Question about RCA HD52W59 HDTV Projection Television
Tv hd52w59 rca
My rca tv am haveing issues with the menu screen appearing on tv,,it will appear and if i hit clear on remote it goes off but it will reapear,,,changed batteries in remote still problem,,,,have even taken batteries out to see if it was issue with remote problem still exist
  • Anonymous Jun 15, 2008
    I'm having the same problem with the menu box, but also with the volume control. They seem to be in competition with one another and finally the volume shuts down by itself and the only way I can get it back is to tap the
    volume control on my remote.
    The menu box flashes on the screen constantly.
Had that problem with a sony trinitron and the problem was the cords were pulling on the connections. I secured the cords so that no weight was pulling on connections and problems went away
Posted on Jun 13, 2008
    Master:
  • 518 Answers
Is there a Menu button on the set itself. Maybe it's stuck in, or something wet (like when cleaning the set) got into it. That's all I can think of. If there is, try pressing it several times, that may clear the problem.
Hope that helps...
Geno
Posted on Apr 04, 2008
Menu screen appears constantly, volume decreases by itself
Hi, common issue with rca sets, you need to replace the tact switches on the front control board. If your not good at soldering / un-soldering you may be able to still purchase the whole control board, call a local tv shop with the complete model # and chassis # of your set and they can give you price & availability, video-tek
Jun 02, 2009 | RCA HD52W59 HDTV Projection Television
Menu rca hd52w59
i have seen this problem at the shop. a few times the front panel has become damaged. replaceing this has resolved it for me
Apr 04, 2008 | RCA HD52W59 HDTV Projection Television
RCA 27V550T 27" TV
Problem fixed. I unplugged the TV for 20+ seconds, then before plugging it back in, I shorted ac plug prongs together with a metal key to ensure complete discharge. Plugged TV back in and used procedure to reset password WITH ONE CHANGE TO THE PROCEDURE.
With TV turned OFF press and hold <CLEAR> button on the remote while pressing <VOLUME DOWN> button on the TV, hold until TV turns on. When the menu appears DO NOT RESET THE PARENTAL CONTROL CODE as the user guide instructs. When my menu appeared it was in the SETUP screen on the LANGUAGE setting. It was set to SPANISH, using the remote I navigated to ENGLISH. Then using the remote I navigated up to GO BACK. Then I navigated to EXIT and hit <OK> button on the remote. All was back to normal.
Jan 10, 2008 | RCA 27V550T 27" TV
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Picture Fades
Here is one possible solution:
1. Go back there and get the remote for the RCA.
2. Towards the bottom right you'll see a "FORMAT" button. Press it and look at the screen each time.
3. This changes the screen format between Cinerama, 16:9, 4:3, and all the Zoom formats.
4. ONE of those should be what you're looking for...
Is there a way to reset this TV back to factory defaults through the menu?Try that. Otherwise it is a more serious problem. Call RCA to see if they can help.
Nov 20, 2007 | RCA HD52W59 HDTV Projection Television
Guide pop up
Maybe there is a setting for the guide in the main MENU settings to adjust when the TV GUIDE displays? Or just turn it off completely? Pretty basic answers, I know, sorry...lol : )
Nov 08, 2007 | RCA F36648 36" TV
RCA HD52W59 HDTV Projection Television Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
