Rank: Apprentice
Rating: 0%, 0 votes
I got a replacement controller board from RepairClinic.com and it solved the problem. The board is located under the freezer side of the unit. You have to take out an outside panel and unscrew an upside-down nut with, I believe, a 10mm wrench or socket. After that, the front of the tray will drop and you can slide the tray out. The controller board is inside the tray. There are three sets of connectors. You just need to unplug them and put in the new board and reconnect.
I suspect how my unit failed was due to power spike. Since then, I put a surge protector between the unit and the wall outlet. It's been working fine since Sept.
