Question about IBM Wheelwriter 30 Typewriter
IBM WHEELWRITER 1500 TYPEWRITER
Our machine was just moved from one office to another and now has the following problem: when you turn it on the wheel will move to the left side, the lights continuously and simultaneously blink for the Phr / Env / Label. No other keys will function.
    President:
  • IBM Master
  • 3,594 Answers
Check to see if anything dropped into the typewriter to inhibit the movement of the carrier if noy try a few drops of WD40 on the shaft that runs thru the carrier.
DickyO
Posted on Apr 04, 2008
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
Brothers ax
Turn off the typewriter, open the top-cover and inspect the area around the carrier for any damage or foreign objects.
2. Move the carrier towards the center of the machine.
a. When moving the carrier manually, it should be difficult to move, butit will move under steady pressure.
b. If the carrier moves freely, the drive mechanism may not be connectedproperly.
3. Remove the ribbon and inspect the cartridge for damage. Turn the colored knob on the left side of the cartridge to remove any slack from the ribbon.
4. Check the correction tape to insure that it has not become tangled ordamaged.
5. Close the top-cover and restore power to the machine.
If the problem persists, your machine may require service.
Dec 12, 2013 | Brother EM-430 Typewriter
Carriage return stuck on left side when powering on
The first thing to try is to lubricate the silver rail that the carriage rides on. A few drops of a light oil ( sewing machine oil ) may take care of the problem. Turn machine off, apply oil and move carriage by hand back and forth. Turn back on and see if this took care of it.
May 14, 2013 | IBM Wheelwriter 6 Typewriter
Printhead won't go left of center
Check the 2 silver rails that the carriage rides on, they need to have a little bit of oil on them. I f they are dry to the touch, they need to be lubricated with a little bit of a light weight oil. This could also be caused by bad keyboard. Do all the keys seem to work? Try turning machine off and move carriage by hand to the left then turn on and see what happens.
Nov 27, 2012 | Lexmark Wheelwriter 5 Series II Typewriter
I had IBM Wheel Writer 1500. When the keys are pressed, the typewheel does not hit the ribbon.
The plastic print solenoid cap is broken. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
Jun 15, 2011 | Lexmark Wheelwriter 1500 Typewriter
I have a Lexmark 1000 Personal Wheelwriter and the daisy wheel does not easily slide into place. It then just keeps turning until the machine beeps and it stops. Will not type of course. Is there a...
No, the printwheels are the same for all Wheelwriters. Make sure the letters face the roller when you put it in (pull the print hammer assy back and check for paper clips, ribbon pieces, etc. first).
Jan 02, 2011 | Lexmark Wheelwriter 1500 Typewriter
Sadly my brother AX-100 is stck at the left hand side of the carriage. I cannot do anything. The machine tries to get itself warmed up but then a bell rings repeatedly. I canno move the daisywheel housing...
With the machine turned OFF, you can move the carrier to the right by hand fairly easily - DO NOT TRY TO FORCE IT- if it doesn't move, look inside the machine to see if some forein object is stopping it.
If the printwheel is not in the machine, it would normally go to the left, stop and start beeping. Its not really necessary to remove the ribbon and printwheel for transport, but it is a good idea to put something inside the machine to stop the carrier from slamming back and forth as it's moved.
Dec 30, 2010 | Brother Office Equipment & Supplies
IBM Wheelwriter 1500 When I'm typing, only the
The platen has probably worked itself loose. Press down firmly on both ends of the roll it should snap into place.
DickyO
Oct 27, 2010 | Lexmark Wheelwriter 1500 Typewriter
Model 6784 -wheel won't spin
The wheel is probably moving but the print solenoid cap is probably broken. We sell them with installation instructions and shipping for 20.00.
DickyO
216-241-0027
Jun 02, 2010 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 30 Typewriter Logo
114 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Toby
Toby
Level 1 Expert
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
