Question about Jensen VM9410 Car DVD Player
Jensen 9410 will not load or eject
Brand new unit out of the box will not load or eject. screen displays "eject" and "loading" and it sounds like there is a motor running. please help! i have the same problem my 9410 will not load or eject...
    Genius:
  • 3,422 Answers
Try Hard reseting your player first by unplugging all the cords for 30min and then plug it back.
I will be posting more solutions...
Posted on Apr 03, 2008
  • 1 more comment
  • Priya darshan Apr 03, 2008
    See if there is a little pin hole in the face plate or bezel of your
    dvd player... stick a paper clip in it and it will release your DVD
    tray and you can get your DVD out.
    Here is the method to eject the disc tray:
    1. Press and hold the power switch.
    2. Unplug the Jensen
    3. Wait a bit (say, 15 seconds)
    4. Plug in the Jensen
    5. Wait for the disk to eject.
    6. Let go of the power switch.
    Does
    the player make squealing noises or is it totally quiet? Squealing
    noises may indicate that the player is trying to synchronize with the
    disc but can't due to an obstruction on the lens or in the laser path
    inside the pickup or a defect in the pickup. This can also be caused by
    an intermittent signal problem due to a faulty ribbon cable.
    Totally
    silent means that the photo sensor is not getting any usable input from
    the laser at all, meaning that the pickup is "blind" for lack of a
    better word.
    This can be caused by an obstruction of the beam by
    foreign matter on the lens or inside the pickup all the way to a
    marginal or failed laser diode and/or photosensor array. This can also
    be caused by a bad ribbon cable with one or more severed traces.
    You
    could try to clean the optics. This is the most common malfunction as
    far as i know in all disc players. It would involve taking the cover
    off and finding a way to expose the lense, and then cleaning it with a
    very gentle brush. some players have a cover for the lense that swings
    to the side during playing, this greatly reduces the chance of dust
    accumulating, but its still worth the try.
    If you actually see dust on the lense, then its just that simple. clean, close, play.
    It may also be worth your while to check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grome, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track. Please refer to the image below.
    Goodluck..
Toshiba REGZA won't play DVD. Shows "disc loading" then goes to wide screen mode, but then ejects the disc. Whats up?
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2014 | Toshiba Regza 32LV67U 32 in. LCD HDTV
CD does not eject from my VM 9410 Car DVD Player
it probably got jammed in there what you can do is unplug the power source and replug it back in a brief power push should eject the disk. make sure you have your unlock codes as the unit may think it got stolen if you undo the power. if that does not work to get it fixed around $89 bucks Thanks and please rate
Aug 18, 2009 | Jensen VM9410 Car DVD Player
Magazine won't eject
HI, the load motor has failed in your changer and , you will have to replace this. its part of the loading dock assembly and it turns all the gears associated with the loading and playing procedures.
If you are hearing continuous clicks, this will be the reason for the failed motor.
May 21, 2009 | Jensen XCH6RF 6-Disc CD Changer
Jensen 2006 7" indash touch screen: CD player wont work
Try a lens cleaner . If that doesn't work then it would have to be repaired.
May 07, 2009 | Jensen MP7610 CD Player
Unit will not play or eject discs
try to repair it agin.
this time i think you have to change only loading belt and optical lence.
are you technicaly sound.
nuwan.
Nov 10, 2008 | Sony DAV-C770 System
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Upside down dvd inserted
FYI - This might damage the unit, but if you really need to get that DVD out then you can try this at your own risk!
Try unpluging the unit, then plug it back in and press the power button and a split second later press the eject button. This all needs to be done quickly otherwise the unit will try to load the disc.
Or
You can try letting the unit load the DVD. When the unit says "Please eject disc. Playback feature may not be avalible on this disc," press the eject button.
Apr 01, 2008 | Emerson EWR20V4 DVD Recorder/VCR
i had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
Mar 20, 2008 | Jensen VM9410 Car DVD Player
Jensen VM9511TS AM/FM/CD/DVD/SD
you may have to open the unit up and manually turn the unload and load gear to eject the DVD from the carriage. The load and unload gear is a round gear located under the DVD carriage and is attached to the load and unload motor
Sep 20, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Wont load or eject
I have the same problem! tuner works just fine. I cant access the dvd mode. i can only access tuner, video input, and rear cam. Ive tried different cds and dvds and it did not help. Also it seems like the ejection mechenism is running continuesly.
Jan 30, 2007 | Jensen VM9410 Car DVD Player
Jensen VM9410 Car DVD Player Logo
300 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
