Question about RCA R52WH73 Projection Television
RCA HD TV MOD D52W19
WILL NOT COME ON hi I actually have a similar problem, but know th reason why...We have an English Mastiff who decided to relieve himself (was ill) and when I came home, I flipped the tv on, there was sound but a black screen with a blue line...I shut it down asap and realized what my dog did. this is 3 days now with hopes it would dry out, but I still just get the green light for a couple of seconds, then it goes off, then on, etc. no picture and no sound...any advice ?? or did my lovely dog just cost me more money to buy another tv...ps only got this set about 4 months ago :(
  • dilucc Apr 04, 2008
    Hi yes we bought it brand new, but I figured the warranty wouldnt be valid because of the circumstances?? 350-500 ughhhhhhh...Is there anyway to do it myself?? thanks sooo much!!
    Hi he actually did it in the front, below the screen and in the middle of the bottom...I actually tried to dry it with a hair dryer and we opened the front, but now I am just at a loss
    Genius:
  • 1,030 Answers
Ok 4 months was it brand new when you go it. it may still be under warrenty. but chances are you have shorted out some high voltage component. averge cost to repair at my shop is 350 to 500.
Posted on Apr 04, 2008
  • Willie Howell Apr 04, 2008
    most likely warranty would be invalid....where did the damage occurr...
When using PS3 on RCA D52W19 TV, the screen does not fit ( it is zoomed and off-center) in 1080i resolution.
hello!
Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works.
good luck,
Alex.
Feb 16, 2012 | RCA D52W19 52" Rear Projection Television
We have a RCA D52w19 rear projection tv. It appears that the HD feature is not working. My Wii does not recognize it as HD and the picture for Wii, satellite and DVD is noticeably grainy. Is there an easy...
The Wii is not a HD output source. It only displays 480p. If you wish to connect an HD source, you must connect through an HDMI cable or a component Cable. HDMI is better.
Feb 28, 2011 | RCA D52W19 52" Rear Projection Television
Our RCA D52W19 TV is playing in standard 480dpi (Satellite, DVD, and Wii). How can we get it to play at 1080dpi, like it used to?
I have a RCA Home Theatre, gemstar guideplus gold. I think it is a 52" rear projection. I just want to know is it a HD TV?
It does not have an HD or ATSC tuner. But it does have HD resolution inputs - ie HDMI and component video (RGB) so effectively it is HD
Nov 24, 2009 | RCA D52W19 52" Rear Projection Television
RCA HD TV D52W19 does not turn on
Replace CP150 , CP120 and CP114. You can get the repair kit at www.tvrepairworld.com that has the capacitors and detailed instructions. Look under the RCA repair kits catagory.
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
My TV won't turn on.
If this is a RCA Picture Tube Rear Projection, the Deflection Board will cause this problem. I do not know though if it is available.
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Need circuit board
You might be able to get some help from the owner of the RCA name;   Thompson Consumer Electronics
Mar 01, 2009 | RCA D52W19 52" Rear Projection Television
52" RCA Rear Projction TV 1995
check cp 150 2200uf 16v, if bad there is 2 more caps in same circuit 220uf 35v.cp111 cp114
Dec 05, 2008 | RCA D52W19 52" Rear Projection Television
Rca hidef tv
Most likely a bad power supply module. The 3 tries is the 3 strike rule with the RCA TV's.
May 26, 2008 | RCA D52W19 52" Rear Projection Television
RCA R52WH73 Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
