Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Filter for the water dispenser
I have a new conquest side-by-side refrigerator. The indicator light is on showing that I need to change the filter to the water dispenser. However, the manual doesn't 1) tell me where this filter is located and 2) what filter I need.
  • 2 more comments
  • troybuck Apr 07, 2008
    How do you change the filter nothing in manual
  • Anonymous May 11, 2010
    Get me your full model and serial numbers from inside of the fridge.
  • Anonymous Mar 12, 2014
    changing the filter on my refrigerator. A light went on indicating a change
  • Anonymous Mar 13, 2014
    Don't know how to turn "filter needs changed" light on refrigerator after changing water filter
    Novelist:
  • 184 Answers
LOOK AT THE TOE PLATE BELOW THE DOORS. THERE SHOULD BE A ROUND DIAL UNDER THE FREEZER DOOR.
TURN IT COUNTER CLOCKWISE ONE QUARTER TURN AND PULL IT OUT. THE DIAL THAT LOOKS LIKE PART OF THE TOE PLATE WILL SLIDE OFF THE END OF THE FILTER. YOU CAN FIND A NEW FILTER AT MOST HOME IMPROVEMENT CENTERS OR YOUR LOCAL WHIRLPOOL DEALER.
Posted on Apr 10, 2008
SOURCE:
My neff is not giving any water, I have changed new filter still light shows fix filter?
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you this it is almost time to change your filter. It is recommended that you replace the filter when the status light changes to red, or when water flow to your water dispenser or ice maker noticeably decreases.
Hence, it's advised to check your water flow (pressure) is perfect. If your water flow is normal the indicator display will automatically be gone and also you will get water also. Please also check any tints orkinks in water hose, if it's correct it. Thanks, Helpful?
Feb 12, 2011 | Neff K3965XO Side by Side Refrigerator
Trying to reset filer light after changing filter-locked up
Here is a link to the manual for your unit. Copy paste into your browser.
http://shop.amana.com/assets/pdfs/literature/12591321.PDF
Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
DISPENSER LOCK
(SELECT MODELS)
This feature prevents ice or water from
being dispensed.
To lock dispenser:
➢ Press and hold DISPENSER LOCK
button for 3 seconds. A green
indicator light above button confirms
dispenser is locked.
To unlock dispenser:
➢ Hold DISPENSER LOCK button for 3
seconds. Green indicator light above
button will go out.
Filter reset
The filter status indicator light
serves as a reminder to replace the
water filter. A green light indicates that
the filter is in good condition. A red light
indicates the filter should be changed.
Once light turns red, it will remain red
until function is reset.
To reset indicator:
➢ Press and hold both DISPENSER
LOCK and WATER buttons
simultaneously for 4 seconds. The
green filter status indicator light will
flash 3 times when the function has
successfully reset.
Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
I just change my water filter on my whirlpool conquest refrigerator because there was no water getting through and the filter indicator said it needed to be changed. I changed the filter but the water...
1. did you let the water fill the filter it takes about a cup and a hlf on some let it run s asec
2. check to make sure you have water to the machine is it clogged at the intake
Oct 05, 2009 | Refrigerators
Changing the water filter
hold the filter light button down for about 6 sec
Jan 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispensing too slow.
The water filter might need changing. Make sure the water supply is completely on and has good pressure.
Oct 21, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Conquest water filter in my whirpool side by side
yes it is. as long as there is still water coming out from the dispenser.
the red light only indicates that it is about time to replace the filter. could be 6 months old. this is controlled by time, so check your water pressure at the dispenser, if it is still strong, then you could still use it .
depending on your condition, some filters would be clogged already even if the light is still green and there is no more water coming out of your dispenser.
normal time to replace the filter is six months.
tnx 4 using fixya,
drcool
Oct 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
777 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
