Question about Yamaha RX-V661 Receiver
Yamaha RX-V861 Low frequency "flutter" after turning on
I get a low freq. distorted, scratchy flutter, even with no input from TV, CD, phono etc. I have Bose Accoustimass 10 series IV speakers, plust two Bose shelf speakers. Checked all connections, set subwoofer to lowest "volume" setting, nothing resolves this.
  • 979 Answers
How close to your video monitor is this rxr? It is not shielded well as far as sync circuits in your TV are concerned. Refer to manual...accordianman
Posted on May 01, 2008
Low sound from speakers sl1600 auto turntable.. preamp needed? Possible bad Rca's?
No. The RCA jacks are fine. Most likely, you are not using an amplifier with a PHONO input. A CD, DVD, AUX, etc.input if used, will give you a very low sound and poor frequency response(sounds tinny and low). You will need a PHONO preamp that can raise the output of the turntable to match that of the higher level, 300mv inputs mentioned above and have correction for the RIAA decoding to make the music sound correct. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Audio Players & Recorders
No volume from surround sound system on dtvcbl cable, dvd or cd modes with yamah rx-v861 powered on.?
Have you looked at the manual? How did it fare using the set up test tones? Did you assign the digital inputs?
http://www.retrevo.com/support/Yamaha-RX-V861-Receivers-manual/id/2526ci757/t/2/
The unnamed sources probably have manuals, too.
Apr 26, 2011 | Yamaha RX-V861 Receiver
Hav nad 2100. I dont understand what the lab in post are for?
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used.
http://web.295.ca/~peak//audio.html
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use them UNLESS you have a turntable source.
Feb 23, 2011 | NAD C325BEE Amplifier
I am trying to find the output power, watts?
bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
Jun 08, 2010 | Audio Players & Recorders
Turntable output level too low and plain compared to CD, etc.
Get an external pre-amp. They range in price from 25-100 and more, depending on the capabilities. All over Ebay, and electronics sites. That will fix your problem. Hope this helps
Jul 06, 2009 | Technics SL-BD20D Turntable
Audio from laptop to yamaha amp (rx-v18oo)to sony lcd
you will need a 3.5mm TRS minijack to stereo RCA (red & white)lead.
Connect the headphone-out of the laptop to a line input on the reciever - one of the following inputs should work: CD, CD-R in, Tape in. Do not connect to the Phono input
set the output volume of your laptop about 50% to avoid distortion.
As for connecting the amp to the LCD, it really depends what inputs your screen has, but if you can- run HDMI.
Mar 01, 2009 | Yamaha Audio Players & Recorders
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
Hooking up a Yamahoa RX-V861 without a manual
If you jump on the Yamaha web site you can download the manual which will show you how to connect the speaker system. Hope this helps.
Regards
Nov 17, 2008 | Yamaha RX-V861 Receiver
Yamaha RX V861 - Phillips DVD - No sound via digital coax
Does your TV support "Line In" or "Aux" or "External"? if so plug your "Low end" DVD directly into the back of the tv and verify that you Can get audio. Quite a few DVD players do have a mute feature. Be sure this is turned "off"...accordianman
May 14, 2008 | Yamaha RX-V861 Receiver
Hooking up playstation 3 to a yamaha rx-v861
have you set your toybox to the appropriate settings for the TV??
Jan 11, 2008 | Audio Players & Recorders
Yamaha RX-V661 Receiver Logo
174 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
