Question about Zyxel Prestige 660R Router (91004397002)
Connecting using wireless
Zyxel p-660R works fine when connected directly PC but when linksys wireless router WRT54GL connected between zyxel and pc unable to access internet neither can the wireless pc. linksys router works fine when connected to another pc and router at different house with no setup
  • Aimed May 07, 2008
    I have exactly the same problem as he/she described it!!!
  • Anonymous Mar 15, 2014
    Cannot get connection with Samsung smart tv and zyxel P-663HN-51 router. Finds connection, then gives following msg "ERROR_MODEL_BIND
I don't believe Zyxel supports only Zyxel products. Finally, after analyzing the problem between the zyxel and the router, I found a solution that worked and allowed me to network both wired and wireless connections here at home. Set your router to auto-dhcp settings. Clone the MAC address of your computer. After this is done, put OFF first the router but make sure that the cable from the router WAN port is attached to the modem already. Then, put ON the zyxel and wait until it is fully functioning (2 lighted LED lights) before you switch ON the modem. Let both units (router and zyxel modem)synchronize first about a minute or so. Then connect/put ON your computers.
I found the above procedure to do it step by step so as to avoid conflict signals during synchronization which seems to be causing the non-internet connection.
Hope this helps!
Posted on Jun 17, 2008
  • 611 Answers
Because of zyxel support only zyxel product only
Posted on Jun 13, 2008
  • kalpesh jain
    kalpesh jain Jun 13, 2008
    first try it for zyxel router
    second tp-link adsl2+router to linksys is work that two way only.
  • kalpesh jain
    kalpesh jain Jun 24, 2008
    can you give me the calraification of the modem zyxel and which connection you using, pppoe,static,or dynamic,
    at first you using pppoe then go to the linksys router. give the pppoe connection and give the user id of the isp given to you after then give the ipaddress which isp give and dns also after then save it and reboot it.
    second thing is in static ipaddress give the dynamic ip address and give the dhcp enabled in the dhcp give the dns value also.
    when you use the internet for then you give the obtian ipaddress and obtian dns.
    in dynamic do same at the static.
I have a ZyXEL EQ-660R-F1 and a Linksys Wireless Router (B BEFW1154) that I'm trying to hook up. Can you tell me what I need to do?
Who is your ISP (internet service provider)? Anyway, it is possible to get your set up working. ZyXel is the DSL modem gateway and Linksys, your router/wifi. If you are able to get online by hooking up directly to the Zyxel, then it is possible to add the Linksys to the system.
Dont hook up the Zyxel to the Internet port of Linksys just yet. First you have to configure the Linksys by connecting your PC to it with a cable. Boot up the PC.
Open web browser and enter the address 192.168.1.1 and hit enter. This is the default address of the Linksys. username = admin and no password. It is probably the same as the Zyxel which causes the conflict.
The first set up page may look something like this below.
Change the LAN IP address from 192.168.1.1 to 192.168.2.1
Then click apply...From now on the Linksys IP address is 192.168.2.1.
Now you can connect the Linksys internet port to the Zyxel. Reboot the Linksys and Zyxel.
Your PC should be on the internet after that. To check/setup wifi, you need to log back into the Linksys using the new adress x.x.2.1
Feb 15, 2013 | Zyxel Prestige 660R Router (91004397002)
Connecting a Linksys WRT54GL. no internet connection detected
The ISP modem connects to the main LAN port on the router. The PC connects to any other port. Done. You should have internet via wire at this point.
Feb 12, 2013 | Linksys Wireless-G WRT54GL Router
DNS server not responding on WRT54GL Linksys router
You are looking for DHCP server. It provides the IPs addresses for devices to connect. DNS resolves the IP into a name. Not really required unless you are setting up a virtual server, or the special setup.
I have a ZyXEL P-660R-D1 router connected to my Linksys Wireless-G 2.4 GHz Broadband router and I'm having a few problems. First, the internet light on my ZyXEL won't light up EVER. I am not sure if that...
First of, unplug your Linksys and go right into your ZyXEL, (you might need to run a cable) Run that way for a while, If your not cut off then it's your router. Do this first and we can go from there.
Dec 22, 2010 | Zyxel Prestige 660R Router (91004397002)
I using zyxel P-660R compact series but I can't logging to my broadband because error 815
error 815 is a dial up error. open control panel, then internet options and click connections at the top. remove every connection in this list. Your pc is trying to use a dial up modem and not a router.
Apr 11, 2010 | Zyxel Prestige 660R Router (P660R)
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Can't access adminpage of the router from the 1st lan
you can use ethernet cable, or you can use the wireless.
search for the wireless network and connect your pc to that wireless network. or simply connect an ethernet cable to your pc and connect other end to the Linksys WRT54GL .
open an internet explorer (or whatever you use) type ip address.
Dec 17, 2008 | Computers & Internet
Can we configure in a notbook directly wrt54gl using wireless without a PC ?
You can have multiple computers connected to the router. What seems to be the problem.
Oct 02, 2008 | Linksys Wireless-G Broadband Router
EMbarq/Zyxel 660R/eHarmony/Windows Don't Play together well
Upgrade to the latest firmware on the modem, disable the modem firewall, or bridging the modem will resolve this
Sep 03, 2008 | Zyxel Prestige 660R Router (91004397002)
Zyxel Prestige 660R Router (91004397002) Logo
887 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
