Fault I have a picture distortion problem with my Thomson TV 28wn22u. Both side the picture is concaving. I was told the problem can be solved using the remote. But how?
  • camel42 Apr 06, 2008
    but how do I adjust that?
  • 113 Answers
You probably need to adjust the setting for " pincushion "
Posted on Apr 03, 2008
  • 1 more comment
  • mark merle
    mark merle Apr 03, 2008
    you will find this in the settings menu
  • mark merle
    mark merle Apr 07, 2008
    because of the rating you offered i won't help you!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • mark merle
    good luck to you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PICTURE CONCAVE OR CURVING ON THE SIDE
Pin-cushion distortion. Contact any service technician. Its convergence part circuit need a through check-up. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 10, 2015 | Televison & Video
The picture on our Sony TV Model KP-43HT20 recently became distorted, concaving at top and bottom. If I use reset the Flash Focus, the picture will return to full screen side for awhile but the colors do...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergene board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 15, 2011 | Sony KP-43HT20 43" Rear Projection...
The image on the TV jitters from side to side rapidly, distorting the entire image on every input. I was told perhaps this is a voltage ripple problem; I replaced a bad capacitor already and it helped...
Replace all capacitors in Hyper Module mounted on main board of tv to solve this issue. These are maybe 10 capacitors, replace them all, this will solve your tv picture problem.
Thanks.
Dec 27, 2010 | Toshiba 50H82 50" Rear Projection...
Rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Sep 15, 2009 | RCA D52W23 52" HDTV CRT TV
My 29" LG golden eye T.v is view pictures in concave
Thyere is a fault in the horizontal stage or supply, I suggest Horizontal, if electronically minded check capacitors around the HO stage, could also be a ceramic cap....Phil
May 19, 2009 | RCA TruFlat 27F520T 27" TV
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
THOMSON 21DF8DR
check the yoke magnets alignment
Oct 25, 2008 | Thomson 21DC320 21" TV
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
