WBVH6240F Front Load Washer
Problem for GE WBVH6240F Front Load Washer
Washer
By warren80 on Apr 03, 2008
I have a GE washer and the model #WBVH6240 and I have replace the rubber seal around the door twice from normal use and I want to know if the seal around the door has a defect in it. And if I can get a replacement for the washer is under a year old.It seem that the seal is very thin to me.Can'nt withstand alot of use
Same Problem
Mar 04, 2009
-   i have the same problem how do you put the seal on-   Guest
Feb 22, 2009
-   this is my second time replaceing gasket very disappointed in quality-   Guest
Jan 30, 2009
-   How hard is the installation of the rubber gasket?
-   rsvernon1
Jan 14, 2009
-   I think it's a combination of the violent vibration during the rinse and spin cycles as well as clothes getting stuck between the drum and gasket. The tear in my machine starts from the door lock push button switch and travels around the top of the gasket and ends at the opposite side (a 180 degree tear). I think replacing this gasket every so 6 months or so may be a lifetime job. -   jklee_55
Aug 31, 2008
-   My door gaket also tore in about 6 months.-   Guest
Popular Solutions for GE WBVH6240F Front Load Washer
Questions and Unsolved Problems for GE WBVH6240F Front Load Washer
Do you recommend GE WBVH6240F Front Load Washer?
Answer
Answer
Water pours out from under the machine at initial fill. I can see it coming from the little valve... (More)
Answer
Once the add garment light goes out it starts emptying the water. then goes to the rinse cycle.
Answer
Hi Do you have any info on model WBVH5200Joww ? control board problem Thanks Angelina...
Answer
older model ge profile front load washer. door lock light is on load did not start?
Answer
We have cleaned out our filter and drained the machine. But when it is in a wash cycle it will not... (More)
7 Other Users Have The Same Problem - Continued
Comment by queenb3, posted on Aug 15, 2008
I have this same front load series, this is also my second time replacing the door seal/gasket. I love my front load but am very dissappointed with the quality of the product. This is the second seal in just over 6 months, can't GE come up with a material that wears better!!!
Comment by Guest, posted on Apr 10, 2008
My washer is 1 months old, I just opened the door after the cycle finished and the door seal had a large tear in it. It was big enough to allow several pieces of clothing to get caught up and twisted in it. I'd say this seal design is lacking a lot, it seems to be a material problem.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE WBVH6240F Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14168
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
