Question about Neovo E-19A 19" LCD Monitor
Blackouts I have a E-19A monitor, while working on the computer the screen will just black out, (power light still green) wait a couple of seconds and screen comes back to life. any ideas?
  • jodyh4 Apr 04, 2008
    not sure about any of that stuff, both time delay boxes are checked and all of system failure is checked also. write debugging information is small dump (64kb)
    Genius:
  • 2,785 Answers
Have you checked your ram
Posted on Apr 04, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Apr 04, 2008
    why dont your try with other working ram if problem persist then check out with your power supply unit
My LG monitor blacks out intermittently when warm, I have tried it on another computer so it is a fault with the monitor. It blacks out every few seconds, sometimes it takes longer. It is 2 years old.
after blackout, check the screen as that. look in to the monitor in side angel,
and if you can see darken live image in that and its working. in that condition, your
LCD panel is working and the problem is no light.
in that case you need to repleace or repair the " inverter unit " in that monitor.
that unit makes the high voltage for back light.
after blackout , you cant see any darken image like as that, and or totally power
goes off , that is different problem. for solve that need advance trouble shooting
and can be need advance repair.
Jan 03, 2011 | LG Flatron W2243SPF Widescreen LCD Monitor
I got this monitor off of craigslist "because it didn't work". The VGA has never worked, but the DVI worked fine for several months. Recently, the screen goes black, the screen shows a 'no...
Check the VGA output pins on your computer. Install a different monitor and see if it works on your computer. Or it could also be the VGA cable (pins) on the monitor is loose.
Dec 16, 2010 | Neovo E-19A 19" LCD Monitor
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is...
skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Jul 31, 2010 | IBM ThinkVision L170 17" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
However if you wait 5-10 minutes and turn it back on, it will repeat itself...
I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
Monitor screen blackout
check for any DRY SOLDER , specifically around the INVERTER TRANSFORMERS on the PC board . hope it helps
Mar 28, 2008 | Computers & Internet
NO PICTURE
Bad power supply. The light is green when it is not plugged into the monitor because there is no load on the power supply. When you plug it in the monitor tries to draw current, nothing the PSU can handle now, so the light blinks. The PSU can not provide the amps that the monitor needs.
Get a new power supply, you can find them on ebay. Just make sure the voltage and amps match. It is ok to buy a power supply with a higher amp rating, the monitor will only take what it needs. Also make sure the power plug that plugs into your monitor matches.
Nov 16, 2007 | Neovo SX-19A (Black) 19" LCD Monitor
Monitor blackout thought green powerlights on
When your dell e173fp lcd monitor black out, the led power light are still green color. Normally, this will be the inverter board or ccfl lamp problem. May i know, after this monitor black out, do you have try use the torch light to see any display on the screen? (sometime the display are darkness only and not totally no display, you need see it clearly). Any details on repair lcd monitor please goto this website, http://www.fastrepairguide.com
Sep 01, 2007 | Dell E173FP 17" LCD Monitor
Screen black
Bill, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 06, 2007 | Samsung SyncMaster 910T 19" LCD Monitor
Screen is gone in half a second....
could be the lamps or the inverter board
Oct 27, 2006 | Neovo AG 17" LCD Monitor
Neovo E-19A 19" LCD Monitor Logo
243 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
