Question about Yamaha RX-V661 Receiver
Can't get sound with TV
Everything was fine until visitors came and then I have been unable to get surround sound or any sound with the tv.  I get sound via the tuner AM/FM but not the cable TV.  As I said everything was working so it isn't the hook up.  It's ME !!!!!  Between the TV remote, the tuner remote and the cable remote there has to be some easy way .  Can anyone help ???  Darniez
  • 979 Answers
Reset your tuner. Call the cable co for instructions...accordianman
Posted on May 01, 2008
SOURCE:
How to set up to my tv
Ok...sorry it took me so long to get back to you...Check the back of you tv and look for RCA jacks for audio and video out...There should be a yellow one for video..a white one for audio left(L) and a red one for audio righ(R)...you may not need the yellow one...now look for any inputs on the rear panel of the surround sound system...They can be marked (AUX)...they will work..once all of these are located...you will need an RCA patch cable long enough to reach from the tv to the surround sound receiver...once done...turn on the tv and the surround sound.With the remote from the surround sound remote...switch between the input sources..maybe (AUX) until you hear your tv sound come through...then you adjust the sound as needed...Assuming the DVD is built in to the surround sound system...your DVD sound will come back when you play DVD's...All connections and cables are color coded so you should have no problem connecting everything....Good luck....let me know how it goes,,,,I hope this was helpful....PEACE.....
Jan 05, 2012 | Audio Players & Recorders
I have hooked up my dish, yamaha receiver, CD player, blueray player and have surround sound for everything but the TV, Help!
Usually, unless the TV show is being broadcast itself in surround sound, the surround decoder in the receiver will default to front only sound on TV shows. When a TV show says that it is in surround sound, the receiver will decode it. I think the Law and Order series in broadcast in surround.
Hope this helps,
Best, Mark
Dec 30, 2010 | Yamaha RX-V463 Receiver
How can i get sound from my Tv to go through my surround sound.
If you are using a "cable box" or "sat receiver" the audio will go from the cable/sat to the surround system with either optical, digital coaxial or analog RCA to the TV input on your surround system. If it does not have an input specifically labeled "TV" you can use vid 1 vid 2 etc. just make sure that when you wish to listen to the tv on surround that the surround system is on the correct input.
If you are using just an "off-air" antenna, your cables would go from the TV "monitor out" which will be either optical or analog RCA to the surround system and the appropriate input. Hope this isn't too confusing, if you need more help, post a comment and I will help some more. Hope this does the trick
Jun 15, 2009 | Insignia NS-H2002 Theater System
Unable to get sound from tv to output from surround sound
as the tv stations that were being feed into the system were digital and the nput was actually analgoue 2 optical cables are required.
have tv sound and blue ray sound through surround sound when tv channels were changed to analague.
Mar 22, 2009 | Kenwood Audio Players & Recorders
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Hello and thank you in advance for helping me resolve this.... i have a insignia 52 flat screen tv.... i just installed a samsung ht z310 home theater... i tried everything and i cant seem to get the sound...
have you connected the optical cable. as the only way to get sound from the tv to the surround is via that link. the hdmi cable only send video and audio to the tv not both ways for some reason.
Jan 20, 2009 | Samsung HT-Z310T Theater System
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Mar 04, 2008 | Panasonic SC-HT680 System
6050 yamaha receiver issues
the problem is how you wired it, guess you plugged the ps3 directly to the tv. to hear the ps3 through surround sound, you would have to wire it through the reciever like everything else...
Jan 28, 2008 | Yamaha HTR-6030 Receiver
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Yamaha RX-V661 Receiver Logo
89 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
