Question about Tappan TEF242 Electric Kitchen Range
Oven fuse blows - Nothing works
The 30 amp fuse for stove keeps blowing
Nothing works.
There's no display, no lights, the ranges don't work and neither does the oven
As soon as it's plugged in it blows.
I looked in the back and I cannot see anything obvious (ie where the wires might have shorted out)
  • RickNeedHelp Apr 07, 2008
    Thanks, good idea.
    Unfortunately I have not had a chance to try it yet, but it sounds like it will definately help.
    Sometimes you really need another opinion.
    President:
  • Tappan Master
  • 2,651 Answers
Try lifting the stove top assy and checking wires under main top, leading to the elements them selves??? if tis tripping and not allowing to reset its gotta be an obvious short. isit hard wired directly to stove or into a 220 cord and plug???id look again, perhaps remove entire back panel and have someone trip on the breaker you might see where it flashes as it trips off
Posted on Apr 04, 2008
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
We have a 40amp hot wired stove but now we just bought a frigidaire fef366dce with a 50amp. Will the new stove work well if hot wired to the 40amp
The new stove may work but you may also blow the breaker/ fuse which ever you have... make sure to leave the 40 amp fuses or breaker in the box as the wiring will not be heavy enough to support a larger amp. fuse or breaker... that will start a fire!
You may find that you just cannot run all of the burners and the oven or broiler at the same time.
heatman101
Apr 19, 2011 | Frigidaire FEF336BC Electric Kitchen Range
The control panel lights do not work nor does the oven. all the burners work fine this is a convection oven with a smooth top Gallery series
Check your main breaker in the fuse panel, it may be partially tripped. Turn the 40 amp breaker off and back on. if the display does not return to the stove, the I would suggest you contact a local servicer.
Aug 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
1984 stove, fuses located on the top of stove/ 30amp keeps blowin
It sounds like the element has a short in it. unplug the range, and take the element out and inspect if for burn marks. check the wires going to the element to make sure they have not shorted.
Jul 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
Apr 05, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Tappan TEF242 Electric Kitchen Range Logo
481 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
