Question about PNY USB SmartMedia Reader PC (SFRUSBWB)
Disk full??? i just today got a 2 gb usb key from pny. after putting 70mb on it it says i have 1.8 gb left. however when i go to save more files on there it wont allow it. it says that there is no more room on the disk!?!? please help. thanks
  • confucius Apr 05, 2008
    eeek. it's a mac today. it will be windows tomorrow though!!
    anyone know about the mac method??
    Master:
  • 518 Answers
If Windows (you didn't say), try using Disk Cleanup from Accessories > System Tools. There could also be hidden files on it. In Control Panel > Folder Options > View click the box for "Show hidden files"
Hope that helps...
Geno
Posted on Apr 04, 2008
My PNY 32 GB Flash drive says 24 GB are being used, but all the files only add up to about 6 GB. How can I find those 18 GB worth of files, so I can use all the space on my drive?
Make sure nobody put hidden files on the Flash,
Copy the files off, then reformat the flash in NTFS unless you have an old computer.
FAT32 will work, the limit is 4GB for a single file and 2TB for the whole drive. If it was an SD or variation I would have kept with this for compatibility with cameras ect. NTFS for a USB has a couple features that make it slightly more reliable and faster for a situation where you have many small files.
Below is a link to a simple flash formatting tool.
HP USB Disk Storage Format Tool
Jul 20, 2016 | PNY Electronics - Others
Startup repair
Please note all below options are at your own risk and only applies to ASUS Vivotab TF600T.
Option 1: From within Windows RT:
1. Select PC Settings .. General
2. Scroll down to options - a. Refresh your PC or b. Reinstall Windows (see NOTE below) c. Reset from recovery disk. (see Options 2 & 3 below).
Option 2: If you have a saved recovery disk on an usb pendrive:
1. Shutdown your tablet.
2. Connect the recovery disk to your usb port on the keyboard.
3. Keep the volume down button pressed and power up your tablet.
4. Release the volume down button when the ASUS logo appears.
5. Recovery software on disk will start the recovery process.
6. Follow the prompts and choose your language / keyboard options.
7. Select Troubleshoot .. Advanced Options ..a. Refresh your PC or b. Reinstall Windows
NOTE: Selecting (b) will reset your PC to factory settings (so save all your data) and you'll also have to install all updates again - DO THIS ONLY AS A LAST RESORT!!!
Option 3: If you don't have a saved recovery disk:
1. Refer to below link and download the file vivort.rar (over 3.6 GB). Also read all relevant comments on that forum before you begin.
http://forum.xda-developers.com/showthread.php?t=2165831
2. Insert a blank min. 8 GB usb disk in the PC you saved the file and open an elevated command prompt and enter 'diskpart' and then the below in this order:
a. list disk
b. select disk (no. of your usb drive only or wrong drive will get cleaned)
c. clean
d. create partition primary
e. select partition 1
f. active
g. format fs=fat32
h. assign
i. exit
3. Extract/Copy the files to the root of the USB drive, not in a folder.
4. Follow steps 1 to 7 in Option 2 above.
Hope this helps someone.
Mar 28, 2014 | ASUS VivoTab 32GB TF600T 10.1" Windows RT...
I have used this flash drive for two days and saved a couple of things. Today i opened a file on the flash drive and made some changes to it. I went to save it back to the flash drive and it said the...
Were the changes you made to the drive only with text changes or did you do some attribute changes? If you haven't make attribute changes, then it should save the file without problems unless the total size of the file exceeds the drives total free space, or if the drive is write-protected or damaged. If you can't get it to run any other way, then you might consider reformattting it and starting over. If you have important files you wish to save, then you will need to run some kind of drive data recovery software like BadCopy Pro v4.10.Build.1215 (or similiar) PRIOR to formatting. This program will recover data on just about any media or drive including floppies, usb thumb drives, hard drives, etc.
Sep 09, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My I Mac won,t reconize my PNY 4 gb usb Flash drive when I insert it
Try reformatting it:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Aug 17, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Need a manual or instructions how to operate it
experimental status
ZEN mozaic player 2 GB
firmware 1.03
ZEN attached to USB 2.0
Windows XP SP2
Message "do not disconnect"
ZEN is not being recognized
Check ZEN memory setting
Memory ZEN is set to 0 in MENU>Etras>removable disk
Memory ZEN should be changed to maximum 1.5 GB
ZEN is recognized now
ZEN is ready to do the format command
ZEN can be written to for a maximum of 0.5 GB [internal memory !]
ALERT ! This 0.5 GB is the internal memory
The files written to the internal memory will be erased after
disconnecting !
access status
NO ACCES TO MY ZEN ?
1) Get access to ZEN by setting disk memory to maximum
2) ZEN should be recognized now
format status
1) FORMAT the disk
After formatting !
SET BACK YOUR disk memory capacity to zero [ 0 ]
for fully recovering the disk capacity
files presence status
FILES NOT PRESENT AFTER DISCONNECTING ?
- When set to zero you can use the full memory for
writing files to the player !
- When keeping the memory set to maximum you're using
the internal memory and written files are not saved
after disconnecting
updating + files presence status
UPDATING FIRMWARE ZEN MOZAIC = MAKING STANDARD MAPS
1) download the firmware that is suited for your computer
Operating System and your type of player from "CREATIVE"
2) Connect player to USB 2.0
and update with the firmware-update
3) Wait until the update is fully completed
4) After the update disconnect the player
5) Connect to USB 2.0 again
6) Check for the presence of the STANDARD MAPS for Music,
Pictures and Video
7) Files can be written into the STANDARD MAPS
8) Written files should be present after disconnecting
9) Files ready for mobile playing on ZEN mozaic now
CREATIVE support site for fimware / software / userguide
SUPPORT FOR ZEN MOZAIC ON THE INTERNET
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic
May 10, 2009 | Creative Labs Creative Technology Zen MP3...
Pny 16gb attachi flash drive reccognized by my computer but says insert disk into drive when I left click it
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 14, 2009 | PNY Attach? 16GB USB 2.0 Flash Drive
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
PNY USB SmartMedia Reader PC (SFRUSBWB) Logo
82 people viewed this question
Top PNY Computers & Internet Experts
David
David
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
