Question about Agere (DSLU56KPCI) Modem
Modem Problem? When I click on connect, the modem dials, but then the operator comes on and says that the call can not be completed as dialed. The phone line is fine and the modem checks out with PC doctor. The modem was fine at 4:00 but would not work at 7:00 the same day. Everything else seems to check out OK. Any suggestions?
  • Magic_Flute Apr 04, 2008
    I HAVE tried to call at least three different numbers. It is not the number being called, it is with the computer itself. Trust me, I have tried just about everything I can think of!
  • 346 Answers
In order to really test your modem you need to call more than just 1 (your ISP's) number. If you are not getting 56k connects, you should try your modem with other local/toll/toll-free numbers. This is a list of some toll-free numbers, the 3Com "Line Test" Number (a toll-call), and links to various ISP local access number listings Setting up an account with a Free ISP is another way you can test and isolate modem/ISP problems.
1-847-330-2780 - USR Linetest number - this is a toll call; if you log-in as "Line Test" with a v.34 modem, it will attempt to determine if your line will support 56k connections.
1-847-330-4569 - US Robotics' V.92 Test number - this is a toll call; the server is a 3Com Total Control HiPer ARC running V.92 server side code that supports PCM upstream.
The following numbers use toll circuits but are free to the caller (as long as you don't log in):
1-800-245-3828 - (Canadian weather BBS)
1-800-590-4857 - (IBM Global network access # x2 and V.90 3Com Server)
1-800-784-3638 - (Netcom - supports V.90)
1-888-861-8490 - (MCI/Worldcom))
1-888-245-0113 - (AOL access x2)
1-800-716-0023 - (AOL alternate access)
1-888-296-3892 - (AT&T Worldnet accessV.90,x2)
1-800-638-1483 - (GTE Net access - V.90/K56Flex Ascend Server)
1-800-572-1959 - (Compuserve V.90,x2)
1-800-350-6885 - (Earthlink - V.90,x2)
1-800-853-7921 - (Earthlink - Flex)
1-800-534-7097 - (Earthlink - Flex)
1-800-304-4226 - (Shore.net - Flex)
1-800-320-4509 - (Ascend 56KFlex test line)
1-800-779-2966 - (Used to be MCI)
1-800-846-7562 - (Gateway BBS)
Posted on Apr 03, 2008
SOURCE:
How can connect internet on our pc with aircel sim
First load the mobile softwares on your PC from the CD
Once the necessary softwares are installed connect your phone through data cable
then follow below given procedure
Go to Start > Settings>control panel> double click on phone & modem
New pop up window opens.in this window got to Modems tab and select the phone modem which would be visible there.
click on the properties and then on diagnostics
click on query modem in new window and wait for some time to get response
You should see that AT command SUCCESS in the command response text area. If doesnt get any response check your phone or contact your phone manufacturer.
Now got to advanced tab in same window and put extra initialization commands given below:
AT+CGDCONT=1, "IP", "aircelgprs"
Now Modem installation complete
Create Dial up connection for Aircel:
Go to My Network Places ,click on it
click on View Network connections
go to create new connection
select connect to internet
select "Set up connection manually"
select connect using Dial up
select mobile handset Modem
Click next and put ISP name as Aircel
?· In next window put *99***1# as dial number
Leave The User Name, Password and Domain Fields Blank and select make this default connection & shortcut to desktop and click Finish.
Now you can connect through dial up.
Dec 20, 2010 | Computers & Internet
After a crash due to the phone line being cut explorer insists I
Your computer is set to "dial using the modem when it is detected that there is no active Internet (DSL or cable-modem) connection".
Within Internet Explorer, click Tools, click Internet Options, click Connections, and set it to "never dial".
Jun 01, 2010 | Microsoft Windows XP Home Edition
I am using zte usb modem FFF1 for internet access via reliance netconnect.whenever I connect the device to laptop it is shown as storage device but as soon as i install the driver software a driver not...
The ZTE modem when initially connected to any system loads as a storage device which contains the software necessary to install the modem. Connect the ZTE and open it in Explorer. Double click the setup file (.exe) to start installation. Follow instructions and allow installation to complete. The modem is automatically installed during this setup. Once completed restart and then your ZTE functions as a modem.
May 19, 2010 | Computers & Internet
I just brought a dell 10' netbook and i have dial up phone service so how can i get the internet on my netbook with dial up service?
Here is the internet setup info for that netbook from Dell's website ...
Setting up Your Internet Connection To connect to the Internet, you need a modem or network connection and an Internet Service provider (ISP).
To set up an Internet connection with a provided ISP desktop shortcut:
  1. Save and close any open files, and exit any open programs.
  2. Double-click the ISP icon on the Microsoft® Windows® desktop.
  3. Follow the instructions on the screen to complete the setup.
note.gif NOTE: Have your ISP information ready. If you do not have an ISP, the Connect to the Internet wizard can help you obtain one.
If you do not have an ISP icon on your desktop or if you want to set up an Internet connection with a different ISP:
Windows Vista®
  2. Click Start interne3.jpg ® Control Panel® Network and Internet.
  3. Under Network and Sharing Center, click Connect to the Internet.
The Connect to the Internet window appears.
  1. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect:
    • Choose Broadband if you will use a DSL modem, cable TV modem, or satellite modem.
    • Choose Wireless if you will use a wireless connection through a WLAN card.
    • Choose Dial-up if you will use a dial-up modem or ISDN (Integrated Services Digital Network).
note.gif NOTE: If you do not know which type of connection to select, click Help me choose or contact your ISP.
  1. Follow the instructions on the screen and use the setup information provided by your ISP to complete the setup.
Windows® XP
  2. Click Start interne6.jpg ® Control Panel® Network and Internet Connections.
  3. Click Set up or change your Internet connection.
  4. Click Setup. New Connection Wizard window appears.
  5. Click Next. Choose Connect to the Internet and click Next.
  6. Click Set up my connection manually and click Next.
  7. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect.
And here is the link to where the info was found...
http://support.dell.com/support/edocs/systems/xlob/dtg/en/internea.htm#wp1012333
and another with more info on that netbook ..
http://support.dell.com/support/edocs/systems/xlob/dtg/en/index.htm
Apr 06, 2010 | Dell Inspiron Mini 10v Netbook Computer
How can i use jasjam as a modem
Thank you for visiting Fixya Forums
Using a Jazjam as a modem:
Notes
• Before activating Wireless Modem, make sure your device has a
SIM card installed, and you have set up a GPRS or phone dial-up
modem connection on your device. For more information about
setting up a GPRS connection, see "To set up a GPRS connection to
the Internet". For more information about setting up a phone dial-up
connection, see "To set up a dial-up connection to your ISP".
Also make sure you have connected your device to a computer (via
infrared, USB or Bluetooth).
• When you activate Wireless Modem, ActiveSync will be disabled
automatically.
To set up your device as an infrared or USB modem
1. On your device, tap Start > Programs > Wireless Modem.
2. In the Connection Type list, select how your device is connected
to the computer: IrDA if via infrared, or USB if through USB cable
connection.
3. To use your device as a GPRS modem, set the GPRS Access
point name. To do so, tap Menu > APN Setting and enter the
access point name.
4. Point your device at the infrared port of your notebook, or plug in
the USB cable adapter between your device and the notebook.
5. Tap Menu > Start.
6. The next thing to do is to add your device as an infrared or USB
modem onto your notebook.
To add your device as an infrared modem to your notebook
1. After you tap Menu > Start on the Wireless Modem screen
of your device, the Found New Hardware dialog box will then
appear on your notebook and will show that your device has been
detected as an infrared modem. In this dialog box, make sure that
Install the software automatically (Recommended) is selected
then click Next.
2. Wait for Windows to finish installing the infrared modem, then
click Finish.
3. You can now connect your computer to the Internet. Follow the
steps in “To dial up and connect to the Internet.”
To add your device as a USB modem to your computer
1. After you tap Menu > Start on the Wireless Modem screen of
your device, your computer will automatically detect that your
device has been connected. The Found New Hardware dialog
box will then appear on your computer.
2. In the Found New Hardware dialog box, select Install from a list
or specific location (Advanced) and click Next.
3. Select Search for the best drivers in these locations.
4. Insert the Getting Started Disc into your CD drive. Select the
Include this location in the search check box. Click Browse
and choose the CD drive and root folder where the modem driver
is located, then click Next.
5. Wait for the installation to complete, then click Finish.
6. Click Start > Settings > Control Panel.
7. Double-click Phone and Modem Options.
8. Click the Modems tab. Select the new modem from the Modem
list, then click OK.
Getting Connected
9. You can now connect your computer to the Internet. Follow the
Once the computer recognizes your device as a modem, you can now
use the computer to dial up and connect to the Internet.
1. On your computer, click Start > Settings > Control Panel.
2. Double-click Network Connections.
3. Click File > New Connection.
4. In the New Connection Wizard, click Next.
5. Click Connect to the Internet then click Next.
6. Select Set up my connection manually then click Next.
7. Select Connect using a dial-up modem then click Next.
8. Select the infrared, USB or Bluetooth modem that you previously
installed, then click Next.
9. Enter a descriptive name for this connection, then click Next.
10. If you are connecting to the Internet via GPRS, enter the
telephone number as *99#. Otherwise, enter your ISP‘s dial-up
phone number, then click Next.
11. Under Internet Account Information, you may not need to
enter a user name and password when using GPRS. Just click
Next to proceed.
12. Click Finish to exit the wizard.
13. The Connect dialog box then opens. Click Dial to dial up and
To end the modem session
• On the Wireless Modem screen, tap Done or tap Menu > Stop.
(Please give me a big thumbs up when you rate my answer, thanks.)
Jan 28, 2010 | i-mate JasJam Smartphone
My 8330 does not let me browse the internet on my
Hi BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
To set up a tethered modem, complete the following tasks from A to D
A) Install BlackBerry Desktop Software 4.1 or later on your computer.
B) To set up an Internet APN, complete the following steps:
1) Click Start > Settings > Control Panel.
2) Double-click Phone and Modem Options.
3) In the Phone and Modem Options window, click the Modems tab.
4) Select Standard Modem and click Properties.
5) Click Change Settings.
6) In the Standard Modem Properties window, click the Advanced tab.
7) In the Extra initialization commands field, type the following:
+cgdcont=1,"IP","<your Internet APN>"
The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
8) Click OK.
9) In the Phone and Modem Options window, click OK.
C) To configure dial-up networking, complete the procedure that is appropriate for Windows Vista
1) Click Start.
2) Select Connect To.
3) Click Setup a connection or network.
4) Click Setup a dialup connection.
5) In the Dial-up phone number field type *99#.
6) Type the user name and password provided by your wireless service provider.
7) In the Connection Name field type BlackBerry.
8) Click Dialing Rules.
9) Make sure the profile created in Task 2 has been selected, and then click OK.
10) Select Connect to establish an Internet.
D) To connect to the Internet using dial-up networking, complete the following steps:
During this procedure, do not operate the BlackBerry Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
1) Connect the BlackBerry smartphone to the computer.
2) Open BlackBerry Desktop Manager.
3) Click Start > Settings > Network Connections > <name of your new connection>.
4) Type the user name and password provided by your wireless service provider.
5) Click Dial.I hope this information will help you
Nov 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How to open ethernet??
Task 1 - Turn on the Discoverable option on the BlackBerry smartphone Complete the following steps:
  1. On the Home screen of the BlackBerry smartphone, click Options > Bluetooth.
  2. Display the menu and click Options.
  3. Set the Discoverable field to Yes.
  4. Display the menu and click Save.
Task 2 - Pair the BlackBerry smartphone and the computer On the computer, complete the following steps:
  1. Go to Control Panel > Bluetooth Devices.
  2. Click Add.
  3. Select the My device is set up and ready to be found check box, and click Next.
  4. When the BlackBerry smartphone is detected, select the check box next to the BlackBerry smartphone, and click Next.
  5. Select the Let me choose my own passkey option.
  6. Type a passkey in the field provided, and click Next.
  7. On the BlackBerry smartphone, type the same passkey from Step 6, then click the trackball.
  8. On the computer, when the Completing the Add Bluetooth Device Wizard screen appears, click Finish.
  9. On the BlackBerry smartphone, when prompted to accept an incoming Bluetooth connection, select Don't Ask Again, and click Yes.
Task 3 - Set up the Internet access point name (APN) Note: You only need to perform this task the first time that you set up the Internet APN.
Note: If you are running Windows Vista, select Classic View.
  1. Go to Control Panel > Phone and Modem Options.
  2. Select the Modems tab.
  3. Select Standard Modem Over Bluetooth Link, and click Properties.
  4. Select the Advanced tab.
  5. In the Extra initialization commands field, type the following: AT+CGDCONT=1,"IP","<your Internet APN( for eg: aircelgprs)>"<cr>
Task 4 - Configure Dial-Up Networking Note: You only need to perform this task the first time that you configure Dial-Up Networking.
  1. Go to Start > Settings > Network Connections.
  2. Right-click Bluetooth DUN connection, and select Properties.
  3. Select the Networking tab.
  4. Select Internet Protocol (TCP/IP).
  5. Click Properties.
  6. Click Advanced.
  7. Select the General tab, and clear the Use IP Header Compression check box.
  8. Click OK to close all open windows.
  9. Go to Start > Settings > Network Connections.
  10. Double-click New Connection Wizard.
  11. Click Next.
  12. Select Connect to the Internet, and click Next.
  13. Select Set up my connection manually, and click Next.
  14. Select Connect using a dial-up modem, click Next.
  15. Select Modem - Standard Modem Over Bluetooth link, and click Next.
  16. If the Select a Device screen appears, select the Modem - Standard Modem check box, and click Next.
  17. Clear the ISP Name field blank, if necessary, and click Next.
  18. Complete the appropriate step below:
    • If the BlackBerry smartphone operates on General Packet Radio Service (GPRS) or Enhanced Data Rates for Global Evolution (EDGE) networks, type *99# in the Phone number field, and click Next.
    • If the BlackBerry smartphone operates on Universal Mobile Telecommunications System (UMTS) networks, type *98# in the Phone number field, and click Next.
    • If the BlackBerry smartphone operates on Code Division Multiple Access (CDMA) or 1x/Evolution Data Optimized (EVDO) networks, type #777 in the Phone number field, and click Next.
  19. Type the user name and password provided by your wireless service provider. If your wireless service provider has confirmed that this information is not required, leave the fields blank. Click Next.
  20. Click Finish.
Task 5 - Connect the computer to the Internet using Dial-Up Networking Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session may interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Click Start > Settings > Network Connections > <Name of the new connection>.
  2. Type the user name and password provided by your wireless service provider. If your wireless service provider does not require this information, leave the fields blank.
  3. Click Dial.
Oct 05, 2009 | RIM BlackBerry 7730
Modem
Found this after some deep looking from blackberry itself: Good Luck
A BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
Summary of Tasks To set up a tethered modem, complete the following tasks:
  1. Install BlackBerry Desktop Software 4.1 or later (one time only).
  2. Set up the Internet access point name (APN) (one time only).
  3. Configure dial-up networking (one time only).
  4. Connect to the Internet using dial-up networking.
Task 1
When you install BlackBerry Desktop Software, the drivers that allow the BlackBerry smartphone to communicate through the Universal Serial Bus (USB) port and virtual communications port are installed. The standard modem, which is used by dial-up networking, is also installed.
Note: If upgrading your BlackBerry Desktop Software from version 4.0 to 4.1, the required virtual communications port and standard modem might be removed during the upgrade process. If this is the case, re-install the BlackBerry Desktop Software 4.1 or later and choose the Repair option to re-install these components.
Task 2
Set up an Internet APN.
  1. Click Start > Settings > Control Panel.
  2. Double-click Phone and Modem Options.
  3. In the Phone and Modem Options window, click the Modems tab.
  4. Select Standard Modem and click Properties.
  5. Click Change Settings.
  6. In the Standard Modem Properties window, click the Advanced tab.
  7. In the Extra initialization commands field, type the following: +cgdcont=1,"IP","<your Internet APN>"
    Note: The following is applicable for T-Mobile® customers only:
    Note: If you do not know your Internet APN, or if you do not have an Internet APN, contact your service provider.
  8. Click OK.
  9. In the Phone and Modem Options window, click OK.
Task 3
To configure dial-up networking, complete the procedure that is appropriate to the operating system you are using:
Windows Vista
  1. Click Start.
  2. Select Connect To.
  3. Click Setup a connection or network.
  4. Click Setup a dialup connection.
  5. In the Dial-up phone number field type *99#.
  6. Type the user name and password provided by your service provider.
  7. In the Connection Name field type BlackBerry.
  8. Click Dialing Rules.
  9. Make sure the profile created in Task 2 has been selected, and then click OK.
  10. Select Connect to establish an internet.
Note: For instructions on connecting a computer to the Internet using a BlackBerry smartphone with CDMA as a tethered modem, see KB04664.
Windows XP operating system
  1. Click Start > Settings > Network Connections.
  2. Double-click New Connection Wizard. The New Connection Wizard opens.
  3. Click Next.
  4. Select the Connect to the Internet option. Click Next.
  5. Select Set up my connection manually. Click Next.
  6. Select Connect using a dial-up modem. Click Next.
  7. If the Select a Device screen appears, select the Modem - Standard Modem check box. Click Next.
  8. In the ISP Name field, type a name for your connection. Click Next.
  9. In the Phone number field, type *99#. Click Next.
  10. Indicate which users will have access to the connection. Click Next.
  11. Type the user name and password provided by your service provider. Click Next.
  12. Click Finish.
  13. In the Connect window, click Properties.
  14. In the Properties window, verify that Modem - Standard Modem appears beneath the Connect using heading, and then click Configure.
  15. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK. In the Properties window, click OK.
Windows 2000 operating system
  2. Double-click Network and Dial-up Connections. Note: The following is applicable for T-Mobile customers only:
    Under the networking tab in the properties window for the dial-up connection, clear the Enable LCP Extensions check box, as well as all check boxes beneath the PPP Settings window.
  3. Double-click Make New Connection. The Network Connection Wizard opens.
  4. Click Next.
  5. Choose Dial-up to private network. Click Next.
  6. In the Phone number field, type *99#. Click Next.
  7. Indicate which users will have access to the connection. Click Next.
  8. Type a name for your connection. Click Finish.
  9. In the Connect window, click Properties.
  10. In the Properties window, verify that Modem - Standard Modem is selected, then click Configure.
  11. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK.
  12. In the Properties window, click OK.
Task 4
Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Connect the BlackBerry smartphone to the computer.
  2. Open BlackBerry Desktop Manager.
  3. Click Start > Settings > Network Connections > <name of your new connection>.
  4. Type the user name and password provided by your service provider.
  5. Click Dial.
Apr 07, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
USB modem HiRo model H50113 will not complete phone connection
Yes you're right! What you have to do is:
  1. Right click My Network Places
  2. Select Properties
  3. Select the Advanced menu
  4. Uncheck "Operated-Assisted Dialing"
Jan 30, 2008 | Hiro V.92 56K AGERE Chipset PCI Fax Voice...
Open Questions:
See all Agere (DSLU56KPCI) Modem Questions
Agere (DSLU56KPCI) Modem Logo
536 people viewed this question
Top Agere Computers & Internet Experts
Ekse
Alun Cox
Are you an Agere Computer and Internet Expert? Answer questions, earn points and help others
