Question about Lexmark 4600 MFP
Blank LCD screen
Problem with Lexmark 4600 mfp option. LCD Screen lights but does not display anything. Cables are correctly installed. Any suggestions will be appreciated
  • 55 Answers
Problem is with lcd only may be its gone...
because in most cases they lights but doesnt show anything..
chirag
Posted on Apr 03, 2008
Blank screen
Did the laptop boot up all the way except the screen is blank? Do you hear fans running and the hard drive spinning, lights on? If you think it booted except the screen is blank try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 23, 2012 | Computers & Internet
Unable to install on screen display after windows 7 installation
What do you mean unable to install on screen display? Are you saying your screen is blank?
Maybe you need to reinstall the video drivers.
Get online and got to www.google.com In the google search box type: "IBM Support" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Video drivers.
If you are saying that the system boots up and everything seems to be running except the screen is blank then try the steps below.
May 14, 2012 | IBM LENOVO - ThinkPad R500 - Genuine...
Unable to load on screen display on lenovo r500
May 14, 2012 | IBM LENOVO ThinkPad R500 - Genuine Windows...
The monitor is blank (pale gray color). No information How can I find a monitor to replace it? The computer is a Dell Dimension 4600 series. I don't know what are the video characteristics of this...
Hello
OK, the package comes standard with a 17 inch screen(CRT). So, basically you have 2 choices, you can either buy a replacement CRT screen or you can buy LCD, these are the cheaper options available at this moment.
I would personally go for a LCD screen. the size is a personal choice, but i will not go any bigger that a 23 inch with the graphics card installed.
You will be able to buy it at almost any computer store, and it is cheaper than you think.
Please let me know if this was sufficient, if not, i will try and better explain myself.
Kind regards
Andrea
Sep 08, 2010 | Dell Dimension 4600 PC Desktop
How do I access the menu/control panel?
MFP and scanner settings can be changed several ways: through the MFP control panel, the software application in use,
the print driver, MarkVision™ Professional, or the Web pages. Settings changed from the application or print driver apply
only to the job being sent to the MFP.
Changes made to print, fax, copy, and e-mail settings from an application override changes made from the control panel.
If a setting cannot be changed from the application, use the MFP control panel, MarkVision Professional, or the Web pages.
Changing a setting from the MFP control panel, MarkVision Professional, or the Web pages makes that setting the user
default.
Menus (A key is shown on the button.) Touch to access the menus. These menus are only
available when the MFP is in the Ready state.
The Menus button is on a gray bar called the navigation
bar. The bar contains other buttons described as follows.
Understanding the copy screens and options
Copy From:
Opens a screen where you can enter the size of the documents you are going to copy.
Touching any of the paper size icons on the follow-on screen will make that your selection and return you to the
Copy Options Screen.
When Original Size is set to Mixed Sizes, you can scan different size original documents (letter and legal size
pages). They will be scaled automatically to fit the selected output media size.
Copy To: Opens a screen where you can enter the size and type of paper on which your copies will be printed.
If the size settings for Copy From and Copy To are different, the MFP will automatically adjust the Scale setting to
accommodate the difference.
If you have a special type or size of paper that you'd like to copy onto that is not normally in the MFP paper trays,
you can select MP Feeder, and manually send the type of paper you want through the MP feeder.
When using Auto Match, the MFP will match the size of the original document as specified in the Copy From box.
If a matching paper size is not loaded in one of the paper trays, the MFP will scale the copy to fit loaded media.
Scale: Creates an image from your copy that is proportionally scaled anywhere between 25% and 400%. Scale can also be
set for you automatically.
When you want to copy from one size of paper to another, such as legal size to letter size, setting your Copy From
and Copy To paper sizes will automatically change the scale to keep all the original document information on your
copy.
Touching the arrow to the left lowers the value by 1%; touching the arrow to the right increases the value by 1%.
Holding your finger on an arrow makes a continuous increment.
Holding your finger on an arrow for two seconds causes the pace of the change to accelerate.
************************Darkness: Adjusts how light or dark your copies will turn out in relation to the original document.****************** here is the link to the full pdf manual for your unit: http://www.lexmark.com/publications/pdfs/2007/x644e/en/ug.pdf#xml=http://support.lexmark.com/lexmark/index?page=answeropen&segment=SUPPORT&userlocale=EN_US&locale=en&type=open&searchid=1270220491739&answerid=16777216&iqaction=6&url=http%3A%2F%2Fwww.lexmark.com%2Fpublications%2Fpdfs%2F2007%2Fx644e%2Fen%2Fug.pdf&productCode=&highlightinfo=106955230,537,548
Apr 02, 2010 | Lexmark X 646e MFP - multifunction ( B/W )...
Blank lcd screen only lights work,
software update would not do anything to restore the LCD's display, you need to have the phone repaired, it needs a replacement LCD.
Jul 04, 2009 | Samsung SGH-E251 Mobile Phone - Black
My phone is a samsung u700. its screen is blank and its not displaying anything. backlight on . what could the problem be.only light from the
first remove the battery just 5minites .................then display is out try change dis play .......
May 30, 2009 | Samsung Cell Phones
please cntact to your samsung care and its lcd screen goes to destroy or you can format your phone by pressing *2767*3855#
May 27, 2009 | Samsung SGH-U700 Cellular Phone
Problem monitor
Hi, Sounds either a backlight problem (inverter or tube light) or the display interface. Since you have confirmed that it is your LCD monitor, your best bet perhaps is to seek the services of a qualified professional. Should you venture in doing it yourself (DIY), You need to open up the casing. A step by step procedure is better illustrated here . The working principles of notebook/laptop displays are nearly identical to your LCD. Hope this be of some help. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 25, 2007 | Amptron CMV-922D 19" Monitor
Lexmark 4600 MFP Logo
321 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
