Question about Curtis Televison & Video
Curtis DVD 6500 Blank Screen
"DVD6500 Q: The screen is blank!
To reset the video output on your DVD, follow these instruction. Connect to standard composite connection (yellow video input on TV and yellow video output on DVD). Remove any DVD's from the unit. Turn the unit off, wait 10 seconds and then turn it on again. Using the remote, press SETUP, then the DOWN ARROW button 3 times. Press OK. Then press the DOWN ARROW button 8 times, RIGHT ARROW 1 time. Then press OK."
~ But that doesn't work for me. Any suggestions?
Sounds like you have accidentally gone into the scanning mode. Press and hold the subtitles button for 5 seconds to get out of this.
Posted on Sep 02, 2009
White screen
Try resetting your tablet. Google search your make, model and reset. Follow the instructions from one of the results provided.
May 04, 2012 | Philips SA3CNT16K 16 GB GoGear Connect 3...
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
The home theater system wont read my disc:(
Well from what I have found in trying to get this problem figured out is that it is a common problem with Curtis Home Theatre Systems; not just your model 6041. Here is a POSSIBLE solution:
To reset the video output on your DVD, follow these instruction. Connect to standard composite connection (yellow video input on TV and yellow video output on DVD). Remove any DVD's from the unit. Turn the unit off, wait 10 seconds and then turn it on again. Using the remote, press SETUP, then RIGHT ARROW button 4 times. Press Enter. Then DOWN ARROW button 3 times. Press Enter.
That is for your 6041. For what I have discovered elsewhere it may or may Not cure the problem. Give it a try and let me know one way or the other.
Oh, here is a link to the Curtis website Support area: http://www.curtisint.com/support/support.asp?brand=CURTIS .
Nov 29, 2009 | Curtis DVD6041 System
Blank Screen
First, confirm that it is the screen itself. Connect the video output to a known working monitor and then power on your Thinkpad. if the known working monitor behaves the same way you can rule out the laptop's monitor as the source of the problem. This may be the BGA, Ball Grid Assembly, leadless soldering problem related to video chips on the motherboard, but first test the monitors.
Apr 15, 2009 | IBM ThinkPad R51 Notebook
When I CONNECT MY CPU TO MY 42 PLASMA SCREEN
hi im josh in cebu phils .may i help you? Friend if the problem is when you connect the plasma screen it appears a seconds then blank. The problem is the video card of your pc output .it cannot supports your plasma screen. you need to use higher bit of video card for better output. good luck .
Feb 23, 2009 | ASUS P5P800-MX Motherboard
Cant see screen on laptop think its videowave???
MS-DOS edit command help edit myfile.txt <press enter>. This would bring up a blank edit screen, as long as the file is saved upon exit this will create the file myfile.txt.
Linux and UNIX xset command help The 'reset' flag forces deactivation of screen saver if it is active. The 'blank' flag sets the preference to blank the video (if the hardware can do so)
Read and follow instructions, good luck, please dont for get to Vote/Thank You
Dec 05, 2007 | Gateway 450SX4 Notebook
Pinoeer DVD-366
Hi there, just got that progresive problem gone :D
- Startup ur DVD (ON)
- Wait until Loading - No Disc (status on DVD display)
- In here, ur screen still blank (black screen)
And here's how:
- Press "Home Menu" button
on ur DVD (it should be on the down left of the circle button)
-- Watch out, the screen still in blank, just feel it right ok?
- Down 2x -- Initial Setting
- Menu / Ok (the circle button)
- Down -- Video Out
- Menu / Ok
- Down -- Component Out
- Menu / Ok
- Down -- It will choose Interlace, it will saved the day :-)
- Menu / Ok
That's it.. Cheers mate ^^
Give me a mail if u still have the problem, coz I Know how it sucks.
Tyraxel@yahoo.com
Dec 02, 2007 | Pioneer DV-366K DVD Player
Televison & Video Logo
122 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
