Question about Garmin StreetPilot C330 GPS Receiver
Battery How long will the c330 batter last using the unit unplugged?
Manual says about 5 hours, ands that about on the money.
Posted on Apr 03, 2008
How do I change the batter in a Garmin Street
Hi! You may need to change the fuse periodically, which is at the tip of the adopter! regarding battery, you may need to contact waste disposal section for disposing the unit since it contains lithium. Don't consider much presence of high amount heat and direct sun rays at new battery for longer duration and have fine
Dec 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot
Did you try replacing the batter? I think that is the problem with this unit...
Jul 30, 2008 | Garmin StreetPilot C330 GPS Receiver
My c330 will not turn off when unplugged.
You have to turn it off from the button on the right side. When you unplug the unit continues to run on the internal battery
Nov 06, 2009 | Garmin StreetPilot C330 GPS Receiver
My Garmin street pilot C330 was purchased about 2 years ago. Lately, it has begun giving a message, Low battery. I have had to charged it up on my computer 2 times in the last 2 weeks. What is the problem?...
2 years is generally about it for the battery on the C330.
You most likely need a new battery.
Charging it on or off does not matter.
Run it with the back light on a dimmer mode to increase battery life for now.
Sep 06, 2009 | Garmin StreetPilot C330 GPS Receiver
Need battery for street pilot c330
THis battery will work in your C330 Garmin. I have had it in my unit for 3 years now without any issues.
http://www.etronicspal.com/132805.html
Just open the unit and splice the wires, and use some electrical tape. Good as new.
Jul 18, 2009 | Garmin StreetPilot C330 GPS Receiver
I turned it on and it lit up and then completely died
Question: Why won't my StreetPilot c3xx power on?
Found on the Garmin web site --> Answer: If your StreetPilot does not power on, or if it turns on then turns off, you can troubleshoot the problem by resetting or charging the unit. The reset is a "soft" reset that you can perform in the car; it restores power to the unit, but it does not remove data.
To reset the unit:
  1. Place the unit in the cradle and roll it backwards slightly to lock it in place.
  2. With the key in the car ignition, turn on the unit or put it in accessory mode.
  3. On the face plate of the unit, put your thumb nail in the groove under the Garmin logo and gently pull off the face plate.
  4. With the face plate removed, press the reset button on the right side.
  5. Turn the unit back on. If the unit still doesn't power on, you may need to charge it.
To charge the unit:
  1. Using the provided USB cable, connect the device to the computer.
  2. Reset the unit (following instructions above).
  3. Keep the device connected to the computer and allow it to charge overnight (7-8 hours).
  4. After charging, unplug the unit and power it on.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 03/10/2008
Oct 05, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN PROBLEMS
Had the same problem. Called Support. They answered immediately - a HUMAN, no recording, speaking American English - walked me through some tests, diagnosed a defective battery, gave me info on returning unit, I had it back in a flash. This is a classy outfit, and the Garmin C330 is a superb piece of equipment, has been flawless since.
Call 1-800-800-1020
Aug 29, 2008 | Garmin StreetPilot C330 GPS Receiver
No power to garmin c330
Does the unit turns on while pluged into the computer? If the answer is yes, then you will need to replace the battery. The battery is not taking a charge.
Jun 03, 2008 | Garmin StreetPilot C330 GPS Receiver
Powerless garmin
When leaving the unit not powered up for so long, the internal battery may be damaged. The power supply will not start up if the internal battery is defective.
Sometimes the internal power supply may become defective in this case and must be replaced along with the battery. Contact the manufacture for details about how to get the unit serviced.
Jerry G.
Jun 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Street pilot
There is a reset button on the unit
Aug 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
21 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
