Question about Car Audio & Video
Indicators Hello, I drive a 2001 VW Passat. The indicators and hazzard lights have stopped working. They work when unlocking the car with the remote control but not when turned on manually. I think it might have something to do with the fuse, but I'm not sure where the fuse box is either. Could you offer some advice/help? Thanks, Lisa
  • 323 Answers
Behind the cover on the left side of the instrument panel- driver's side- you have to have the driver's door open to remove the cover.
http://64.85.6.118/diagrams/diagrams.asp
Might be wiring issue. Look for your vehicle in this database.
You'll have the color codes for your vehicle there.
Found some other information:
It's likely that the relay is not working. It should be behind the emergency indicator switch. Try this switch to see if indicators work, if not activate it several times as there might just be a bad connection. If still no joy then you will need to prise out the switch (carefully to not damage trim) and renew the relay.
Posted on Apr 04, 2008
Holden cruz petrol cap will not open
Hi
i have a problem with my VW Bora 2002 ,2.0 engine .
i drove home last night and today the lights did not switch on , no indicators , no wipers and no AC
but the hazzard lights go on and the head light or brights.
it drives normall , I did check the fuses all of them looks good.
any one can help?
Nov 22, 2013 | 2001 Volkswagen Golf
My instrument says my drivers door is open when it is not. I can open my car with the remote, but can not lock it. Is it the Comfort Control Module? VW Passat 2001. 2.0L
the problem you are having is the drivers door latch mecanism, i just changed one on a 2002 jetta yesterday, the electronics in the latch get worn out, the only place to get one if from a dealer.
Oct 29, 2010 | 2001 Volkswagen new Passat
VW passat 2001 2.8L The hand brake ligth comes on with a continou
Its faulty sensor for driver warning (control light and acustic) when is parkbrake switched up. For safety goes warning after move on. When stopped is warning out. Its VERY EASILY to repair
Jun 08, 2010 | 2001 Volkswagen Passat
Programming keys for 2001 VW Passat
I'm thinking ask google or utube
Sep 02, 2017 | 2001 Volkswagen Passat
Vw passat 2001 cant stop car alarm how can we fix this?
Sounds like your autostart is damaged, you can try to put it in valley mode. By chance is the battery good in the remote?
Apr 15, 2009 | 2001 Volkswagen Passat
No lights and ac and indicators
suspect x relay or wiring for this problem this relay controls all circuits for all inop components ,may also be fault with ignition switch has twin circuits one for aux, as above and one for ignition for engine aux may be faulty, hope this helps phil.
Feb 10, 2009 | 2001 Volkswagen Golf
Key fob not working
hello mate.. if it has stopped working you might want to check the battery first.. if you are sure that the battery is fine then consider reprogramming the fob to your car.. here are the steps to follow.. NISSAN
Remote Control Fob Procedures:
The Central Door locking is controlled by the Multi-Remote Control system which controls
the door locking, door super locking and emergency hazard reminders.
When the doors are locked and unlocked the unit flashes the hazard lights once for lock and twice for unlock.
A maximum of four remote controls are allowed to be programmed:
ALMERA
ALMERA TINO
PRIMERA
MAXIMA
MICRA
SERENA
VANETTE CARGO
TERANO II
Ensure all the doors have been unlocked, either by using a good transponder key or remote
control plip key.
Procedure:
1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds.
2. Next, turn ignition switch to OFF position. Leave key in ignition switch.
3. Wait 2 seconds then the system will enter programming mode and will flash the warning
lights twice.
4. Press and HOLD the unlock button on the Plip.
5. While pressing the unlock button, press the lock button 3 times.
6. Release the unlock button.
7. The warning lights will flash once to indicate successful programming.
8. Repeat procedure 4 to 7 for up to 4 plip key's.
9. When completed turn ignition ON, and the warning lights will flash 2 times.
10. Remove key, and check all plip key's for operation.
NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys
have been programmed or no input signal either from the switch or plip keys has been received
for 120 seconds.
http://www.autokeysquad.com/nissan-fob-programming
i hope this can help you.. :)
Jul 28, 2008 | 2005 Nissan Sentra
Suddenly my remote control device to lock and open doors in passat 2001 stopped working, the red light is blinking, but nothing happens, can anybody help?
replace the battery in the remote .it will stop working even before the batt is completely dead.
has anyone worked on the car lately?
Jun 30, 2008 | 2001 Volkswagen Passat
Car Audio & Video Logo
154 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
