Question about Dell Dimension 4600 PC Desktop
Computer needs ethernet card for highspeed internet
What types of ethernet cards are compatible with this computer and a Motorola DSL modem ( style MSTATEA)? Is there an external adaptor that can be used to make this computer ethernet ready?
Thanks,
Amy
    Problem Solver:
  • 12 Answers
It depends on your computer and your operating system, but generally if you have USB ports with a Windows-based machine, then you can use a USB ethernet adapter. You plug the adaptor into your USB port, then the ethernet cable into the adapter.
Almost any electronics supply store ie Circuit City, Best Buy, plus Walmart and other big discount stores carry USB Ethernet Adapters. You can also try your local mom 'n' pop computer supply store.
http://www.dlink.com/products/?pid=133
I'm posting a link to a DLink adapter as an example *only.* There are other brand names out there that would probably do just as well.
Hope this helps!
Posted on Apr 03, 2008
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
Tip
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
Procedure:
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
Cannot connect to internet. I had internet connection over telephone modem before Hard drive crashed. I replaced HD and could not connect to internet. Dell was no help at all. I signed up for Verizon DSL...
I bet you are using the phone modem that canme in your machine. You need to connect the Network card ( Ethernet Card) and make sure the drivers are working. Find it is System, Hardware, device manager, look for ethernet.
Connection icon and see if the netcard driver is installed.Connect the cat5 cable that was sent to you with the DSL modem box. It chould be a yellow cable... It only fits one way and in a maked plug on the DSL modem and into the network card in the computer. Everything there after should go automatically.
Jul 24, 2009 | Dell Dimension 4700C PC Desktop
How to connect DSL internet to the second computer
You need an ethernet card, either hard wired or wireless to connect your computer to the DI-624.
Jun 13, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Ethernet card
hi there. The ethernet card is an interface that allows your computer to be connected to a LAN (Local area network) and to a Cable/Dsl modem to be on the internet. The connector looks bigger than the one of a regular telephone jack (it's actually double). If you don't have the ethernet card you can't go on the internet or on a LAN.
From the back of the modem or router you should connect a cable to your ethernet card of yor computer. Only after you did that you can try to connect to the internet.
Let me know, or be more specific.
thanks
Mar 30, 2009 | Dell Computers & Internet
Internet promplems
for dial up simply a modem .... on laptops if you do not have a builtin modem you can purchase a pc-card modem that goes into your pcmcia slot ... for highspeed either a ethernet (same option as modem) but almost all modern laptops have a built in ethernet ... or usb ... also I highly recommend a router if you are going highspeed ... even if you only have one computer ... a router will protect your system because it provides a NAT firewall. If you go with a router make sure to set up the internet connection on the router do not tunnel through the router with a PPPoE connection
Mar 30, 2008 | Computers & Internet
Internet Connection
A few years ago, i too had an IBM thinkpad and encountered some issues as well when connecting to the internet.
The IBM 2647 does not have a built in wireless card, meaning that you need to purchase one from your local electronics store to use wireless internet. The software provided with these CD's can often be quite helpful and will help you set up the connection.
The 2647 only supports an analog modem connection, and the modem in the area you are attempting to connect via ethernet may use a digital modem. Adapters are available although they are quite pricey (ranging from $200 and up.)
Hope this helps.
FerrariXP
Mar 10, 2008 | IBM ThinkPad T20 2647 Notebook
I JUST GOT A COMPAQ LTE 5300 AND CANT CONNECT TO THE INTERNET DO I NEED A ETHERNET CARD?
if you don't have one. yes, you do need some type of network card in order to go on to the Internet by way of modem. (DSL, higspeed, dial-up).
what pc do you have and what operating system ???
Dec 10, 2007 | Internet KM-2501P Enhanced PS/2 Multimedia...
Dell Dimension 4600 PC Desktop Logo
138 people viewed this question
Alun Cox
