Question about Motorola Mobility C168 Cellular Phone
Greeting and dial color
How do you change the greeting on the main page from at&t to something else and how do you change the color of the numbers when you dial??????
Built-in ic or program cannot change
Posted on Apr 06, 2008
Our school has a Siemens 500 OptiPoint 500 advance phone that has a greeting one. Can't find out in any of the manuals as to how I can go about changing it. Can anyone out there help me?
We always programme the voicemail to 555. If you have something different change what is below, which is our 'one sheet' user guide from www.dschiltern.co.uk
All Types of Phones
1. Your mailbox number will be the same as your extension number.
2. Default password is 1 2 3 4
3. Voicemail group number is 555 (unless programmed differently)
Before callers can leave voicemail messages you must activate your mailbox and record your greeting message. We would suggest something along the lines of
"You are through to the voicemail of . . . . I am sorry I am unable to take your call at the moment but please leave a message after the tone and I shall get back to you "
To Record Your Greeting Message
1. Dial the voicemail group number (usually 555)
2. Enter your password (default is 1234)
3. Keep pressing 3 to scroll to greeting messages
4. Press 8 to toggle between your two greeting messages
5. Press 0 to change the message and follow the instructions.
To leave voicemail just press 'Release' or hang up.
Responding to Voicemail
On a display phone you will see "You have messages" on the top line and "Display messages?" on the bottom line. Press tick twice to go to voicemail and then enter your password.
On Siemens 'Entry' phone or display phones with a 'voicemail' button, just press this button and enter password when asked.
On ordinary analogue phones you will get broken dial tone. Dial the voicemail group number (usually 555) and enter password.
In all cases you will then be able to listen to your messages.
To delete a message press 0. It will ask you to confirm by pressing 0 again.
Sep 17, 2014 | Siemens optiPoint 500 Advance - Corded...
How do you set up voicemail on the Panasonic KX-T7636 system?
1. Raise the handset on any telephone in the Panasonic Telephone system.
2. Press the "INTERCOM" button and dial 165.
3. When answered by the Auto Attendant, dial # XXXXX * 9 9 8.
(Pound Six Star Nine Nine Eight)
4. Enter the Administrator Password. Followed by a #. (Pound) If required.
5. Dial 5 to "Modify Message"
6. Dial 1 to "To Change The Company Greeting"
7. Enter the Company Greeting Number from 1 to 32.
If you are not sure of which Company Greeting Number to change, then start with 1.
The Panasonic Voice Mail system will actually play the greeting to you.
Then you can determine if it is the correct one you want to change.
If it isn't, you can dial 2 and move on to next greeting and so on.
If you select a greeting number where there is no greeting recorded,
the Panasonic Voice Mail system will prompt you to record one at that time.
You may dial *1 (STAR ONE) to skip recording and return to Step 7.
8. When you have found the Company Greeting you want to re-record
follow the system prompts to record and save your new greeting.
Note:
You can change the Company Greetings remotely from anywhere.
1. Call the main number of your business.
2. When answered go to Step 3 and follow the same procedures.
3. When completed....Hang up....
Aug 09, 2011 | Panasonic KX-T7636-B Corded Phone
Hi, I am having a problem trying to update my phone greeting on my Panasonic KX-T7633 . Can you assist?
This is an answer to the question you asked, how to update YOUR phone greeting. Either rate this as a FixYA (4 starts) or don't rate it at all if you're asking a different question.
When you dial into your voice mail from your phone, if you use 500, you're in your VM greeting and the lady says "enter password" or "you have xxx" messages. Option 31 and 1,2 or 3 for greetings. Note: If it says something about "temporary greeting" then select option 5 instead of 31 to change or delete the temp greeting. The other VM access code we use is 165 instead of 500. It's a left over number from the TD series systems.
If you have ESVM, where you can go off-hook and dial *383 to retrieve your messages, You access the recordings by dialing *382. If it starts to play back, then you need to consult your OM (Operating manual) or listen to the prompts to change your greetings for day and night.
Carl
Jun 23, 2011 | Panasonic KX-T7633 Corded Phone
T7316 Change recording of Company Directory
To re-record the main greeting on most Nortel voicemails, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
Jun 07, 2010 | NorStar T7316E Corded Phone
Changing main voicemail message
This may be specific for my system, but hopefully it helps:
Connect to your voicemail (for us, we can either hit the voicemail button or dial 1650)
Once in, press #6, it will ask for a mailbox number, dial *9998, it will ask for a password (the default is 1234#)
Press 5 to modify messages.
Press 3 to record custom service menus.
It will ask you to pick which menu (1-100). Our day menu is 1, and night is 2. I'm guessing yours will be the same.
From this point, it becomes the same as recording a standard voicemail greeting. It will play the current greeting and you can press 1 to re-record it. Do so, and then press #. Press 2 to accept and you're done!
Dec 24, 2009 | Panasonic KX-T7630 Corded Phone
Call Pilot voicemail Nortel
Depending what number your extensions start with, you need to go to the programming for the auto attendant and "undefine" the number in the menu. More than likely, it is built as a "thru-dial" and allows callers to punch in the extension. If you remove this, callers will have no other choice but to use the options in the menu. I can walk you through these changes if you want.
Apr 16, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Cannot change Main Voice Mail Greeting
after dialing 72 you must first hit the instr key in the display than dial 001 or 002.
Apr 06, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Need to change greeting
main system greetings can be changed via the administrator mailbox, dial your voicemail huntgroup number, on answer press the * key and supply the admin mailbox number which is usually 999 or 9999 the default pincode is 8642 then follow the voice prompts to change the system greeting.
Jan 30, 2009 | Mitel 5220 IP Phone
Need to change the greeting on my office phone from my home
you must call in to your main number and get the main greeting. Dial 632 for system manager, you must know the password to get in. listen for mgr options than for opening greetings option. remember 1=yes 2=no. ldtsnj.com can help
Dec 31, 2008 | NEC Electra Elite 32D-1 Corded Phone
How do I change the voice mail recorded message? How do I get a manual for this existing system?
IF you know the password for the mailbox then log into the voicemail by dialing the Stratagy access code, after Stratagy answers dial * , then your user ID mailbox number plus #, then your security code plus #. The User Main Menu plays, press 2 to change your greeting, the Select Greeting Menu plays, press the greeting number, the Record Menu plays, press 2 to record your greeting, Record greeting, as soon as you finish press #, the Record Greeting Menu plays, press 1 to review or 2 to re-record. Press 9 to save and return to the Select Greeting Menu and 9 again to return to the User Main Menu, hang up at this point.
Jun 08, 2008 | Toshiba DKT-2010 Corded Phone
Motorola Mobility C168 Cellular Phone Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
