Question about Garmin eTrex Legend GPS Receiver
Compass pointing in opposite direction
I use my GPS for geocaching and lately the compass has been pointing in the opposite direction I need to travel.  What is causing this and how can it be corrected?
  • Anonymous May 06, 2008
    Compass is reversed no matter the orientation of the unit.
  • Wonder Boy
    Wonder Boy Sep 30, 2017
    If you are not moving the arrow on the compass page will seem to point in all different directions. The 1st thing to do is calibrate your compass using the method described in your user manual. If there is no calibration method you will skip that. Now looking at your compass screen you will again see that the pointer points in all directions. But if you look at the circular graph around the compass that indicates N, S, E & W you will note that the compass points to a particular spot on that graph continuously. That is the direction you need to go. I always carry a real compass with me so that I can find north and then using both compasses I know which way to travel. Cache On.
  • Garmin Master
  • 638 Answers
Do you have your unit set for north up or track up? This might cause this problem.
Posted on Apr 21, 2008
SOURCE:
Sat nav on jag xf. the direction arrow on sat nav always points in compass direction of travel ie if going south then arrow points down over. is it possible to have arrow always pointing up like tom tom
the touch screen on the car should allow you to change the compass setting...I cant remmeber if yours has this but see if you can touch the compass on the screen display to make the direction allow of the car be in accordance with the cars real movement or north as you wish..Keep me posted
Sep 12, 2011 | 2010 Jaguar XF
The compass points in the opposite direction. While hunting in Ontario, I was lucky that I had a compass with me or I would still be there!
Electronic compasses tend to be very scuwy, your may need to be calibrated if not re calibrated to get the proper bearing.
Hope this helps!
Dec 08, 2010 | Garmin GPSMAP 60CSx GPS Receiver
When I am in heavy timber and not moving at a good pace my compass points in the opposite direction it is supposed to. What am I doing wrong? When I walk down the road it works perfectly.
The Garmin 12 GPS loses sattelite reception in heavy woods and that's why it doesn't work properly. It's not a fault and you're not doing anything wrong. All Garmin 12s are the same.
Nov 08, 2010 | Garmin GPS 12 GPS Receiver
I have a Garmin 250 Nuvi. I would like to do some
No this is a road navigation only unit. For a cheap entry level GPS that you can use for Geocaching, take a look at the Garmin eTrex series. For a top of the line, consider a GPS60csx or the new Oregon series from Garmin.
Mar 12, 2010 | GPS
My sat nav shows opposite direction map
Binatones run igo. I would recommend finding the latest software and trying an update - then see if the problem still occurs. There is also a setting in the map view for making the map change to the direction of travel - this may be causing an issue.
"austech" is a good place to start.
Feb 19, 2010 | Toymax Binatone Carrera X350 Car GPS...
How do I calibrate my compass in the eTrex Venture HC. The book says to go to the tje menue and then press calibration. My GPS does not give me this option.
I will be happy to help you with this. Unfortunnately, the Etrex Venture does not have an Electronic Compass, therefore you cannot calibrate it. What this means is that this unit will show the correct direction of travel as long as you are moving. The unit takes satellite reading every 1 seconds and compares it's location with the last location. This way it can read the direction of travel. It will not give correct readings unless you are moving.
I hope this helps.
Dec 31, 2009 | Garmin eTrex Venture HC GPS Receiver
Etrex vista cx
Hi, the DOT (Direction Of Travel) arrow will only appear on the Compass page when you are navigating.
  1. Go to the 'Main Menu'
  2. Select 'Find'
  3. Select 'Waypoints'
  4. Select a waypoint
  5. Select the 'Go TO' button
Once you are on the Compass page you should have the DOT arrow as long as you have a sat lock.
Jun 22, 2008 | Garmin eTrex GPS Receiver
Compass deos not point north
do a calibration. press the menu button while on the compass screen and select calibrate.
Jun 07, 2008 | Garmin eTrex GPS Receiver
60CS
Your electronic compass is probably turned on, and if so, either it is not calibrated or you are not holding the GPS unit level.
Try turning off the electronic compass by holding the PAGE button in for a couple seconds. With the electronic compass turned off, the GPS will instead show direction of travel using the current track, which is probably what you are expecting.
Cheers!
May 30, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
185 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
