Question about LG enV VX9900 Cellular Phone
Charging My phone will not pick up the battery charge. When I plug it in it doesn't recognize it. I have tried 2 different cell phone chargers and neither one works, What do I do?
Yea i had the same problem too.
1st of all you probably have a dead battery meaning it wont hold a charge and 2nd your ciruit board where u plug the charger in is probably broken. you will know if its broken if you can wiggle it around, its suppose to be stuck in place.
so take it in to verizon, they will help you, i got a free phone out of it =]
Posted on Apr 14, 2008
    Problem Solver:
  • 10 Answers
Do you have the PC transfer cable. If you do try that and see if it recognize it. If it does you can charge it thru that using PC.
Posted on Apr 04, 2008
SOURCE:
The usb for charging but it is not charging.
are you using the charger that came with the phone? I ask because I've run into in the past that if you try and use a different charger it may not work on your phone. you should use the one that came with the phone. having said that, you might want to try a different usb charger if that doesn't work it's probably the battery. Li-Ion batteries have charging circuits built in that can fail and also prevent the battery from charging if it's gone bad.
Nov 09, 2012 | Sony Ericsson Xperia Arc
My samsung corby cannot be charge..how can i solve this problem?
I would try charging it with a different charger. its more likely that the charger itself is the issue. If not then the issue could be with the phone. Try a hard reset of the phone ( pulling the battery) and then put battery back in and plug in charger. try moving it around if no connection issue could be with the charger or the charging port on the phone.
Oct 19, 2012 | Samsung GT S3850 Corby II
My Nokia E73 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 15, 2012 | Nokia E73 Mode Cell Phone
Phone won't charge
First Option:
Second Option:
Jul 28, 2012 | Pantech Pursuit Cell Phone
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
Second Option:
Jul 26, 2012 | Huawei Impulse 4G
The battery is not charging when I plug my phone in. I have tried different chargers as well as a new battery.
Since you tried different charges and a new battery may be the charging jack in your phone has loose contact .i mean the board of your phone.also check the charger IC.
Mar 05, 2010 | Motorola Mobility RAZR V3
Razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
Oct 26, 2009 | Motorola Mobility RAZR V3
Won´t charge
My SLVR had the same problem, so I bought a new one from Amazon. When I plugged the new one in the first time it did fine, but when I ran the battery completely out, it wouldn't charge. I played around with it a little bit, and I think I've found a solution that works: try taking the SIM card out of the phone, THEN charge it. It works on both my new one and my old one that way. The drawback for you is that you can't use your phone while its charging, I just switch phones while the other is charging, a bit of a pain sometimes, but the SLVR is my favorite phone so its worth it. :-) Good Luck.
Dec 10, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
LG enV VX9900 Cellular Phone Logo
126 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
