Question about Microsoft Xbox 360 Controller
Wireless controller controller will not charge when plugged in to usb port
Your problem could be if you were trying to use a normal battery pack instead of the rechargable one.
Posted on Apr 29, 2008
The mouse cursor on my laptop wandering without control?
This is what they call device interference, You might have to many wireless devices connected to a single USB port on your PC. Sometimes its a struggle between keyboard and mouse both wireless. Solution would be to limit the wireless devices to certain USB ports. For ex: plug the wireless keyboard to opposite USB port from the wireless mouse, vise versa. If you are using a multi-port USB connector, unplug the mouse from the multi-port and plug it to a single USB port on the PC.
Oct 20, 2014 | Sony VAIO Computers & Internet
Tip
How to use a ps3 wireless controller.
<span>Ensure your playstation 3 is properly set up and connected to Plug the power cord for the PS3 wireless controller into one of the usb ports on the front of the PlayStation 3.<span><br /><br /></span><span>Plug the power cord for the PS3 wireless controller into one of the USB ports on the front of the PlayStation 3.<span><br />Plug the other end of the power cord into the access port on the top of your wireless controller.Allow the wireless controller to charge, leaving it plugged into the PlayStation 3 undisturbed for several hours to gain a full charge.Disconnect the PS3 wireless controller from the power cord. Press the PS button to start up the PlayStation 3. The PS button is in the middle of the controller. It is clear and displays the PlayStation logo of a letter P and a letter S molded together into one shape.Use the wireless controller to control the PlayStation 3, exactly as you would have with a corded controller for earlier PlayStations.<br /><span><br /><br /></span></span></span></span>
on Dec 06, 2010 | Sony Playstation 3 (PS3) Console
Hi eveyone i have a ps3 and a Logitech wireless controller but won't connect to the ps3 please help
If there is a USB cable /charging port plug into PS3. If this doesn't have a USB cable /charging cable using your other ps3 controller turn ps3 on, scroll over to the settings, manage blue tooth accessories, turn controller on in discovery mode , and follow steps on screen to pair your PS3 and controller
Aug 11, 2014 | Video Game Consoles & Games
Charging problem?
The battery in the headphones is most likely not taking a charge anymore and will need to be replaced with an equal value rechargeable battery
Jan 04, 2014 | TekNmotion Airhead 1000 Wireless...
My controllers wont sync to the ps3 or charge on it but they charge when i plug them into the PC. i had the "Maximum power reached" message thing plop up then my ps3 crashed and now they dont...
yea i have noticed my ps3 isn't charging stuff either it only does charge when its turned on im pretty sure theres a setting to charge while the ps3 is off To sync:
  • Connect the USB cable (provided with the controller) into the data USB port on the top of the controller. Insert the other end of the controller into one of the two USB ports on the front of the system.
  • Power on the television and the Sony PlayStation 3. You are going to see a series of lights flicker on the top of the wireless controller.
  • Press the PS3 button in the middle of the controller. This tells the gaming system it is connected. A single light appears on the controller.
  • Remove the gaming controller from the PS3. You can now use it wireless. It is also possible to remove the USB cable from the PlayStation if it is blocking your field of view.
  • Jan 15, 2011 | Video Game Consoles & Games
    On ps3 my controllers wont charge i have perchased new controllers and usb cord and the wireless controllers still wont charge can u help me out? all the other system soft ware is running fine .
    maybe its the USB PORTS from your ps3 system that are not working try using a flash drive or any kind of USB drive into the ps3 USB port and see if the playstaion recognizes itif it doesn't I'd say its the USB ports that do'nt work
    Apr 10, 2010 | Sony Wireless Controller for PS3
    Its a big ben wireless controller with no usb how do i connect it to my ps3
    plug the usb thingy in the pc then connect the bigben controller then take out usb thing plug it into ps3 conct the controller and itz done
    Jan 18, 2010 | Sony Wireless Controller for PS3
    I cant get a connection with the xbox and the standard controller
    The usb ports are soldered onto the mainboard and would require quite a bit of technical knowlege to replace. You are stuck with wireless controllers and batteries. There are charging stations for xbox 360 controllers on ebay. Most 360's have a USB port on the back above the network port. You could charge with that one. Good Luck
    Nov 23, 2009 | Microsoft Xbox 360 Console
    Controller problem
    Ok, im figuring that you have a wireless network in your area.(to connect to xbox live. Also take into concideration that your wireless router works on the same radio frequency as your controller(it overrides the controller).
    Got to your router's settings and change the redio band to the highest it will go.
    Mar 23, 2008 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Controller Logo
    32 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Tre Elkins
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
