Question about Gateway FPD2275W LCD Monitor
Philips 170S4 white screen not display.
Had this white screen problem.My LCd monitor display flicker white screen ,no image at all.The Back light is working.Have try with other computer with same problem.Try pressing all the control button ,nothing display.
Pls someone out there help me with the problem.
Thanks.
  • adamni Apr 05, 2008
    Thanks alot for your help.Been searching for week for answer.You been a great help.
    Problem Solver:
  • 6 Answers
Its in the power suppy section,most of the lcd monitor has this problem,try to check the capacitor electrolytic or replace all th 16v capacitor
Posted on Apr 04, 2008
There is like haze spot
LCD Panel White Spot Cleaning Technique - YouTube
? 4:13
https://www.youtube.com/watch?v=0OzjLMKFYk8
Jun 9, 2012 - Uploaded by joegingCA
Simple Technical procedure on how to remove a white spotproblem of an LCD Panel. ... Don't like this video? ... How to remove liquid spots from LCD screen - Duration: 5:16. ... Building a liquid crystal display (LCD) - Duration: 13:49. ... 2:18:17. Samsung/Mitsubishi/Toshiba DLP TV Repair - Black & White ...Missing: 170s4fb ‎haze
LCD TV - Problem with white glow seeping in from edges - MyBroadband
mybroadband.co.za/.../349324-LCD-TV-Problem-with-w...
MyBroadband
Jul 12, 2011 - 15 posts - ‎9 authors
Results 1 to 15 of 17 ... After googling it seems this is quite a common problem withLCD panels, though I .... Earlier this year I read that Philips have sold off their LCD TV... Yeah, something like that, unless demo stock is treated differently? ... bleeding from the edges as well as in the middle of the display.Missing: 170s4fb
How to Fix LCD Monitor Ghost images - MadeByMark.com
Jan 14, 2016 | Philips 170S4FB 17" LCD Monitor
I have a 2002 Philips 150B2 and when I plug it in it doesn't turn on at all. The light for the power button doesn't even come on. Any suggestions on what is wrong with it. Thanks,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 11, 2015 | Philips Televison & Video
Tv problem troubleshooting screen all white no picture
- Flickering screen
- Dim screen
- Slow start
Apr 08, 2014 | LG Televison & Video
Smart image on philips lcd on screen
Dont Buy Philips monitor. I have 20 pcs monitor and after one year half of them had malfunction. smartimage with vertical lines back and forth and that all controls are locked that cant be unlock by holding any button. Some had white screen when Resolution exceed 1024X768 (when 1280X768) after a year.
Maybe they program it to malfunction after a year. My CDR king and AOC monitor had no problem 2yrs to present date.
Philips monitor are garbage
Sorry for bad english.
Sep 22, 2011 | Philips 220CW8FB 22" LCD Monitor
I have a Philips 170S4. On startup it displays the memory check fine. Then everything goes black, the green light indicating the monitor is still on is still lit up. I can only JUST see some pictures on...
did you adjust the brightness, also in windows settings?
pls check with another monitor ,also you can check monitor with another pc or laptop
try with reset the monitor settings
also change the resolution and display frequency
Oct 03, 2017 | Gateway FPD2275W LCD Monitor
No video image on LCD but OSD works
Sounds like you may have a bad video cale or a dmaged or bentpin in the connector, remove the cable from the monitor and look at the pins on the connector
Dec 14, 2009 | Philips 170S4FG 17" LCD Monitor
OSD problem
Hi, To unlock the OSD menu, press and hold the MENU button for 10 seconds.
Hope this solves your problem Thanks.
Aug 05, 2009 | Philips 150S4FB 15" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
Monitor is Flickering and screen becomes pink
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it goes back to white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 10, 2008 | Acer AL2017 20" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
1,139 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
