Question about Dell Dimension 3000 PC Desktop
Taking forever to reinstall XP Home Edition
1.) I get an error message: INF INSTALL FAILURE REASON: The Handle is invalid
2.) I can't get to advanced setup to try to clear NVRAM
    Sergeant:
  • 318 Answers
To clear the NVRAM, perform the following steps:
Restart your computer.
At the first text on the screen or at the Dell logo, press the <F2> key every three seconds until the message Entering Setup appears.
The System Setup screen appears.
Press the <Caps Lock> key, the <Scroll Lock> key, and the <Num Lock> key to light up all three lights on the keyboard.
Press the <Alt> and <E> keys at the same time.
The system will emit a beep tone to indicate that NVRAM has been cleared.
Press the <Esc> key, and then press the <Enter> key to save the changes and reboot the system.
Proceed with the installation or troubleshooting that you were attempting
Posted on Apr 05, 2008
6ya staff
SOURCE:
Occasionally I receive a message when I am trying to download or install a programme etc. The message tells me to insert the Windows XP Home Edition disc? The problem is that my PC was purchased (from PC...
I think you have these options:-
1. Explain your problem to PC World and see if they can help.
2. Borrow a Windows XP Home Edition disc from a friend.
3. Download a Windows XP Home Edition disc from the internet. I don't know how legal this is, but as you have already got the legal copy installed and are only using the disc to install other programs you might be OK.
Oct 30, 2009 | Microsoft Windows XP Home Edition
Error 1335. The Cabinet file Data1.cab required for this installation is corrupt and cannot be used.
When you try to install Microsoft Office 2000 or Microsoft Office XP, you may receive the following error message: Error 1335-Cannot copy cab file Office1.cab. The file may be corrupt. When you start the computer in Safe Mode and then try to install Office, you may receive the following error message: The Windows Installer Service could not be accessed. This can occur if you are running Windows in Safe mode or if the Windows Installer is not correctly installed. You may receive this error message even when the Office CD-ROM package works correctly on another computer.
When you try to install Office while you are logged on to the computer with administrative rights, you receive the same error messages. uparrow.gifBack to the top CAUSEThis error can be caused by dirty media, CD-ROM read issues, or problems with me... loadTOCNode(1, 'cause'); This error can be caused by dirty media, CD-ROM read issues, or problems with memory allocation. uparrow.gifBack to the top WORKAROUNDTo work around this problem, try the following methods. Method 1: Clean the CD-... loadTOCNode(1, 'workaround'); To work around this problem, try the following methods. uparrow.gifBack to the top Method 1: Clean the CD-ROM loadTOCNode(2, 'workaround'); Use a soft cloth to gently clean the disc. uparrow.gifBack to the top Method 2: Change the memory settings for installation loadTOCNode(2, 'workaround'); To change the memory settings for installation, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the BOOT.INI tab, click Advanced Options.
  4. In the BOOT.INI Advanced Options dialog box, select the /MAXMEM= check box, and then change the setting to 256 (or lower if your computer has less RAM).
  5. Click OK to close the BOOT.INI Advanced Options dialog box.
  6. In the System Configuration Utility dialog box, click Apply.
  7. Click OK to close the System Configuration Utility dialog box.
  8. Click Restart to the following message: You must restart your computer for some of the changes made by System Configuration to take effect.
  9. After you restart your computer, install Office as a Complete Install.
  10. After you install Microsoft Office, follow steps 1 through 8 to clear the /MAXMEM= check box.
uparrow.gifBack to the top Method 3: Install Office by using a flat folder loadTOCNode(2, 'workaround'); To install Office by using a flat folder, follow these steps:
  1. Clean boot your computer. For additional information about how to clean boot Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 310353 (http://support.microsoft.com/kb/310353/ ) How to perform a clean boot in Windows XP
  2. Save a copy of the Microsoft Office CD-ROM to your computer's hard disk. To do this, follow these steps:
    1. Start Microsoft Windows Explorer. To do this, right-click Start, and then click Explore.
    2. Create a new folder at the root of a hard disk volume, and then name it "Flatfile" (for example, C:\Flatfile).
    3. Locate the drive that contains the Microsoft Office CD-ROM, and then copy all the contents of the Microsoft Office CD-ROM into the C:\Flatfile folder. To do this, follow these steps:
      1. In Windows Explorer, click the CD-ROM icon (or DVD-ROM icon) that contains the Microsoft Office CD-ROM.
      2. On the Edit menu, click Select All.
      3. Paste all the files into the new folder. To do this, drag the selected items on the right side of the Explorer window into the C:\Flatfile folder on the left.
        Note If you receive the "This Folder contains "X" hidden files" error message, follow these steps:
        1. On the Tools menu, click Folder Options.
        2. Click the View tab.
        3. Turn on Show Hidden Files and Folders.
        4. Turn off Hide Protected Operating System Files.
        5. Click Apply, and then click Ok.
        Note If there are errors during the copy process, this can indicate problems with the CD-ROM (media), a dirty CD-ROM drive, or a problem with your hard disk.
  3. Restart your computer the way that you typically do, and then install Microsoft Office from the C:\Flatfile folder onto your hard disk.
uparrow.gifBack to the top Method 4: Install only one Office program loadTOCNode(2, 'workaround'); Install only one Office program, such as Microsoft Access. To do this, select a Custom install, and then cancel the selection for all but one of the Office programs. If the Setup program is completed successfully, restart the Setup program. Restarting the Setup program will take you into Maintenance mode. Click Add/Remove Programs, and then click the programs that you did not install in the first installation of Office. uparrow.gifBack to the top Method 5: Contact Microsoft loadTOCNode(2, 'workaround'); If the previous methods do not resolve the problem, contact Microsoft. For information about how to contact Microsoft, visit the following Microsoft Web site: http://support.microsoft.com (http://support.microsoft.com/) uparrow.gifBack to the top APPLIES TO
  • Microsoft Office XP (Setup), when used with:
    • Microsoft Windows XP Professional
    • Microsoft Windows XP Home Edition
  • Microsoft Office 2000 Premium Edition
  • Microsoft Office 2000 Professional Edition
  • Microsoft Office 2000 Standard Edition
  • Microsoft Office 2000 Small Business Edition
  • Microsoft Office 2000 Developer Edition
  • Microsoft Access 2002 Standard Edition
  • Microsoft Excel 2000 Standard Edition
  • Microsoft FrontPage 2000 Standard Edition
  • Microsoft Outlook 2000 Standard Edition
  • Microsoft PowerPoint 2000 Standard Edition
  • Microsoft Word 2000 Standard Edition
Sep 15, 2009 | Computers & Internet
I have an eMachine T3410. When it boots, a screen
your missing the biosinfo.inf. try reinstalling the system but backup everything you need first.
Jun 09, 2009 | E-Machines eMonster 600 PC Desktop
Problem reinstalling XP
Wow, sadly Your CD is corrupted. You need to get another good one. It is caused by scratches on the cd that he complains he can't read the file.
Jun 09, 2009 | Microsoft Windows XP Home Edition
Autorun.inf virus prob.
go to start button and press run option type cmd type cd\  2. type c: and press enter
3. type attrib -r -h -s autorun.inf
4. type del autorun.inf
Apr 01, 2009 | Microsoft Windows XP Home Edition
System Crash or Freeze
XP home edition should be very stable when install properly.. I suggest you scan for PC invalid registry.. below link might be able to help on this issue.
http://etech.maiila.com/repair-kernel-32-errors-and-fix-dll-file-error-messages
Good Luck!
Nov 05, 2008 | Microsoft Windows XP Home Edition
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
UNABLE TO REACH DESKTOP
loadTOCNode(1, 'symptoms');-------------------------------------SYMPTOMS:------------------------------------
When you restart your computer after you install Windows XP Service Pack 1 (SP1), your computer may generate the following Stop error message:
STOP: 0x00000050 (0x8872A990, 0x00000001, 0x804F35D7, 0x00000000)
PAGE_FAULT_IN_NON-PAGED_AREA
----------------------------------------CAUSE:-----------------------------------------
loadTOCNode(1, 'cause'); This problem may occur if there is a conflict between Windows XP SP1 and the display adapter drivers that are currently installed.
------------------------------------SOLUTION :---------------------------------------
loadTOCNode(1, 'resolution'); To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail: 1. Start Windows in Safe mode. To do so: a. Restart the computer, and then press F8 while the computer starts. b. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER. c. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode. 2. In the message that states that Windows is running in Safe mode, click Yes. 3. Click Start, click Run, type msinfo32 in the Open box, and then click OK. 4. Under System Summary, expand Components, and then click Display. 5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf. 6. Quit the System Information utility. 7. Click Start, right-click My Computer, and then click Properties. 8. Click the Hardware tab, and then click Device Manager. 9. Expand Display adapters, right-click the display adapter, and then click Uninstall. 10. Click OK. 11. Click Start, click Run, type cmd, and then click OK. 12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old 13. Close all open windows, and then restart the computer in the typical manner. 14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware. 15. When the Found New Hardware Wizard starts, click Cancel.
If you receive a stop error after you remove the updated display drivers, restart the computer and use the Last Known Good Configuration option. To do this, restart the computer, and then press the F8 key while the computer starts. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Last Known Good Configuration, and then press ENTER.
If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.16.Obtain and install the latest drivers for your display adapter.For information about how to contact computer hardware manufacturers, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi - (Technical Associate)
May 07, 2008 | Compaq Armada 1700 Notebook
"a service installation section in this INF is invalid"
If the player is showing up in your Windows' Device Manager under "portable devices" with a yellow "!":
1.) Right-click the yellow "!" and choose "update driver".
2.) When given the option to connect to Windows Update, choose "no, not this time" and click next.
3.) Choose "Install from a specific location (advanced)" and click next.
4.) Choose "Don't search. I will choose the driver to install" and click next.
5.) Click the "Have Disk" button. Browse to C:\Windows\inf and choose the file marked "wpdmtp.inf"
I can't believe the generic players have such crappy support when so many people have this problem! I think the Windows file problem might be caused by "compressing old files" when you do a disk cleanup.
Oct 15, 2007 | RCA OPAL M4001 MP3 Player
Dell Dimension 3000 PC Desktop Logo
895 people viewed this question
Ekse
Clive
Clive
Alun Cox
