Question about RCA HD52W59 HDTV Projection Television
Rca hd52w55 issues with menu screen
    Genius:
  • 1,030 Answers
What is your issue with the menu screen
Posted on Apr 04, 2008
RCA 32 Smart Tv SLD32A30RQ Will turn but nothing happens and has a blank screen.
It sounds like the internal calendar function is working perfectly.
Nov 12, 2015 | RCA Televison & Video
52 Inch RCA TV Model HD52W55 does not turn on green power light blinks 3 times but does not turn on. ive got it to turn on once before, and left it on since, accidently shut it off and cant get it back on,...
The best assumption, at this point, is that the power supply board has died. You can buy a replacement unit from the link below and have it professionally installed.
Power Supply
Aug 28, 2011 | RCA HD52W58 52" TV
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
May 06, 2011 | RCA Televison & Video
I have a HD52W55 and it will not come on. heard a pop and smelled something burning, took the back cover off can not find anything obviously burnt but have no lights and no power.
Well, my first guess would be a blow fuse, did you check for that?
But if you smelled something burning, then even if the fuse did blow, it failed to protect something; probably the main power transformer. That's a coil of wire in a sort of square shape that should be near the fuse. Its hard to tell if they're burnt sometimes, but it may need replacement.
Please upload a few pictures so we can have a look too.
Mar 25, 2010 | RCA HD52W58 52" TV
My 52 rca screen looks like
This is a pin cushion issue. There should be a setting in the picture menu where you can adjust this. If that does not work than your unit has an issue that you will need a local service center to repair.
Oct 04, 2009 | RCA Televison & Video
HD50LPW42 screen is black with antenna inputs
It sounds to me like you have a tuner issue, I have seen this before. If you have a good picture from other sources and they have the same antenna input, the tuner is suspect.
I hope that this helps you solve your issue.
Thanks
asnowman
Aug 01, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA D52W19 52" Rear Projection Television
On going Convergence Issue RCA R52WH73 Television
did you reflow the solder on the flyback and the vertical output IC?
Jun 12, 2009 | RCA R52WH73 Projection Television
Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Feb 20, 2008 | RCA HD56W66 56" HDTV
RCA 46" TV
That's every interesting! I wonder if its the manufacturer setting on where there is some issue it does that... Is your product still under its warranty? Are you able to select anything in the main menu? Or is it frozen up on you?
Nov 21, 2006 | RCA P46924 46" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
81 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
