Question about PSC PowerScan RF Base Station
PCS Powerscan problems
I have a PCS Powerscan that won't always scan a barcode.  The device with "beep" as if a scan was captured, but no data is detected.  Attempted in Notepad as well.  If I unplug the device and plug it back in, it then works, but only for a few scans.  The cycle then repeats itself.
I know it's not a distance issue with the Wireless device, since I am scanning right next to the Transmitter. I have PSC Model:Powerscan barcode scanner. It reads the barcode but seems too slow to recognise the barcode and does not capture the data.
help
  • 19,396 Answers
Clean the powerscan screen with solution, it may be dirty.
Posted on Apr 03, 2008
  • Ginko
    Ginko Apr 03, 2008
    They usually do this when the screen is dirty. You can clean it with a computer screen cleaning kit (cloth and solution). If this does not work the lamp inside the scanner may be faulty or opaque from use, and is not giving back enough light. In this case you will need to take your barcode scanner to a service and have the lamp replaced.
    Regards
I need to find the settings so I can ensure that it will scan all types of barcodes and not just ECC200.
Barcode scanners perform similarly as product data entry devices. Howver, each barcode scanner has a designe specication from the manufacture also considering the requested functionalities. For example, the barcode scanner is capable of capturing data either codes of producst however in situations that a retailer acquires scanners that least compartible to prior versions is incapable of being recognifigured at the retailers facility. Refer with an expert within store structure to derive most productivities either setting to capture an much to the convenience to product experts.
Mar 02, 2011 | Motorola (MC9596-KDABAE0000U) Wireless...
I was in the middle of an order and the red scaning light still working but will not scan the product, I downloaded what was on the scanner and that worked, but still not getting a beep after scanning the...
Push and hold down the big button for a while until it beeps. This scanner has a feature to disable the confirm beep that gets activated if you hold down the scan button too long!
Regards, Alan
Oct 05, 2010 | Opticon OPN 2001 Mobile Data Collector...
Could not active it the scanner on the MC9090
The link works for me DataWedge provides a convenient mechanism for non-scanning aware applications to receive data from embedded or connected data capture devices. It allows the user to capture data into any application that accepts keyboard input. It supports four types of Data Feeds: Barcode Scanners, RFID Tag Readers, MSR Readers and Serial Data Input. It provides user with text/hex data formatting and prefix/suffix facilities. Description
  1. New Test and Log Display.
  2. Improved DataWedge Startup Time for MSR and RFID
  3. Gen2 RFID Support
  4. Device enable/disable persistence over cold boot
  5. Virtual Key Support in Prefix/Suffix
  6. Performance improvements for MSR
  7. Enable Serial Interface on startup
  8. Support added for Event based Serial reading.
  9. Delays regarding RFID are fixed.
  10. Several Barcode character mapping issues fixed.
make sure some security software is not blocking your access
Jun 22, 2009 | Symbol MC9090 Barcode Scanner
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
LS 1902 AND USB CONNECTION
Scan the Set all defaults barcode from the product reference guide and set the scanner to use USB again if required. This should sort out your problem.
Mar 18, 2009 | Symbol Cobra LS1902 Handheld
I think you most change the config from RS-232, have the bes speed.
try!
Oct 30, 2007 | PSC PowerScan RF Base Station
PSC PowerScan RF Base Station Logo
521 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
