Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker and frige
I have a whirpool gold side by side and i notice that the frige is not getting cold at all and the freezer is not making any ice and i don't think there is any water dipense in there, could you help please
  • Anonymous Mar 23, 2009
    refridge is cool but not enough. Dial set on MAX
    Freezer cold but not freezing/making ice cubes.
  • Anonymous May 11, 2010
    If the compressor is running, and the fan inside of the freezer is running, check behind the back panel inside of the freezer. If you see a large amount of frost or ice there, let me know, as this means you probably have a defrost problem.
    Novelist:
  • 184 Answers
A COMMON FAILURE FOR THE WHIRLPOOL REFRIGERATORS THAT CAUSE NO COOLING IN THE FREEZER IS A BAD RELAY ON THE COMPRESSOR.
LISTEN CLOSELY FOR ABOUT 5 MINUTES TO THE BACK OF THE REFRIGERATOR. IF YOU HEAR A CLICK AND THE COMPRESSOR HUMS AND THEN CLICKS AGAIN AND SHUTS OFF THE COMPRESSOR, THE RELAY IS MOST LIKELY BAD. ABOUT A 40 DOLLAR COMPONENT.
ALSO, CHECK THE FREEZER BACK WALL. IF IT IS FROSTED UP, THERE IS A FAILURE OF THE DEFROST CYCLE. YOU WOULD HAVE TO CHECK THREE COMPONENTS. THE DEFROST CONTROL, HEATER, AND BI-METAL.
Posted on Apr 10, 2008
SOURCE:
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
Whirpool gold Frige no light or temp display working
I am having the same problem does anyone have a solution?
Dec 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Side by side, freezer very cold, frige warm
Any ice buildup is due to one of 2 problems. Either the defrost circuit is not working properlyor the drain hole where the defrosted water drains down to the underneath pan is clogged. I once found a spider's nest in the drain of a refrig that was in a seasonal house after the winter shutdown.
Very common is a defective (open) defrost thermostat, or a bad defrost timer. But for a unit only 5 yrs old I'd start with the drain hole. BE SURE YOU GET ALL THE ICE OUT. Use hot water, hairdryer etc, so water flows freely to drain pan
Aug 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirpool Gold Refrigerator Ice Maker not making ice
Hi: It is a separate line. If the tube to the ice maker was not clogged with ice itself that is not your problem. The ice maker is thermally proctected and will not make ice unless the freezer is actually at zero degrees F. Not just frozen. The plastics in a freezer will be soft when warm even easily melt, but be hard when at operating temps. Just try setting your freezer colder to see if it kicks in. Give it at least 24 hrs. Don't do the human nature thing and open it every hour to see if it makes ice. You will just dump the cold air out. Listen for the ice to dump into the tray. I hope this helps, Jeff
Jun 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frige is cold, freezer is cold & freezing . . . Ice maker not making ICE.
Hi: As we don't (as in I) know the actual temp. in the freezer, this is a simple and free try. Cold is cold. The temp in the freezer has to be 0 degrees to make ice. They are thermally protected. A good guess for temp. is your ice cream. Is it rock hard? A lot of refrigerator thermometers are inaccurate. Just try setting your freezer colder. Ignore human nature and don't check the freezer every 30 Min's. You will never get to 0 degrees. I hope this helps, Jeff
May 31, 2009 | Refrigerators
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Can you lower the ice maker temp on that model.
Thanks J
Jan 05, 2008 | Freezers
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
166 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
