Question about SmartDisk 160GB FIRELITE PORTABLE FIREWIRE HARD DRIVE 5400 RPM 2.5IN 160 GB FireWire 400
Formatted hard disk on pc now it won't run on mac
I formatted my new 160gb smartdisk firelite external hard drive on my work pc with the intention of deleting the back up software that is factory installed. I can now access that drive from my pc but not my mac. What is the solution?
    Scholar:
    New Friend:
  • 27 Answers
Format it into HFS or HFS+ file system.
Posted on Jun 15, 2012
  • 341 Answers
Try plugging your hard drive into your mac, open "Disk Utility" select your hard drive in the list on the side, Click RAID, change the Volume Format to MS-DOS (FAT), and it should work.
Hope this helps!
Posted on Aug 24, 2009
SOURCE:
How to transfer 57 gigs from a mac to firelite xp.
The hard drive maybe formatted in Windows NTFS format and the MAC cannot see this formatted hard drive.
If you only wanr to use this hard drive on a MAN then you need to format this hard drive with your MAC.
If you want to exchange files between your MAC and a PC then you need to format the hard drive on a PC in FAT32. The MAC can read and write to a FAT32 formatted hard disk.
May 30, 2012 | SmartDisk FireLite 80 GB Hard Drive
Firelite smartdisk does not mount on my Mac
Your drive may be in NTFS file format that is not supported natively by your mac, try looking for NTFS support or reformat your drive to FAT32.
May 02, 2012 | SmartDisk CrossFire Desktop FireWire/USB...
Reconfigure firelite for PC
you will need to reformat the drive. it sounds like it was just formatted for MAC only.
to do this open computer management and select disk management under storage. select the firelite drive and click format. please note these are settings for windows 7.
Feb 13, 2012 | SmartDisk FireLite 40 GB Hard Drive
Will a Smartdisk Firelite 120 GB external Hard drive work on both PC and Mac?
Yes. To be used on both it will be best to format it on the PC as the PC and the Mac will be able to read it. But if it is formatted on a mac, the PC will not be able to read it.
Feb 11, 2012 | SmartDisk FireLite USBFLB120 120 GB USB...
How do I reformat my smartdisk firelite external hard drive for my new mac?
Go to the applications folder and then utilities open Disk Utility in the left box select you firelite and then clcik on the erase tab to your right. You can then select how you are going to format the hard drive standard for using with Mac only machines is Mac OS Extended (Journaled) or if you want to use with both PC and Macs is MS-DOS (FAT). Then name your drive and click on erase. Hope this helps.
Feb 01, 2011 | SmartDisk FireLite 80 GB Hard Drive
MY Apple computer all of a sudden is not recognizing my 160GB Firelite. It has power but when plugged in the icon won't appear on the desktop and I can't access the drive? Was working earlier in the day.
Try going to utilities in the applications folder, in utilities select disk utility and see if the drive shows up, if so select repair disk after selecting the SmartDisk. If not showing select your hard drive and run repair permissions and see if it helps. Failing this you need a 3rd party disk repair solution like DiskWarrior. The information is still there!
Feb 22, 2010 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
External hard drive not recognized
where can i find the software for my smartdisk firelite 160gb
Dec 18, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
I want to reuse this drive on a new MAC, how do I clean the old information off the drive?
Do you want to use it as an external USB hard drive?
If so connect it to a USB hard drive adapter case and connect it to the MAC and either delete the folders and filed OR format the hard disk.
Nov 25, 2009 | SmartDisk FireLite 80GB 400Mbps FireWire...
I'm having problems connecting FireLite portable hard drives to my mc.
1. Check operating system version sometimes its just the version not all mac versions like externals.
2. Under disk manager if the drive does not appear 9 times out of 10 its not compatable with the os your using.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 17, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
May 24, 2009 | FireLite (USBFLB80) Hard Drive
Open Questions:
SmartDisk 160GB FIRELITE PORTABLE FIREWIRE HARD DRIVE 5400 RPM 2.5IN 160 GB FireWire 400 Logo
192 people viewed this question
Top SmartDisk Computers & Internet Experts
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Kris
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
