Question about ASUS A8N-E Motherboard
Cpu fan noisy/chip fan fail error messages
my cpu fan has become noisy intermittently though. asus probe shows temp of cpu normal (42-43 c max). changed bios settings for cpu fan from 1200 rpm to 800 rpm. error messages"cpu fan fail or speed too low" even after that.suddenly new error message "chip fan fail or speed low".after visually checking it i found out that the chip fan spins some times and doesn't other times. the message frequency has increased to almost everytime i boot nowadays. does the problem lie with cpu fan/chip fan /smps. the voltages are in normal range (as shown by the probe). the frequency of cpu fan from 3600-4400 rpm. the chip fan when detected runs at 4500 rpm -5500rpm. the noise of the cpu fan is usually accompanied by drop in chip fan rpm count.the count rises when the sound of the cpu fan dies down.
i have been advised to change the cpu fan. i want to make sure the problem lies with the cpu fan. plz suggest.
  • 4 more comments
  • pils Apr 06, 2008
    hi airmack,
    thank you for the reply. my chip fan has started failing more often( it doesn't run). there is no noise from the cpu fan when the chipfan fails.i have started to wonder whether it is an loose connection or the chip fan which is the problem. will post the end result.
  • pils Apr 08, 2008
    hi there,
    fan noise from chip fan after all. a spray of WD-40 took care of the problem. ty for your time.
  • pils Apr 09, 2008
    hi again,
    i think i jumped the gun while thinking the problem was solved. the chip fan still makes noise. do u think i need to change the fan? if yes, is it available over the top?
  • pils Apr 10, 2008
    hi!
    the problem isn't with the cpu fan. it is with the chip fan which comes with the motherboard. my mb is asus A8N-E, with an athlon processor 3000+ socket 939.
  • pils May 15, 2008
    hi !
    installed a heat sink. the motherboard temp now goes to to abt 48-50 celcius. is it alright? i have a feeling tht the temp has gone up by a couple of notches.
  • pils May 22, 2008
    hi!
    very true. it does remain in the "safe zone" normally . just worried when i start playing games. ty for the post
I had tons of problems with these Asus chip fans. I asked Asus to deliver 12 replacements (as I had a lot of pcs at that time with the same problem) It worked well, but placing a tiny heatsink well glued to the chip worked well also, as long as one does not want to overclock the thing. It's true that the temp raised a bit, but it remained pretty much in the tolerance area.
Posted on May 21, 2008
    Problem Solver:
  • 7 Answers
Pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Posted on Apr 03, 2008
  • Anonymous Apr 09, 2008
    Hey pils,
    Oiling a fan is often a good temporary solution (heck, I still do it every once in a while), but once the bearing sleeve/balls start to wear, it's only a matter of time before the fan will not run - even with the oil. I think a change of fan will take care of all of your issues. Yes, CPU fans are available as standalone products and are often not too expensive. I'd be willing to point you in the right direction for a new CPU fan if you would like. Do you know what type of motherboard and CPU you are using?
  • Anonymous Apr 10, 2008
    OH! You are talking about the chipset fan! I apologize. I misunderstood.
    Yes. There are options to replace the fan. They are in the cost range of $10-$25 with shipping. Take a look at these chipset coolers and read some of the comments. Many have installed new fans/heatsinks on your exact motherboard after having your same problem.
    Newegg Chipset Cooling
    Keep in mind that if you install a fanless heatsink, you'll have to turn off the fan warning in your computer BIOS to get rid of that pesky warning.
SOURCE:
Problem: No display everything running including cpu fan, pci card everything. No error sound. Anyone please help. its a x58 chipset. I also checked that the motherboard getting hanged. like after running...
You will remove the CMOS battery and wait for 5 minutes .
Hope it will solve.
If the problem is same please change or clean the RAM with eraser and install it again.
If the problem is same please ,
http://www.techspot.com/review/129-asus-p6t-deluxe/If the mobo is in warranty should change .If period expire Now you will create a identity mark on BIOS chip and ,you should remove resoiulder the BIOS chip from *********** board .and install it again tightly.
If all the procedure will fail think your mobo should change as new.
Hope this helps.
Jan 10, 2011 | ASUS P6T Deluxe Motherboard
When i boot up the laptop i get a message 'Main Fan Error' the fan runs on start up then stops just before i get the error message. Fan will not restart... Joseph
This message means that the fan on your CPU (processor) is failing or has failed. This is not good because if the fan on the CPU fails your CPU will overheat and cause your machine to lock up and become non-functional till it cools down and then the same cycle will repeat till the fan is replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 11, 2010 | Gateway (8008625) Cooling Fan, Heatsink...
Motherboard A8V-E SE core Temperature at 58C is that normal?
Hi
AMD's CPU temperature's range from 10-85 degrees, the normal is around 48-60 degrees. So your within the normal. Sometimes depending on what your doing, the chip will run up to 70 or so, that's also normal, but you want to make sure that it doesn't stay at 70 for long. It will shorten the life of the CPU.
Thanks for asking on FixYa
Mark
Jan 31, 2010 | ASUS A8V-E SE Motherboard
Cpu chip fan
This sounds as if the motherboard arrived with some form of issue. It has been happening quite frequently with ASUS boards recently. The retention bracket which connects the heatsink/fan to the CPU? If so, yes, it should be connected to ensure the processor remains cool. You are correct, you will need a DVI-HDMI cable. Not to worry, though. They have become quite popular recently.
Let me know if you have any other questions.
Mar 11, 2009 | ASUS A8N-SLI Deluxe Motherboard
Asus A8N-E failing? Chip fan dead?
The CPU fan need to be replaced and the CPU may now be damaged for overheat.
Jan 19, 2009 | ASUS A8N-E Motherboard
ASUS P5VD2-MX Temperature label on speedfan
Hi dutchdj, speed fan software is not perfect. If you look on the motherboard, use your manual & go to page 1-6. You'll see there is a power connector in-between the memory & the main MB power connector. The 3-pin connector closest to the upper right hand of the board is for the CPU fan. The 3-pin power connector under the CPU fan connector is for the MB fan. You seem to have this covered. You are correct. There is no other 3-pin connectors for additional fans. (I went over your manual), your good!
It is possible that your software is trying to monitor the graphics card fan. I wouldn't worry about it. The temp 41c-44c is still within normal temp. If you want to help lower the over all temp, suggest you add 1 or 2 side case fans. These will bring in fresh air onto the MB & help cool CPU, MB, video & hdd's. I did this for my Asus & it has helped allot.
Check out this site if you want to add more case fans;
http://www.xoxide.com/casefans.html
Link to Asus;
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=1200&modelmenu=1
Your fine dutchdj!
Good eye.
Mike
Jan 14, 2009 | ASUS P5VD2-MX SE Motherboard
Cpu temp probe
probe needs to be between the cpu and cooler and the feeder power needs to be checked for proper AMPS and volts. lala linda
May 27, 2008 | Aerocool CoolWatch Fan Controllers
Cpu fan noisy /chip fan fail
You must buy a new CPU Fan. You can get them HERE or a zillion other places on the Internet. You need a Socket 939 type fan that will handle your cpu speed. If you need help installing it, it may be in the manual. You can read the manual by clicking on the picture of your MB at the top of this post and then scrolling down.
Hope that fixed ya...
Geno
Apr 01, 2008 | ASUS A8N-E Motherboard
ASUS STRIKER FORMULA
This Is A Processor error Message, CPU ( Central-Processing-Unit ) INT ( Intermittent Fault ) wrong Type Installed. ( Faulty Processor ) Disconnected Fan-Wire To Motherboard ?
Or if It,s INIT Then It Fails To Initialise The CPU.
Is The Board Auto-detect Settings ? Or Jumpered ?
Mike @ Compurepair.
** Please don,t Rate This Post until Your Problem/Issue Has Been Resolved**
Feb 27, 2008 | ASUS Striker Extreme Motherboard
ASUS A8N-E Motherboard Logo
1,348 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
